Highlighted
Beginner
Not Display Caller name from Siemen IP Phone to Cisco IP Phone
Dear all,
I have a problem when siemen ip phone call to cisco ip phone, it not display caller name.
But cisco ip phone call to siemen ip phone is show caller name.
It can display caller name when I use CUCM version 6.1 but now I upgrade to CUCM 8.5 already.
My diagram
cisco ip phone (4605) <--> router (MGCP) <--> PBX (Siemen) <--> siemen ip phone
(5959)
I debug isdn q931 and show this result
Jul 29 12:34:09.825 TH: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x098F
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Facility i = 0x9FAA06800100820100A1180201000201008010507261736F6E672E4C75202D20494354
        Calling Party Number i = 0x0081, '4605'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '5959'
Jul 29 12:34:09.885 TH: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x898F
Jul 29 12:34:09.925 TH: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x898F
        Facility i = 0x9FAA068001008201008B0100A1150202DCA506082B0C02885302010603050011000000
        Facility i = 0x9FAA068001008201008B0100A10F0202DCB402015530068204061C0840
        Facility i = 0x9FAA068001008201008B0100A1170202DCC3020101A10E040949342D4F4E53495445020101
        Facility i = 0x9FAA068001008201018B0100A14A0202DCD206082B0C028853020100303A810C0C06008035393539740200C0822A031902000410000000600000040400C00E38008F048005000088836301C37C0A8349342D4F4E53495445
        Progress Ind i = 0x8088 - In-band info or appropriate now available
Jul 29 12:34:11.233 TH: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x098F
        Cause i = 0x8090 - Normal call clearing
Jul 29 12:34:11.341 TH: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x898F
Jul 29 12:34:11.349 TH: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x098F
How I configure any command at voice gateway or change at CUCM.
Please help.
Thank you
6 REPLIES 6
Highlighted
Beginner
are these checked under the port which is connect to the siemen PBX ?
Highlighted
Beginner
Hi Linuxchild,
I try already but still not display.
Please help
Thank you
Highlighted
Beginner
Hello
I don't know if this has relation to your installation
but I have found this
Calling Line (Number) Identification Restriction (CLIR) is not supported by the Siemens PBX for outgoing calls. The PBX does honor CLIR on incoming calls, however.
http://www.ciscopaw.net/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/571119nt.pdf
Beginner
Re: Not Display Caller name from Siemen IP Phone to Cisco IP Pho
I have worked with CUCM <>H323 GW <> E1 ISDN <> Siemens PBX and CLID works fine in both direction. Could you post your debug output in the other way direction (Siemens calls Cisco).
Thanks!
Highlighted
Have you checked 'Send Calling Name in Facility IE' on the E1 config page?
Try that and reset.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Highlighted
Beginner
I configure MGCP this below
Then I cannot configure anything.
Thank you.
