not recieving incoming calls in the endpoint
eljaouhari04
Can you please help me , i have a  cisco BEE6K with a gateway 2901 I have everything configured but I do not receive calls in the endpoint, this is my configuration:
sh run
Building configuration...
Current configuration : 8003 bytes
! Last configuration change at 11:19:43 UTC Tue Jul 28 2015 by cisco
! NVRAM config last updated at 11:07:13 UTC Tue Jul 28 2015 by cisco
version 15.4
hostname gateway
boot-start-marker
boot-end-marker
card type e1 0 1
logging buffered 51200 warnings
no aaa new-model
network-clock-participate wic 1
network-clock-select 1 E1 0/1/0
ip dhcp excluded-address 192.168.1.10 192.168.1.20
ip dhcp excluded-address 192.168.1.244 192.168.1.254
ip dhcp excluded-address 172.27.199.10 172.27.199.20
ip dhcp pool ccp-pool
 import all
 network 192.168.1.0 255.255.255.0
 default-router 192.168.1.1
 dns-server 192.168.1.1
 domain-name ciscolocal.com
 --More--
ip host ns.ciscolocal.com 192.168.1.1
ip host ucn1.ciscolocal.com 192.168.1.12
ip host pcp.ciscolocal.com 192.168.1.10
ip name-server 192.168.1.1
ip cef
no ipv6 cef
isdn switch-type primary-ni
cts logging verbose
crypto pki trustpoint TP-self-signed-3114885926
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3114885926
 revocation-check none
 rsakeypair TP-self-signed-3114885926
crypto pki certificate chain TP-self-signed-3114885926
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33313134 38383539 3236301E 170D3135 30343137 31353530
  32345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 31313438
  38353932 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100DFAA B6C811F2 D22F617C 74DE00C6 DEBFB730 079935B9 B1906BC2 CA229353
  CC71FDD2 557C41F5 B9F21BCE AC34A823 2F4BA033 466FAA63 AA1ED477 9904EE82
  DFA2C8C9 1F1B3E28 7F730BE5 DC2814E6 36F55B9A 4659E232 24649078 9AE18723
  FAC4618B 31EE7908 93DCB78E 8F3EA49B 59B323F5 85C7285F A25B9B0F 55EF85F1
  4BC10203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 146A859E 6A65318A A1A58FD2 5F3C7741 7F2C890F 8A301D06
  03551D0E 04160414 6A859E6A 65318AA1 A58FD25F 3C77417F 2C890F8A 300D0609
  2A864886 F70D0101 05050003 81810077 15E75B62 93306F50 78630D69 0CCA387E
  2CBC55D4 064C35F2 EC176DA5 3B87A789 5CED2AC9 CDCEF5A7 EFD3AC45 10693A5E
  DE656AEC 0884424E 29DD6180 1202F8EF A9B369DA 33E0F6AE F4847CBE E13B8946
  FF742C11 C8949AD5 C5636F84 1B7EBA4D 965EC890 894F081D 38224862 25B63E1C
  AA13FF57 BE052C99 36CAB4AA F2432F
        quit
voice-card 0
voice call send-alert
voice call convert-discpi-to-prog
voice call carrier capacity active
voice rtp send-recv
voice service voip
 ip address trusted list
  ipv4 192.168.1.11
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 supplementary-service h450.12
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 h323
  no call service stop
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
 codec preference 2 g729r8
voice class h323 1
  h225 timeout tcp establish 3
license udi pid CISCO2901/K9 sn FGL191611G2
hw-module pvdm 0/0
hw-module pvdm 0/1
username cisco privilege 15 secret 5 $1$GHtD$wnwJjzlvzGVQ8P7bjZ2WB.
redundancy
controller E1 0/1/0
 pri-group timeslots 1-10,16
controller E1 0/1/1
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/1/0:15
 no ip address
 encapsulation hdlc
 isdn incoming-voice voice
 no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
control-plane
voice-port 0/0/0
 supervisory disconnect dualtone mid-call
 timeouts initial 0
 timeouts interdigit 0
 timeouts call-disconnect 0
 connection plar opx 1010
 bearer-cap 3100Hz
 caller-id enable
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0:15
mgcp
mgcp call-agent 192.168.1.11 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
ccm-manager music-on-hold
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager config server 192.168.1.11
ccm-manager config
dial-peer voice 99900990 pots
 service mgcpapp
 port 0/0/0
dial-peer voice 2 pots
 port 0/0/0
dial-peer voice 3 pots
 port 0/0/0
dial-peer voice 103 pots
 description utliser pour les appels vers les numeros verts
 destination-pattern 7T
 progress_ind setup enable 3
 progress_ind alert enable 8
 direct-inward-dial
 port 0/0/0
 forward-digits all
dial-peer voice 99900099 pots
 service mgcpapp
 port 0/0/0
dial-peer voice 5 voip
 description utiliser pour les appels entrants extensions 4 chiffres
 destination-pattern 1...
