Cisco Community Designated VIP Class of 2020
213
Participant
Number Referral
How do I configure a Number Referral for a number?  I want callers to hear message saying 'this number has been changed to new number'. CUCM 10.5
1 ACCEPTED SOLUTION
VIP Advisor
Re: Number Referral
Yes, a DN set to forward to voicemail is needed, but the CTI RP is optional. Most people do it because it makes them feel better, but it's really unnecessary. :) To each, their own.
In order to get a lot of numbers in, without a lot of configuration, you could use wild card DNs in CUCM. Say for example my range was 1000 - 1999. I would create a DN like 1XXX and for that to voicemail. Then as I use the numbers, like 1000, 1001, etc. CUCM will route the call to the phones (or whatever destination it is), because the pattern is more specific.
Anthony Holloway
If you found this post helpful, please consider clicking that helpful button!
And for a limited time, by marking helpful posts, you're also helping Doctors Without Borders
4 REPLIES 4
Highlighted
VIP Advisor
Re: Number Referral
You would not be able to do this in CUCM alone. Do you have CUC? If so, you could send the DN to CUC so that you can play a message from there. Likely, you'll want to do this with a System Call Handler.
Anthony Holloway
Participant
Re: Number Referral
Thanks for your prompt reply Anthony...
yes we do have CUC. so from CM create CTI RP and send it to Call Handler? If this true, do I need to do these steps for every num referral?
VIP Advisor
Re: Number Referral
Anthony Holloway
Participant
Re: Number Referral
great...I will give it a try. Thanks for your help
Content for Community-Ad
FusionCharts will render here
