%NVRAM-3-EEPROM_WRITE_FAILED: Read back after write failed
masroor-ali
I have 2900 router, when I type wr, it gives the below error
keithknowles
Sound like a hardware issue. Firstly DON'T REBOOT THE ROUTER. Copy the running configuration and the startup configuration to files and compare them. If they are identical you can try a power cycle of the router. If the error persists after a power cycle then you will need to have Cisco look at the hardware.
waqas0612147
Its a definative Hardware issue ..you need to contact TAC and replace the router