 session target ipv4:192.168.1.11
 incoming called-number .
 dtmf-relay h245-alphanumeric
 codec g711ulaw
 no vad
gateway
 timer receive-rtp 1200
gatekeeper
 shutdown
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you want to
use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE  PUBLICLY-KNOWN
CREDENTIALS
Here are the Cisco IOS commands.
no username cisco
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
 login local
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 access-class 23 in
 privilege level 15
 login local
 transport input telnet ssh
line vty 5 15
 access-class 23 in
 privilege level 15
 login local
scheduler allocate 20000 1000
ntp master 3
ntp server 192.168.1.1
end
gateway#
10 Replies 10
Manish Gogna
Where is the endpoint registered ( CUCM or CME ) ?
Can you provide "debug isdn q931" and "debug voice ccapi inout" for a test call alongwith calling and called party numbers.
Manish
- Do rate helpful posts -
Hi, thanks for your answer,
The endpoint is registred with CUCM (BE6000), this is the debug:
ug 10 10:34:44.555: //-1/4006AFE28016/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x22D7C840, Call Info(
   Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=1010(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=99900990, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Aug 10 10:34:44.555: //-1/4006AFE28016/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Aug 10 10:34:44.555: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 10 10:34:44.555: :cc_get_feature_vsa malloc success
Aug 10 10:34:44.555:  cc_get_feature_vsa count is 1
Aug 10 10:34:44.555: :FEATURE_VSA attributes are: feature_name:0,feature_time:1056708128,feature_id:9
Aug 10 10:34:44.555: //9/4006AFE28016/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=1010(TON=Unknown, NPI=Unknown))
Aug 10 10:34:44.559: //9/4006AFE28016/CCAPI/cc_process_call_setup_ind:
   Event=0x3E8BDF70
Aug 10 10:34:44.559: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 1010
   >>>>CCAPI handed cid 9 with tag 99900990 to app "MGCPAPP"
Aug 10 10:34:44.559: //9/4006AFE28016/CCAPI/ccCallSetContext:
   Context=0x2200B0F0
Aug 10 10:34:44.559: //9/4006AFE28016/CCAPI/ccCallSetupAck:
   Call Id=9
Aug 10 10:34:44.559: //9/4006AFE28016/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
Aug 10 10:34:44.559: //9/4006AFE28016/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x0
   Call Entry(Connected=TRUE, Responsed=TRUE)u all
Aug 10 10:36:14.207: :FEATURE_VSA attributes are: feature_name:0,feature_time:1056708128,feature_id:11
Aug 10 10:36:14.207: //11/75767F8E801B/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
Aug 10 10:36:14.207: //11/75767F8E801B/CCAPI/cc_process_call_setup_ind:
   Event=0x3E8BD468
Aug 10 10:36:14.207: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   >>>>CCAPI handed cid 11 with tag 99900990 to app "MGCPAPP"
Aug 10 10:36:14.207: //11/75767F8E801B/CCAPI/ccCallSetContext:
   Context=0x2200B0F0
Aug 10 10:36:14.207: //11/75767F8E801B/CCAPI/ccCallSetupAck:
   Call Id=11
Aug 10 10:36:14.207: //11/75767F8E801B/CCAPI/cc_api_set_transfer_info:
Aug 10 10:36:14.207: //11/75767F8E801B/CCAPI/ccCallConnect:
Aug 10 10:36:29.223: //11/75767F8E801B/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms)
   Call Entry(Inter Digit Timeout=4000(ms), Initial Digit Timeout=4000(ms))
Aug 10 10:36:29.223: //11/75767F8E801B/CCAPI/ccRestartDigitTimeoutMsec:
   Digit Timeout=0, Call Id=11
Aug 10 10:36:29.223: //11/75767F8E801B/CCAPI/ccCallReportDigits:
   (callID=0xB, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=11
Aug 10 10:36:29.223: //11/75767F8E801B/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x22D7C840, callID=0xB, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x22D7C840, Call Id=11
   Call Entry(Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms))
Aug 10 10:36:29.223: //11/75767F8E801B/CCAPI/ccCallDigit:
   Digit Tone Mode=DTMF, Call Id=11
Aug 10 10:36:29.223: //11/75767F8E801B/CCAPI/ccCallModify:
   Nominator=0x1001, Params=0x3EDAF948, Call Id=11
