06-13-2014 01:47 AM - edited 03-16-2019 11:06 PM
I am currently have the issue is not display original dialed number when forward a call to external number.
Example:
1111 calls to 3333 forward to 4444 = 4444 see 1111 (correct). However, currently the issue as below
1111 calls to 3333 forward to 4444 = 4444 see 2222 (incorrect)
I have tried to change "Always Display Original Dialed Number " to true in CUCM 9.1 but not effected (default is false)
ISDN -----Voice GW----H323------CUCM--------phone
Any help appreciated.
Best regards,
Tan
Solved! Go to Solution.
06-17-2014 09:55 PM
06-13-2014 02:11 AM
Hello Tan
Please check the calling party selection under Call Routing Information - Outbound Calls in H.323 gateway configuration page.By default it is set as Originator. is it different in your configuration?
If it is set to Originator, it may be set to mainline number by your provider as the calling number is different from the ones you purchased from them. in that case you may try including the Redirecting number for those forwarded calls.
If calling party selection is set to Originator, please try checking the box "Redirecting Number IE Delivery - Outbound" and check the behaviour.
if the issue persists, please collect the debug isdn q931 for a test call and provide us the calling party, redirected party & called party numbers.
//Suresh
Please rate all the helpful posts
06-13-2014 02:45 AM
Hi Suresh,
Yes, it is et to Originator.
I've tried to check the box "Redirecting Number IE Delivery - Outbound" as your advice but not affected.
may i change any configure on voice gateway beside cucm?
Appreciate your help.
Best regards,
Tan
06-13-2014 03:43 AM
Hi Tan,
Make sure you reset the gateway after making any changes.
Manish
06-13-2014 03:52 AM
Hi Manish,
Not yet, you mean is I must reset the voice gateway after any changes, right?
BR
Tan
06-13-2014 03:53 AM
Yes.
06-13-2014 03:46 AM
Hello Tan,
could you please collect debug voice ccapi inout & debug isdn q931 for a test call with Redirecting number IE Delivery Outbound checked?
BR//Suresh
06-13-2014 03:55 AM
Hi Suresh,
Sure, i'll provide you once i come back office.
BR
Tan
06-13-2014 09:48 AM
06-14-2014 11:04 AM
Hello Tan, I checked the debug and saw the gateway received the redirecting number from CUCM
Jun 13 16:35:49.442: //12515/00A680C50100/CCAPI/ccCallSetupRequest:
Calling Number=66457700(TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
Called Number=981181689(TON=Unknown, NPI=Unknown),
Redirect Number=52807, Display Info=
Account Number=997318215, Final Destination Flag=TRUE,
Guid=00A680C5-6528-B139-0100-79020A7D02FC, Outgoing Dial-peer=2
>> but when the call sent out to Telco, the redirecting number was not sent in the setup message.
Jun 13 16:35:49.446: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0BE0
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x0181, '66457700'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x8/0, '81181689'
Plan:Unknown, Type:Unknown
>> To send the redirecting number in the ISDN setup message, we need to configure the command "isdn outgoing ie redirecting-number" in interface Se0/0/0:15 configuration mode.
>> however when we configure the above command, we would still send the Redirect Number as 52807, I believe this is the internal extension number and the telco may not accept this and expect the complete number.
>> So we need to translate this redirecting number to complete number by checking "Redirecting Party Transformation CSS"
>> You have to use the calling party transformation patterns for this, create a unique partition and CSS assign it on the redirecting transformation CSS, however in order to get it to work if you have a VM profile with any type of wildcard it will not to work with this case. so you'll have to remove any wildcards to get it to work.
BR, Suresh
06-15-2014 06:19 PM
Hi Suresh,
thanks for the info. the calling as below.
97318215 calls to 66452807 (internal number) forwards to 81181689 = 81181689 see 66457700 (main line)
i am facing with external number, it's ok with internal number
Appreciated assistance to advise as what should i do now on CUCM and voice GW?
BR
Tan
06-16-2014 05:15 AM
Hi Tan,
Jun 13 16:35:49.438: //-1/00A680C50100/CCAPI/cc_api_call_setup_ind_common:
Interface=0x3111D130, Call Info(
Calling Number=997318215,(Calling Name=)(TON=Subscriber, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE,
>> The calling number is changed to main number in the gateway itself. do you have any translation profile configured for this?
>> could you please post your gateway configuration?
BR,
Suresh
06-16-2014 06:00 PM
Hi Suresh,
I think the telecom only accepts calls when the calling number is within the internal number (DID) Range. That’s why when we make the call with internal number, it will show the number of the caller (correct)
below is translation profile configuration in gateway:
voice translation-rule 10
rule 1 /^5\(2...\)/ /6645\1/ type any unknown
rule 2 /^6645\(2...\)/ /6645\1/ type any unknown
rule 3 /^.*/ /66452700/ type any unknown
voice translation-profile Outgoing
translate calling 10
dial-peer voice 2 pots
description Outgoing Calls to PSTN
translation-profile outgoing Outgoing
destination-pattern 9.T
port 0/0/0:15
Thanks for your help.
BR
Tan
06-16-2014 08:53 PM
06-17-2014 06:22 PM
Hi Suresh,
Thanks for the info. I'll try as your guide and keep update to you.
Best regards,
Tan
