Well, if the 2 networks are not integrated and if there is no routing between them VPN is your only option, I would look into phone VPN feature if I was you, where you basically provision the phone with built in VPN client and point to your ASA.
For more details you can check out Cisco documentation or search this forum for it as this has been asked many times.
HTH,
Chris