Aug 10 10:36:29.223: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x226EF79C, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Aug 10 10:36:29.223: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 10 10:36:29.223: :cc_get_feature_vsa malloc success
Aug 10 10:36:29.223:  cc_get_feature_vsa count is 2
Aug 10 10:36:29.223: :FEATURE_VSA attributes are: feature_name:0,feature_time:1056707904,feature_id:12
Aug 10 10:36:29.223: //12/75767F8E801B/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
Aug 10 10:36:29.223: //12/75767F8E801B/CCAPI/ccCallSetContext:
   Context=0x2200B040
Aug 10 10:36:29.227: //11/75767F8E801B/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x22D7C840, Call Id=11
Aug 10 10:36:29.227: //12/75767F8E801B/CCAPI/cc_api_call_connected:
   Interface=0x226EF79C, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Aug 10 10:36:29.227: //12/75767F8E801B/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID1=0xC, gcid=0-0-0-0, tag=0x0)
Aug 10 10:36:29.227: //11/75767F8E801B/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID2=0xB, gcid=75767F8E-3E8211E5-801B8320-1F96CD66, tag=0x0)
   Conference Id=0xFFFFFFFF, Call Id1=12, Call Id2=11, Tag=0x0
Aug 10 10:36:29.227: //12/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
Aug 10 10:36:29.227: call_info mainst_callID:0xC, peer_callID:0xB, confID:0x6, spi_type:6, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
Aug 10 10:36:29.227:   stream[0]: callid:0xC, media_passthrough:0
Aug 10 10:36:29.227: //12/75767F8E801B/CCAPI/cc_api_bridge_done:
   Conference Id=0x6, Source Interface=0x226EF79C, Source Call Id=12,
   Destination Call Id=11, Disposition=0x0, Tag=0x0
Aug 10 10:36:29.227: //11/75767F8E801B/CCAPI/cc_api_bridge_done:
   Conference Id=0x6, Source Interface=0x22D7C840, Source Call Id=11,
   Destination Call Id=12, Disposition=0x0, Tag=0xFFFFFFFF
Aug 10 10:36:29.227: //12/75767F8E801B/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x6, Destination Call Id=11)
   Call Entry(Conference Id=0x6, Destination Call Id=12)
Aug 10 10:36:29.2u27: confID:0x6; callEntry1 callID1:0xC, type:9; callEntry2 callID2:0xB, type:6
Aug 10 10:36:29.227: //11/75767F8E801B/CCAPI/cc_api_caps_ind:
   Destination Interface=0x226EF79C, Destination Call Id=12, Source Call Id=11,
   Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Aug 1all0 10:36:29.227: //12/75767F8E801B/CCAPI/cc_api_caps_ind:
   Destination Interface=0x22D7C840, Destination Call Id=11, Source Call Id=12,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
Aug 10 10:36:29.227: //12/75767F8E801B/CCAPI/cc_api_caps_ind:
Aug 10 10:36:29.227: //12/75767F8E801B/CCAPI/cc_api_caps_ack:
Translating "uall"...domain server (192.168.1.1)2D7C840, Destination Call Id=11, Source Call Id=12,
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Fax Version:=0, Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=4351)
Aug 10 10:36:29.227: //11/75767F8E801B/CCAPI/cc_api_caps_ack:
Aug 10 10:36:29.227: //12/75767F8E801B/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x6, Call Id1=12, Call Id2=11
Aug 10 10:36:29.227: //11/75767F8E801B/CCAPI/cc_api_voice_mode_event:
   Call Id=11
   Call Entry(Context=0x2200B0F0)
Aug 10 10:36:29.267: //11/75767F8E801B/CCAPI/ccCallModifyExtended:
   Nominator=0x3EDAECB8, Params=0x3EDAF0C8, Call Id=11
Aug 10 10:36:29.267: //12/75767F8E801B/CCAPI/ccCallModify:
   Nominator=0x18E30, Params=0x3EDAF6A0, Call Id=12
Aug 10 10:36:29.271: //11/75767F8E801B/CCAPI/cc_api_call_modify_done:
Aug 10 10:36:29.271: //12/75767F8E801B/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x226EF79C, Call Id=12
Aug 10 10:36:29.271: //12/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
Aug 10 10:36:29.271: call_info mainst_callID:0xC, peer_callID:0xB, confID:0x6, spi_type:6, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
Aug 10 10:36:29.271:   stream[0]: callid:0xC, media_passthrough:0
Aug 10 10:36:33.223: //11/75767F8E801B/CCAPI/cc_handle_inter_digit_timer:
   Generate inter-digit timeout CC_EV_CALL_DIGIT_END event
Aug 10 10:36:38.579: //11/75767F8E801B/CCAPI/ccCallModifyExtended:
Aug 10 10:36:38.579: //12/75767F8E801B/CCAPI/ccCallModify:
