1266
Highlighted
Beginner
Not hearing any prompt from BACD on ISR gen 2
Dear all,
I configured bacd so many times before on ISRs and never failed.  This is my first time configuring bacd on ISR gen 2.  The script itself works, the debug shows the prompt is being played and it responses to user inputs.  Unfortunately, I can't hear it.  Actually, it's not only bacd, but all TCL scripts with audio prompts.  I just can't hear the audio.  Any help would be very appreciated.
Cisco 3925 (c3900-universalk9-mz.SPA.152-1.T.bin) - CME ver. 8.8
application
service aa flash:/IVR/app-b-acd-aa-2.1.2.2.tcl
  paramspace english index 1
  param number-of-hunt-grps 3
  param menu-timeout 6
  param dial-by-extension-option 5
  param handoff-string aa
  paramspace english language en
  param max-time-vm-retry 2
  param max-extension-length 4
  param aa-pilot 8999
  paramspace english location flash:/IVR/
  param second-greeting-time 60
  param welcome-prompt drc_welcome.wav
  param call-retry-timer 15
  param max-time-call-retry 600
  param voice-mail 8100
  param service-name queue
service queue flash:/IVR/app-b-acd-2.1.2.2.tcl
  param aa-hunt3 8100
  param queue-len 10
  param aa-hunt1 8618
  param queue-manager-debugs 1
  param aa-hunt2 8619
dial-peer voice 11 voip
description IVR
service aa
destination-pattern 8999
session target ipv4:10.230.254.21
incoming called-number 8999
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
Christian
Everyone's tags (2)
12 REPLIES 12
Highlighted
Hi Christian.
This could mean that your VG is unable to find the welcome prompt file into the specified location or the filename.
Try to simply rename your file
drc_welcome.wav in en_welcome.wav and define the welcome-prompt param with _welcome.wav.
Please try it and let me know.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Highlighted
Beginner
Hi Carlo,
Thank you for your prompt response. I have tried to use the default prompt (en_bacd_welcome.au) and define welcome-prompt param with _bacd_welcome.au.  Unfortunately it didn't work.  Do you have any idea or any debug I can use?
I tried "debug voice application script" -> it said the prompt was being played
I tried "debug voice application medi" -> it seemed that it was streaming the media
Christian
Highlighted
Hi Christian.
Are you able to hear other prompts, option_menu or invalid_input for example?
Where are you calling the aa pilot from? (eg. from ip phone registered on cucm or on cucme)
and last...
Is  10.230.254.21 the local ip address of vg you are configuring?
Let me know.
Carlo
Highlighted
Beginner
Hi Carlo,
I also can't hear the other prompts, I tried invalid entries and no prompt.  There's also no option menu prompt.
I called from IP phones registered to CME on this local router (10.230.254.21).  This is a one router configuration.
By the way, 10.230.254.21 is the address of the router's BVI.
Christian
Highlighted
Hi Christian.
Can you post your config and the output of a debug voip application media?
Thanks.
Carlo
Highlighted
Beginner
Re: Not hearing any prompt from BACD on ISR gen 2
Hi Carlo,
Could you please analyze this show run and debug voice application media for me?  Thank you.
Christian
Highlighted
Hi Christian.
Try to download versio 3.0 of BACD script and see if it works.
Let me know
Bye
Carlo
Highlighted
Hi Christian.
Just another point.
Try to put your prompts into flash root and change your parameters.
Carlo
Highlighted
Beginner
Hi Carlo,
Thanks for your suggestion, I have tried the version 3 bacd and put the files in the flash root, but it still the same.
