Highlighted
Frequent Contributor
NTP server unreachable
I have the following weird issue with NTP. When I check with the command "utils ntp status" I get the information that clock is Synchronized:
admin:utils ntp status
ntpd (pid 6811) is running...
     remote           refid      st t when poll reach   delay   offset  jitter
+193.239.214.227 145.238.203.10   3 u  153  256  377   35.319   -1.920   0.647
*178.239.61.38   193.67.79.202    2 u  202  256  377   61.296   -2.136   0.574
synchronised to NTP server (178.239.61.38) at stratum 3
   time correct to within 122 ms
   polling server every 256 s
But in the CUCM GUI I see "WARNING: NTP server unreachable
In the OS administration I see:
1.gr.pool.ntp.org    The NTP server could not be contacted.
1.europe.pool.ntp.org    The NTP server could not be contacted.
When I use IP addresses instead of names, everything is OK
Any idea?
Bye
11 REPLIES 11
Highlighted
Please note NTP does not go unsynchronized straightaway, it takes time hence the output you are getting on OS Admin is valid. BTW, if the IP address is working fine then why are you choosing FQDN. Also, it is not recommended to use free NTP source available on the internet. You should be using a dedicated IOS based NTP source within your internal network itself for the UC applications.
Deepak
Highlighted
Hello Deepak,
Normally with an installation I use an IOS box to sync to an NTP resource in the Internet, and the CUCM Publisher uses this IOS box as it's NTP resource
Just find it weird that when the NTP (on CUCM) is configured with IP (External or Internal) the GUI and the CLI tell me that all is OK, but when I configure an FQDN, the CLI says all is OK, but the GUI says unreachable.
Just curious why this is, doesn't make sense!
Jan
Highlighted
Hi Jan,
I have the same behavior with internal NTP servers. I configured the server with FQDN via CLI - status shows fine on CLI. In GUI it says "The NTP server could not be contacted." Did you find a solution for this?
Thank you,
Andreas
Highlighted
nope, just use IP's
Bye
Highlighted
I have same issue, could you please tell me which CUCM version did you use ?
Tnx
Highlighted
I have seen this issue in CUCM 10.5.2. I restarted the NTP service to fix this issue. Run the command 'utils ntp restart' from the cli.
Highlighted
Beginner
Highlighted
Restarting NTP did not work for me.
- CUCM/CUC 12.0 & UCCX 11.6 are all experiencing this.
- Same symptoms as others where CLI shows sync with utils ntp status, but CLI and GUI state "NTP server unreachable" when you login.
- Configuration is pool.ntp.org & time.nist.gov which I realize is abnormal and I should be using an IOS router but that's not an option quite yet.
- utils ntp server add x.x.x.x results in "Inaccessible NTP server. Not added."
Highlighted
I can confirm that this is occurring in UCCX 11.6 and restarting NTP is not resolving the issue.  Anyone else have anything to add on this "cosmetic" bug or could this actually be an issue?
VMware Installation:
        2 vCPU: Intel(R) Xeon(R) CPU E5-2630 v3 @ 2.40GHz
        Disk 1: 146GB, Partitions aligned
        10240 Mbytes RAM
ntpd (pid 1828) is running...
*66.135.44.92    216.218.254.202  2 u   15   64   17   47.023    1.701   0.387
synchronised to NTP server (66.135.44.92) at stratum 3
   time correct to within 1020 ms
   polling server every 64 s
Current time in UTC is : Thu May 31 16:28:45 UTC 2018
Current time in America/New_York is : Thu May 31 12:28:45 EDT 2018
Highlighted
Hi there
You can run utils diagnose test command on CUCM CLI and see the ntp tests are passed. If yes, I dont think you have something to worry about.
test - ntp_reachability
test - ntp_clock_drift
test - ntp_stratum
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
Highlighted
Content for Community-Ad