   Nominator=0x800, Params=0x3EDAF6A0, Call Id=12
Aug 10 10:36:38.579: //11/75767F8E801B/CCAPI/cc_api_call_modify_done:
Aug 10 10:36:38.579: //12/75767F8E801B/CCAPI/cc_api_call_modify_done:
Aug 10 10:36:38.579: //12/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
Aug 10 10:36:38.579: call_info mainst_callID:0xC, peer_callID:0xB, confID:0x6, spi_type:6, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
Aug 10 10:36:38.579:   stream[0]: callid:0xC, media_passthrough:0
Aug 10 10:36:38.583: //11/75767F8E801B/CCAPI/ccCallReportDigits:
   (callID=0xB, digit_event=0x0, enable=FALSE, consume=FALSE)
Aug 10 10:36:38.583: //11/75767F8E801B/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x22D7C840, callID=0xB, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Aug 10 10:36:38.583: //11/75767F8E801B/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Fast Busy,
   Tone Direction=Network, Params=0x0, Call Id=11
% Bad IP address or host name
Aug 10 10:36:50.331: //11/75767F8E801B/CCAPI/cc_api_call_disconnected:
   Cause Value=0, Interface=0x22D7C840, Call Id=11
   Call Entry(Responsed=TRUE, Cause Value=0, Retry Count=0)
Aug 10 10:36:50.331: //11/75767F8E801B/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
Aug 10 10:36:50.331: //12/75767F8E801B/CCAPI/ccGetCallStatistics:
   Call Stats=0x3EED8970, Call Id=12
Aug 10 10:36:50.331: //12/75767F8E801B/CCAPI/ccConferenceDestroy:
   Conference Id=0x6, Tag=0x0
Aug 10 10:36:50.331: confID:0x6; callEntry1 callID1:0xC, type:9; callEntry2 callID2:0xB, type:6
Aug 10 10:36:50.331: //12/75767F8E801B/CCAPI/cc_api_bridge_drop_done:
Aug 10 10:36:50.331: //11/75767F8E801B/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=12, Disposition=0x0, Tag=0x0
Aug 10 10:36:50.331: //12/75767F8E801B/CCAPI/cc_generic_bridge_done:
Aug 10 10:36:50.331: //11/75767F8E801B/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Aug 10 10:36:50.331: //11/75767F8E801B/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
Aug 10 10:36:50.331: //12/75767F8E801B/CCAPI/ccCallDisconnect:
Aug 10 10:36:50.331: //12/75767F8E801B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x226EF79C, Tag=0x0, Call Id=12,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Aug 10 10:36:50.331: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug 10 10:36:50.331: :cc_free_feature_vsa freeing 3EFC1538
Aug 10 10:36:50.331:  vsacount in free is 1
Aug 10 10:36:50.359: //11/75767F8E801B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x22D7C840, Tag=0x0, Call Id=11,
Aug 10 10:36:50.359: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug 10 10:36:50.359: :cc_free_feature_vsa freeing 3EFC1618
Aug 10 10:36:50.359:  vsacount in free is 0
 (192.168.1.1)
A quick look shows that the call is hitting  Incoming Dial-peer=99900990 ( which is MGCP ) and so its not able to hit the outgoing dial peer 5 ( voip ). Can you try adding 'incoming called-number ." under dial-peer 103 and test.
Manish
it redirege me towards inbox "your call can't be continued..."
you are not binding the serial interface 0/1/0:15 so its h323 setup. Modify your incoming dial peer this way and test. Run the debug again and see if it matches 103 pots dial peer for incoming from Telco and outgoing dial peer 5 voip to CUCM.
 incoming called number .
 direct-inward-dial
 forward-digits all
Hello Vijay,
I did what you told me but does not work, below the result of debug voice ccapi inout:
 direct-inward-dial
 port 0/0/0
 forward-digits all
Aug 11 09:08:13.695: //-1/547211368002/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=1010
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Aug 11 09:08:13.695: //-1/547211368002/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x3F359E20, Call Info(
Aug 11 09:08:13.699: //-1/547211368002/CCAPI/ccCheckClipClir:
Aug 11 09:08:13.699: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 11 09:08:13.699: :cc_get_feature_vsa malloc success
Aug 11 09:08:13.699:  cc_get_feature_vsa count is 1
Aug 11 09:08:13.699: :FEATURE_VSA attributes are: feature_name:0,feature_time:553750072,feature_id:1
