Odd issue - dialing a site in China
Zane May
We have a site in China that if you try to place a call +86... it will be cancelled after the 9th digit even though there are 4 more digits to dial. The numbers are being dialed without a pause so i don't think it is inter-digit timing related. If you dial all 13 digits ahead of time (edit dial?) then press dial the call will go through. I know this post is short on details but any ideas? We are on CUCM 10.5
Jaime Valencia
Sounds like overlapping in your dial plan, and something has the reject call option, use DNA to find out what you're matching
java
if this helps, please rate
Jaime Valencia
java
George Sotiropoulos
Go to your CUCM Admin Page then Cisco Unified Serviceability->Tools->Dialed Number Analyzer->Analysis->Analyzer and try to "simulate" the call to understand if there is an overlapping on your Route Patterns.
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
