Old CME 2851 is not going to voice mail when calls are not answered
luisperez55181
I am a CCNA with not a whole lot of experience or knowledge of cisco voice, the thing I was dragged into this thing.
This CME2851 apparently the customer says everything was working fine and now all of a sudden the system does not goes to voicemail when calls are not answered. I think somebody messed with this config but no one is saying anything.
I am posting the full config for the kind experts out there to take a look and tell me if they see something wrong or missing in this config as I have spent a great part of the day and cannot  make sense of why is not working. By the way, when I call and nobody answers the line just goes dead.
Current configuration : 83659 bytes
! Last configuration change at 10:30:43 est Tue Nov 8 2016 by admin
! NVRAM config last updated at 00:23:23 est Fri Nov 11 2016
version 12.4
service timestamps debug uptime
service timestamps log datetime localtime
service sequence-numbers
hostname CME2851
boot-start-marker
boot system flash:c2800nm-adventerprisek9-mz.124-11.XW10.bin
boot-end-marker
logging buffered 10000000
no logging console
enable secret 5 $1$r8gc$lMq16i7Ssxg.HxK8Cwozt.
enable password lockemup1042
aaa new-model
aaa authentication login default local
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa authentication login sdm_vpn_xauth_ml_2 local
aaa authorization exec default local
aaa authorization network sdm_vpn_group_ml_1 local
aaa authorization network sdm_vpn_group_ml_2 local
aaa session-id common
clock timezone est -5
clock summer-time EDT recurring
network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp excluded-address 10.10.10.200 10.10.10.253
ip dhcp excluded-address 192.168.1.1 192.168.1.100
ip dhcp excluded-address 10.10.10.46 10.10.10.47
ip dhcp excluded-address 10.10.10.1 10.10.10.50
ip dhcp pool phone
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
option 150 ip 10.10.10.1
dns-server 75.75.75.75 75.75.75.76 4.2.2.2
ip dhcp pool data
network 192.168.10.0 255.255.255.0
default-router 192.168.10.2
dns-server 192.168.10.2 4.2.2.2
ip dhcp pool Crestron
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 64.89.70.2 64.89.74.2
no ip domain lookup
ip domain name yourdomain.com
ip name-server 64.89.70.2
ip name-server 64.89.74.2
isdn switch-type primary-5ess
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
h323
sip
registrar server expires max 3600 min 600
voice class codec 1
codec preference 1 g711ulaw
voice register global
mode cme
source-address 10.10.10.1 port 5060
max-dn 5
max-pool 5
authenticate realm cisco.com
create profile sync 0420545391215175
voice translation-rule 1
rule 1 // /9/
voice translation-rule 5
rule 1 /.*/ /5614557500\1/
rule 2 reject /2000000/
voice translation-profile Redial
translate calling 1
voice translation-profile outboundCLID
translate calling 5
voice-card 0
no dspfarm
crypto pki trustpoint TP-self-signed-1349081427
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1349081427
revocation-check none
rsakeypair TP-self-signed-1349081427
crypto pki certificate chain TP-self-signed-1349081427
certificate self-signed 01
3082024E 308201B7 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31333439 30383134 3237301E 170D3039 30373036 30323536
34305A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 33343930
38313432 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100F185 2B6DB5D5 2795C68C C55D9611 77927EBE 0EC31607 B3C589B2 16A5F7FD
8B07B348 62863DE8 B3F13C2F 5353A5C4 7BFF7414 D7E24BF2 63E8F6B0 F731ACA0
CCE04D96 9C3869B9 CAD2BE66 1EAF8887 7C6FBDC1 ACBE2405 1119F044 A5FC2A5D
D7A52F33 A2000D35 FD136195 ED144541 2EEF6C71 3E0E406F 8656368A 3698F29D
7F2B0203 010001A3 76307430 0F060355 1D130101 FF040530 030101FF 30210603
551D1104 1A301882 16434D45 32383531 2E796F75 72646F6D 61696E2E 636F6D30
1F060355 1D230418 30168014 AB435D8D 66F0DF21 47395774 A3350224 5C67C92A
301D0603 551D0E04 160414AB 435D8D66 F0DF2147 395774A3 3502245C 67C92A30
0D06092A 864886F7 0D010104 05000381 8100EB9B A3FD217E 44960546 092906ED
04C72FF8 32841A40 20BECEA1 D27D9587 1A32EBDF AA8854AC 80FA1598 530DE0F4
CD7A0011 9495929F 21BB8D91 C74254E4 D2ADBB1F 7C277947 A7A59414 CBFDA8A7
57DD33B8 CE6553EA CA80BEA7 18BD36EC 9087717D 5D26EF6C D0DE7694 DFB8BEBB
3D4852D1 2AB8B322 1B830219 6DCF372F 417E
quit
crypto isakmp policy 10
hash md5
authentication pre-share
group 2
crypto isakmp key lockemup1042 address 38.105.10.130 no-xauth
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes 192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes 192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes 256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes 256 esp-md5-hmac
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto map mymap 1 ipsec-isakmp
set peer 38.105.10.130
set transform-set myset
match address 102
username admin privilege 15 secret 5 $1$yg9z$2PS.Hh.QD3OOp36GU5DBq0