Aug 11 09:08:13.699: //1/547211368002/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
Aug 11 09:08:13.699: //1/547211368002/CCAPI/cc_process_call_setup_ind:
   Event=0x228EB648
Aug 11 09:08:13.699: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   >>>>CCAPI handed cid 1 with tag 99900990 to app "MGCPAPP"
Aug 11 09:08:13.699: //1/547211368002/CCAPI/ccCallSetContext:
   Context=0x3E5F5A30
Aug 11 09:08:13.699: //1/547211368002/CCAPI/ccCallSetupAck:
   Call Id=1
Aug 11 09:08:13.699: //1/547211368002/CCAPI/cc_api_set_transfer_info:
Aug 11 09:08:13.699: //1/547211368002/CCAPI/ccCallConnect:
Aug 11 09:08:28.927: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 11 09:08:28.927:  cc_get_feature_vsa count is 2
Aug 11 09:08:28.927: :FEATURE_VSA attributes are: feature_name:0,feature_time:553749848,feature_id:2
Aug 11 09:08:28.927: //2/547211368002/CCAPI/ccIFCallSetupRequestPrivate:
Aug 11 09:08:28.927: //2/547211368002/CCAPI/ccCallSetContext:
   Context=0x3E5F5980
Aug 11 09:08:28.931: //1/547211368002/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x3F359E20, Call Id=1
Aug 11 09:08:28.931: //2/547211368002/CCAPI/cc_api_call_connected:
   Interface=0x3ECCCD74, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
Aug 11 09:08:28.931: //2/547211368002/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID1=0x2, gcid=0-0-0-0, tag=0x0)
Aug 11 09:08:28.931: //1/547211368002/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID2=0x1, gcid=54721136-3F3F11E5-8002B723-2A15C5E4, tag=0x0)
   Conference Id=0xFFFFFFFF, Call Id1=2, Call Id2=1, Tag=0x0
Aug 11 09:08:28.931: //2/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
Aug 11 09:08:28.931: call_info mainst_callID:0x2, peer_callID:0x1, confID:0x1, spi_type:6, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
Aug 11 09:08:28.931:   stream[0]: callid:0x2, media_passthrough:0
Aug 11 09:08:28.931: //2/547211368002/CCAPI/cc_api_bridge_done:
   Conference Id=0x1, Source Interface=0x3ECCCD74, Source Call Id=2,
   Destination Call Id=1, Disposition=0x0, Tag=0x0
Aug 11 09:08:28.931: //1/547211368002/CCAPI/cc_api_bridge_done:
   Conference Id=0x1, Source Interface=0x3F359E20, Source Call Id=1,
   Destination Call Id=2, Disposition=0x0, Tag=0xFFFFFFFF
Aug 11 09:08:28.931: //2/547211368002/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x1, Destination Call Id=1)
   Call Entry(Conference Id=0x1, Destination Call Id=2)
Aug 11 09:08:28.931: confID:0x1; callEntry1 callID1:0x2, type:9; callEntry2 callID2:0x1, type:6
Aug 11 09:08:28.931: //1/547211368002/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3ECCCD74, Destination Call Id=2, Source Call Id=1,
Aug 11 09:08:28.931: //2/547211368002/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3F359E20, Destination Call Id=1, Source Call Id=2,
Aug 11 09:08:28.931: //2/547211368002/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=8683)
Aug 11 09:08:28.931: //1/547211368002/CCAPI/cc_api_caps_ack:
Aug 11 09:08:28.935: //2/547211368002/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x1, Call Id1=2, Call Id2=1
Aug 11 09:08:28.935: //1/547211368002/CCAPI/cc_api_voice_mode_ev
gateway#ent:
   Call Id=1
Aug 11 09:08:28.935: //1/547211368002/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x3E5F5A30)
Aug 11 09:08:29.047: //1/547211368002/CCAPI/ccSetDigitTimeouts:
Aug 11 09:08:29.047: //1/547211368002/CCAPI/ccRestartDigitTimeoutMsec:
Aug 11 09:08:29.047: //1/547211368002/CCAPI/ccCallReportDigits:
   (callID=0x1, digit_event=0x1, enable=TRUE, consume=FALSE)
Aug 11 09:08:29.047: //1/547211368002/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x3F359E20, callID=0x1, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x3F359E20, Call Id=1
Aug 11 09:08:29.047: //1/547211368002/CCAPI/ccCallModifyExtended:
   Nominator=0x22D26F20, Params=0x22D27330, Call Id=1
Aug 11 09:08:29.047: //2/547211368002/CCAPI/ccCallModify:
   Nominator=0x18830, Params=0x22D27908, Call Id=2
Aug 11 09:08:29.047: //1/547211368002/CCAPI/cc_api_call_modify_done:
Aug 11 09:08:29.047: //2/547211368002/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x3ECCCD74, Call Id=2