With TAC assistance, we found this looping problem :
05:24:20: voip_rtp_media_loop_detect:ERR, gccb:0x19704260, pak:0x12DE62E4, callID:180, pak consumed
05:24:20: RTP(2053): ps rx s=10.35.253.132(17786), d=10.230.254.21(30052), pt=0, ts=821F6755, ssrc=12EAFD84, marker=0
05:24:20: voip_rtp_media_loop_detect:ERR, gccb:0x19704260, pak:0x1A127FC4, callID:180, pak consumed
05:24:20: voip_rtp_media_loop_detect:ERR, gccb:0x19704260, pak:0x12DE69B8, callID:180, pak consumed
05:24:20: voip_rtp_media_loop_detect:ERR, gccb:0x19704260, pak:0x1A128698, callID:180, pak consumed
05:24:20: RTP(2054): ps rx s=10.35.253.132(17786), d=10.230.254.21(30052), pt=0, ts=821F67F5, ssrc=12EAFD84, marker=0
05:24:20: RTP(2055): ps rx s=10.35.253.132(17786), d=10.230.254.21(30052), pt=0, ts=821F6895, ssrc=12EAFD84, marker=0
05:24:20: RTP(2056): ps rx s=10.35.253.132(17786), d=10.230.254.21(30052), pt=0, ts=821F6935, ssrc=12EAFD84, marker=0
05:24:20: voip_rtp_media_loop_detect:ERR, gccb:0x19704260, pak:0x12DE708C, callID:180, pak consumed
05:24:20: RTP(2057): ps rx s=10.35.253.132(17786), d=10.230.254.21(30052), pt=0, ts=821F69D5, ssrc=12EAFD84, marker=0
05:24:20: RTP(2058): ps rx s=10.35.253.132(17786), d=10.230.254.21(30052), pt=0, ts=821F6A75, ssrc=12EAFD84, marker=0
05:24:20: voip_rtp_media_loop_detect:ERR, gccb:0x19704260, pak:0x1A128D6C, callID:180, pak consumed
05:24:20: voip_rtp_media_loop_detect:ERR, gccb:0x19704260, pak:0x12DE7760, callID:180, pak consumed
05:24:20: RTP(2059): ps rx s=10.35.253.132(17786), d=10.230.254.21(30052), pt=0, ts=821F6B15, ssrc=12EAFD84, marker=0
05:24:20: voip_rtp_media_loop_detect:ERR, gccb:0x19704260, pak:0x1A129440, callID:180, pak consumed
05:24:20: RTP(2060): ps rx s=10.35.253.132(17786), d=10.230.254.21(30052), pt=0, ts=821F6BB5, ssrc=12EAFD84, marker=0
05:24:20: voip_rtp_media_loop_detect:ERR, gccb:0x19704260, pak:0x12DE7E34, callID:180, pak consumed
05:24:20: voip_rtp_media_loop_detect:ERR, gccb:0x19704260, pak:0x1A129B14, callID:180, pak consumed
05:24:20: voip_rtp_media_loop_detect:ERR, gccb:0x19704260, pak:0x12DE8508, callID:180, pak consumed
05:24:20: RTP(2061): ps rx s=10.35.253.132(17786), d=10.230.254.21(30052), pt=0, ts=821F6C55, ssrc=12EAFD84, marker=0
05:24:20: RTP(2062): ps rx s=10.35.253.132(17786), d=10.230.254.21(30052), pt=0, ts=821F6CF5, ssrc=12EAFD84, marker=0
05:24:20: RTP(2063): ps rx s=10.35.253.132(17786), d=10.230.254.21(30052), pt=0, ts=821F6D95, ssrc=12EAFD84, marker=0
05:24:20: voip_rtp_media_loop_detect:ERR, gccb:0x19704260, pak:0x1A12A1E8, callID:180, pak consumed
05:24:20: RTP(2064): ps rx s=10.35.253.132(17786), d=10.230.254.21(30052), pt=0, ts=821F6E35, ssrc=12EAFD84, marker=0
05:24:20:
I'm not sure if this is the cause and what causes the loop.  Have you ever heard about this?
Christian.
Highlighted
Hi Christian.
Yes I heard something about it in th past.
Please post me the output of a show voip rtp connections and, if you can, a second output of a debug voip rtp.
Carlo
Highlighted
Beginner
Hi Carlo,
Here is the debug file as requested. Hope it helps.
Christian.
Highlighted
Beginner
Hi Carlo,
The problem is now solved.  After I tried several IOS, finally c3900-universalk9-mz.SPA.150-1.M7.bin worked.  It seems that this is a IOS bug.  Thank you for your help.
Christian
Content for Community-Ad
Cisco COVID-19 Survey
