06-20-2012 02:43 PM - edited 03-16-2019 11:46 AM
Hi, may i change the ntp server or add a new one in Business Ed. 6000 on C200 server (publisher server) running on Vmwrae Esxi without the need of rehosting the licenses?. I read that if i change the timezone i need to rehost the license file but nothing about ntp.
Thank you.
Solved! Go to Solution.
06-20-2012 03:01 PM
You have a 30 day grace period for anything that changes the License MAC before anything happens to the server, even if it changes, it's more than enough time to reach licensing and have them rehost them.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
06-20-2012 02:45 PM
Yes you will have to rehost the license if you change the NTP server.
06-20-2012 02:53 PM
Thank you, my i add a secondary ntp server without rehosting?
06-20-2012 02:56 PM
I am not positive but I believe any time you edit any NTP settings, even adding a secondary, you will need to rehost the file.
06-20-2012 03:01 PM
java