Aug 11 09:08:29.047: //2/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
Aug 11 09:08:29.047: call_info mainst_callID:0x2, peer_callID:0x1, confID:0x1, spi_type:6, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
Aug 11 09:08:29.047:   stream[0]: callid:0x2, media_passthrough:0
Aug 11 09:08:29.083: //1/547211368002/CCAPI/ccCallModifyExtended:
Aug 11 09:08:29.083: //2/547211368002/CCAPI/ccCallModify:
   Nominator=0x18E30, Params=0x22D27908, Call Id=2
Aug 11 09:08:29.087: //1/547211368002/CCAPI/cc_api_call_modify_done:
Aug 11 09:08:29.087: //2/547211368002/CCAPI/cc_api_call_modify_done:
Aug 11 09:08:29.087: //2/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
Aug 11 09:08:29.087: call_info mainst_callID:0x2, peer_callID:0x1, confID:0x1, spi_type:6, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
Aug 11 09:08:29.087:   stream[0]: callid:0x2, media_passthrough:0
Aug 11 09:08:33.047: //1/547211368002/CCAPI/cc_handle_inter_digit_timer:
Aug 11 09:08:38.423: //1/547211368002/CCAPI/ccCallModifyExtended:
Aug 11 09:08:38.423: //2/547211368002/CCAPI/ccCallModify:
   Nominator=0x800, Params=0x22D27908, Call Id=2
Aug 11 09:08:38.423: //1/547211368002/CCAPI/cc_api_call_modify_done:
Aug 11 09:08:38.423: //2/547211368002/CCAPI/cc_api_call_modify_done:
Aug 11 09:08:38.423: //2/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
Aug 11 09:08:38.423: call_info mainst_callID:0x2, peer_callID:0x1, confID:0x1, spi_type:6, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
Aug 11 09:08:38.423:   stream[0]: callid:0x2, media_passthrough:0
Aug 11 09:08:38.431: //1/547211368002/CCAPI/ccCallReportDigits:
   (callID=0x1, digit_event=0x0, enable=FALSE, consume=FALSE)
Aug 11 09:08:38.431: //1/547211368002/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x3F359E20, callID=0x1, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Aug 11 09:08:38.431: //1/547211368002/CCAPI/ccGenerateToneInfo:
Aug 11 09:08:57.347: //1/547211368002/CCAPI/cc_api_call_disconnected:
   Cause Value=0, Interface=0x3F359E20, Call Id=1
Aug 11 09:08:57.347: //1/547211368002/CCAPI/ccGenerateToneInfo:
Aug 11 09:08:57.347: //2/547211368002/CCAPI/ccGetCallStatistics:
   Call Stats=0x3FA55488, Call Id=2
Aug 11 09:08:57.347: //2/547211368002/CCAPI/ccConferenceDestroy:
   Conference Id=0x1, Tag=0x0
Aug 11 09:08:57.347: confID:0x1; callEntry1 callID1:0x2, type:9; callEntry2 callID2:0x1, type:6
Aug 11 09:08:57.347: //2/547211368002/CCAPI/cc_api_bridge_drop_done:
Aug 11 09:08:57.347: //1/547211368002/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=2, Disposition=0x0, Tag=0x0
Aug 11 09:08:57.347: //2/547211368002/CCAPI/cc_generic_bridge_done:
Aug 11 09:08:57.347: //1/547211368002/CCAPI/ccCallDisconnect:
Aug 11 09:08:57.351: //1/547211368002/CCAPI/cc_api_get_transfer_info:
Aug 11 09:08:57.351: //2/547211368002/CCAPI/ccCallDisconnect:
Aug 11 09:08:57.351: //2/547211368002/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3ECCCD74, Tag=0x0, Call Id=2,
Aug 11 09:08:57.351: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug 11 09:08:57.351: :cc_free_feature_vsa freeing 21018D50
Aug 11 09:08:57.351:  vsacount in free is 1
Aug 11 09:08:57.375: //1/547211368002/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3F359E20, Tag=0x0, Call Id=1,
Aug 11 09:08:57.379: //1/547211368002/CCAPI/cc_api_call_disconnect_done:
Aug 11 09:08:57.379: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug 11 09:08:57.379: :cc_free_feature_vsa freeing 21018E30
Aug 11 09:08:57.379:  vsacount in free is 0
Whats this end point with the DN 1010. I can see it is configured to act as a PLAR phone. If you need the incoming PSTN call to reach this destination remove the connection plar command from voice-port 0/0/0.  Also modify the pots dial-peer as mentioned earlier by this way and check. Provide the debug if it still doesnt work.
 direct-inward-dial
 forward-digits all
I made the change as below:
 direct-inward-dial
 port 0/0/0
 forward-digits all
but in voice-port 0/0/0  if I remove connection PLAR opx 1010 where I will receive the call ??
