339
Highlighted
Participant
Number of Srst References in centralized call processing
I just want how many SRST References Can I add to one cucm (Centralized call processing) and in multisite deployments as I can't find these information in SRND
2 ACCEPTED SOLUTIONS
Highlighted
Re: Number of Srst References in centralized call processing
Hello Ahmed,
I think it should be same as how many gateways you can add in a cluster.
Because you will configure the SRST config on gateway/routers only and it should be same in numbers as your gateways.
Please rate the answer if it is helpful....
Highlighted
VIP Rising star
There is no limit defined as per the documentation on Number of SRST Reference OR number of Device Pools. Only Limitation I can see is Location and Region and Gateway. So Theoretically speaking no limit is defined. As Region Location Device Pool and SRST Reference are all tied we can take those values as reference.
SRND Says
"Configuration of regions and locations in the Unified CM cluster requires both database and static
memory. The number of gateways that can be defined in the cluster is also tied to the number of locations
that can be defined "
5 REPLIES 5
Highlighted
Hello Ahmed,
Highlighted
Participant
Thanks very much @Anurag Srivastava
Highlighted
Participant
I find this document
The centralized design consists of a headquarters site and up to 49 remote sites.
Can you explain this please ?
Is it mean that remote site = SRST Reference ?
Highlighted
Hello Ahmed,
I think this guide is specific to BE6000 server and explain what you can support using this server.
But in general no limit is mentioned in SRND.
Please rate if it is helpful...
Highlighted
VIP Rising star
SRND Says