I remove the connection Plar opx 1010 and this is the result of debug:
Aug 11 10:11:03.979: //-1/1BB5B51F8007/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Aug 11 10:11:03.979: //-1/1BB5B51F8007/CCAPI/cc_api_call_setup_ind_common:
Aug 11 10:11:03.979: //-1/1BB5B51F8007/CCAPI/ccCheckClipClir:
Aug 11 10:11:03.979: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 11 10:11:03.979: :cc_get_feature_vsa malloc success
Aug 11 10:11:03.979:  cc_get_feature_vsa count is 1
Aug 11 10:11:03.979: :FEATURE_VSA attributes are: feature_name:0,feature_time:553750072,feature_id:3
Aug 11 10:11:03.979: //3/1BB5B51F8007/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Called Number=(TON=Unknown, NPI=Unknown))
Aug 11 10:11:03.979: //3/1BB5B51F8007/CCAPI/cc_process_call_setup_ind:
   Event=0x228EB648
   >>>>CCAPI handed cid 3 with tag 99900990 to app "MGCPAPP"
Aug 11 10:11:03.979: //3/1BB5B51F8007/CCAPI/ccCallSetContext:
   Context=0x3E5F5A30
Aug 11 10:11:03.979: //3/1BB5B51F8007/CCAPI/ccCallSetupAck:
   Call Id=3
Aug 11 10:11:03.979: //3/1BB5B51F8007/CCAPI/cc_api_set_transfer_info:
Aug 11 10:11:03.979: //3/1BB5B51F8007/CCAPI/ccCallConnect:
gateway(config)#
Aug 11 10:11:19.003: //3/1BB5B51F8007/CCAPI/ccSetDigitTimeouts:
Aug 11 10:11:19.003: //3/1BB5B51F8007/CCAPI/ccRestartDigitTimeoutMsec:
   Digit Timeout=0, Call Id=3
Aug 11 10:11:19.003: //3/1BB5B51F8007/CCAPI/ccCallReportDigits:
   (callID=0x3, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=3
Aug 11 10:11:19.003: //3/1BB5B51F8007/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x3F359E20, callID=0x3, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x3F359E20, Call Id=3
Aug 11 10:11:19.003: //3/1BB5B51F8007/CCAPI/ccCallDigit:
   Digit Tone Mode=DTMF, Call Id=3
Aug 11 10:11:19.003: //3/1BB5B51F8007/CCAPI/ccCallModify:
   Nominator=0x1001, Params=0x22D27BB0, Call Id=3
Aug 11 10:11:19.003: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x3ECCCD74, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
Aug 11 10:11:19.003: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 11 10:11:19.003: :cc_get_feature_vsa malloc success
Aug 11 10:11:19.003:  cc_get_feature_vsa count is 2
Aug 11 10:11:19.003: :FEATURE_VSA attributes are: feature_name:0,feature_time:553749848,feature_id:4
Aug 11 10:11:19.003: //4/1BB5B51F8007/CCAPI/ccIFCallSetupRequestPrivate:
Aug 11 10:11:19.003: //4/1BB5B51F8007/CCAPI/ccCallSetContext:
   Context=0x3E5F5980
Aug 11 10:11:19.003: //3/1BB5B51F8007/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x3F359E20, Call Id=3
Aug 11 10:11:19.003: //4/1BB5B51F8007/CCAPI/cc_api_call_connected:
   Connection Handle=0
Aug 11 10:11:19.003: //4/1BB5B51F8007/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID1=0x4, gcid=0-0-0-0, tag=0x0)
Aug 11 10:11:19.003: //3/1BB5B51F8007/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID2=0x3, gcid=1BB5B51F-3F4811E5-8007B723-2A15C5E4, tag=0x0)
   Conference Id=0xFFFFFFFF, Call Id1=4, Call Id2=3, Tag=0x0
Aug 11 10:11:19.003: //4/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
Aug 11 10:11:19.003: call_info mainst_callID:0x4, peer_callID:0x3, confID:0x2, spi_type:6, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
Aug 11 10:11:19.003:   stream[0]: callid:0x4, media_passthrough:0
Aug 11 10:11:19.003: //4/1BB5B51F8007/CCAPI/cc_api_bridge_done:
   Conference Id=0x2, Source Interface=0x3ECCCD74, Source Call Id=4,
   Destination Call Id=3, Disposition=0x0, Tag=0x0
Aug 11 10:11:19.003: //3/1BB5B51F8007/CCAPI/cc_api_bridge_done:
   Conference Id=0x2, Source Interface=0x3F359E20, Source Call Id=3,
   Destination Call Id=4, Disposition=0x0, Tag=0xFFFFFFFF
Aug 11 10:11:19.003: //4/1BB5B51F8007/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x2, Destination Call Id=3)
   Call Entry(Conference Id=0x2, Destination Call Id=4)
Aug 11 10:11:19.007: //4/1BB5B51F8007/CCAPI/ccConferenceCreate:
Aug 11 10:11:19.007: confID:0x2; callEntry1 callID1:0x4, type:9; callEntry2 callID2:0x3, type:6
Aug 11 10:11:19.007: //3/1BB5B51F8007/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3ECCCD74, Destination Call Id=4, Source Call Id=3,
Aug 11 10:11:19.007: //4/1BB5B51F8007/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3F359E20, Destination Call Id=3, Source Call Id=4,
Aug 11 10:11:19.007: //4/1BB5B51F8007/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=8210)
Aug 11 10:11:19.007: //3/1BB5B51F8007/CCAPI/cc_api_caps_ack:
Aug 11 10:11:19.007: //4/1BB5B51F8007/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2, Call Id1=4, Call Id2=3
Aug 11 10:11:19.007: //3/1BB5B51F8007/CCAPI/cc_api_voice_mode_event:
   Call Id=3
Aug 11 10:11:19.043: //3/1BB5B51F8007/CCAPI/ccCallModifyExtended:
   Nominator=0x22D26F20, Params=0x22D27330, Call Id=3
Aug 11 10:11:19.043: //4/1BB5B51F8007/CCAPI/ccCallModify:
   Nominator=0x18E30, Params=0x22D27908, Call Id=4
Aug 11 10:11:19.043: //3/1BB5B51F8007/CCAPI/cc_api_call_modify_done:
Aug 11 10:11:19.043: //4/1BB5B51F8007/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x3ECCCD74, Call Id=4
Aug 11 10:11:19.043: //4/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
Aug 11 10:11:19.043: call_info mainst_callID:0x4, peer_callID:0x3, confID:0x2, spi_type:6, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
Aug 11 10:11:19.043:   stream[0]: callid:0x4, media_passthrough:0
Aug 11 10:11:23.003: //3/1BB5B51F8007/CCAPI/cc_handle_inter_digit_timer:
Aug 11 10:11:28.351: //3/1BB5B51F8007/CCAPI/ccCallModifyExtended:
Aug 11 10:11:28.351: //4/1BB5B51F8007/CCAPI/ccCallModify:
   Nominator=0x800, Params=0x22D27908, Call Id=4
Aug 11 10:11:28.351: //3/1BB5B51F8007/CCAPI/cc_api_call_modify_done:
Aug 11 10:11:28.355: //4/1BB5B51F8007/CCAPI/cc_api_call_modify_done:
Aug 11 10:11:28.355: //4/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
Aug 11 10:11:28.355: call_info mainst_callID:0x4, peer_callID:0x3, confID:0x2, spi_type:6, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
Aug 11 10:11:28.355:   stream[0]: callid:0x4, media_passthrough:0
Aug 11 10:11:28.379: //3/1BB5B51F8007/CCAPI/ccCallReportDigits:
   (callID=0x3, digit_event=0x0, enable=FALSE, consume=FALSE)
Aug 11 10:11:28.379: //3/1BB5B51F8007/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x3F359E20, callID=0x3, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Aug 11 10:11:28.379: //3/1BB5B51F8007/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=3
Aug 11 10:11:31.083: //3/1BB5B51F8007/CCAPI/cc_api_call_disconnected:
   Cause Value=0, Interface=0x3F359E20, Call Id=3
Aug 11 10:11:31.083: //3/1BB5B51F8007/CCAPI/ccGenerateToneInfo:
Aug 11 10:11:31.083: //4/1BB5B51F8007/CCAPI/ccGetCallStatistics:
   Call Stats=0x3FA55488, Call Id=4
Aug 11 10:11:31.083: //4/1BB5B51F8007/CCAPI/ccConferenceDestroy:
   Conference Id=0x2, Tag=0x0
Aug 11 10:11:31.083: confID:0x2; callEntry1 callID1:0x4, type:9; callEntry2 callID2:0x3, type:6
Aug 11 10:11:31.083: //4/1BB5B51F8007/CCAPI/cc_api_bridge_drop_done:
Aug 11 10:11:31.083: //3/1BB5B51F8007/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=4, Disposition=0x0, Tag=0x0
Aug 11 10:11:31.083: //4/1BB5B51F8007/CCAPI/cc_generic_bridge_done:
Aug 11 10:11:31.083: //3/1BB5B51F8007/CCAPI/ccCallDisconnect:
Aug 11 10:11:31.083: //3/1BB5B51F8007/CCAPI/cc_api_get_transfer_info:
Aug 11 10:11:31.083: //4/1BB5B51F8007/CCAPI/ccCallDisconnect:
Aug 11 10:11:31.087: //4/1BB5B51F8007/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3ECCCD74, Tag=0x0, Call Id=4,
Aug 11 10:11:31.087: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug 11 10:11:31.087: :cc_free_feature_vsa freeing 21018D50
Aug 11 10:11:31.087:  vsacount in free is 1
Aug 11 10:11:31.111: //3/1BB5B51F8007/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3F359E20, Tag=0x0, Call Id=3,
Aug 11 10:11:31.111: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug 11 10:11:31.111: :cc_free_feature_vsa freeing 21018E30
Aug 11 10:11:31.111:  vsacount in free is 0
I was confused earlier regarding this end point. So I guess its a analog endpoint registered as mgcp configured on port 0/0/0. So when u dial this DN 1010 internally the CUCM sends the call to the Gateway and it is matching the dial peer 99900990 which is right. But for some reason its unable to find the DN 1010. Can you add the command destination pattern 1010 like this way to the dial peer 99900990  .
 service mgcpapp
 port 0/0/0