username rremesar privilege 15 secret 5 $1$8ZiA$jwxv25ZsS8vkRYUZI4hPy1
archive
log config
hidekeys
controller T1 0/0/0
framing esf
linecode b8zs
pri-group timeslots 1-4,24
ip ssh version 2
ip rcmd rcp-enable
class-map match-all L3-to-L2_VoIP-Cntrl
match ip dscp af31
class-map match-all L3-to-L2_VoIP-RTP
match ip dscp ef
class-map match-all SIP
match protocol sip
class-map match-all RTP
match protocol rtp
policy-map EthOut
class RTP
policy-map output-L3-to-L2
class L3-to-L2_VoIP-RTP
set cos 5
class L3-to-L2_VoIP-Cntrl
set cos 3
interface Loopback0
ip address 10.1.10.2 255.255.255.0
interface Loopback1
ip address 1.1.1.1 255.255.255.252
interface Loopback2
no ip address
interface Loopback5
no ip address
interface Loopback176
ip address 172.16.1.1 255.255.255.252
interface GigabitEthernet0/0
description ** assign static IP address to the interface **$ETH-WAN$$FW_OUTSIDE$
ip address 70.43.176.195 255.255.255.240
ip access-group 100 in
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no mop enabled
crypto map mymap
interface Service-Engine0/0
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.0
service-module ip default-gateway 10.1.10.2
interface GigabitEthernet0/1
no ip address
no ip mroute-cache
duplex auto
speed auto
interface GigabitEthernet0/1.100
description ** Voice VLAN **$ETH-LAN$$FW_INSIDE$
encapsulation dot1Q 100 native
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip policy route-map nonat-vpn
interface GigabitEthernet0/1.200
description ** Data VLAN **$ETH-LAN$$FW_INSIDE$
encapsulation dot1Q 200
ip address 192.168.10.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1350
interface GigabitEthernet0/1.300
description ** Crestron VLAN **$ETH-LAN$$FW_INSIDE$
encapsulation dot1Q 300
ip nat inside
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn map address .* plan unknown type unknown
no cdp enable
interface Virtual-Template5 type tunnel
no ip address
tunnel mode ipsec ipv4
ip route 0.0.0.0 0.0.0.0 172.168.1.1 2
ip route 0.0.0.0 0.0.0.0 70.43.176.193 2
ip route 10.1.10.1 255.255.255.255 Service-Engine0/0
ip http server
ip http authentication local
ip http secure-server
ip http path flash:
ip dns name-list 1 permit SHOPLIVE.COM
ip dns name-list 2 permit SHOPLIVE.COM
ip dns name-list 3 permit SHOPLIVE.COM
ip dns name-list 4 permit SHOPLIVE.COM
ip dns name-list 5 permit SHOPLIVE.COM
ip dns name-list 6 permit SHOPLIVE.COM
ip dns name-list 7 permit SHOPLIVE.COM
ip dns name-list 8 permit SHOPLIVE.COM
ip dns name-list 9 permit SHOPLIVE.COM
ip dns name-list 10 permit SHOPLIVE.COM
ip dns name-list 11 permit SHOPLIVE.COM
ip dns name-list 12 permit SHOPLIVE.COM
ip nat pool outside 70.43.176.196 70.43.176.207 netmask 255.255.255.0
ip nat inside source list 109 interface GigabitEthernet0/0 overload
ip nat inside source static 10.1.10.1 70.43.176.195
logging trap debugging
logging 10.10.10.101
logging 74.223.84.144
access-list 1 remark SDM_ACL Category=18
access-list 1 permit any
access-list 2 remark SDM_ACL Category=2
access-list 2 permit 10.10.10.0 0.0.0.255
access-list 23 permit 0.0.0.0
access-list 23 permit 65.207.163.111
access-list 23 permit 69.172.190.26
access-list 23 permit 74.223.84.144
access-list 23 remark SDM_ACL Category=17
access-list 23 permit 171.68.225.213
access-list 23 permit 10.0.0.0 0.255.255.255
access-list 23 permit 0.0.0.195 255.255.255.0
access-list 23 permit 0.1.10.3 255.0.0.0
access-list 23 permit 0.0.0.0 255.255.255.0
access-list 23 permit 0.0.0.196 255.255.255.0
access-list 23 permit any
access-list 23 permit 0.0.0.10 255.255.255.0
access-list 23 permit 0.0.0.200 255.255.255.0
access-list 23 permit 0.0.0.111 255.255.255.0
access-list 100 deny udp any any eq 1720 log
access-list 100 deny tcp any any eq 1720 log
access-list 100 deny udp any any eq 5060 log
access-list 100 deny tcp any any eq 5060 log
access-list 100 permit ip any any
access-list 101 remark SDM_ACL Category=2
access-list 101 deny ip host 10.1.10.1 host 192.168.2.20
access-list 101 deny ip host 10.1.10.1 host 192.168.2.19
access-list 101 deny ip host 10.1.10.1 host 192.168.2.18
access-list 101 deny ip host 10.1.10.1 host 192.168.2.17
access-list 101 deny ip host 10.1.10.1 host 192.168.2.16
access-list 101 deny ip host 10.1.10.1 host 192.168.2.15
access-list 101 deny ip host 10.1.10.1 host 192.168.2.14
access-list 101 deny ip host 10.1.10.1 host 192.168.2.13
access-list 101 deny ip host 10.1.10.1 host 192.168.2.12
access-list 101 deny ip host 10.1.10.1 host 192.168.2.11
access-list 101 deny ip host 10.1.10.1 host 192.168.2.10
access-list 101 deny ip host 10.1.10.1 host 192.168.2.9
access-list 101 deny ip host 10.1.10.1 host 192.168.2.8
access-list 101 deny ip host 10.1.10.1 host 192.168.2.7
access-list 101 deny ip host 10.1.10.1 host 192.168.2.6
access-list 101 deny ip host 10.1.10.1 host 192.168.2.5
access-list 101 deny ip host 10.1.10.1 host 192.168.2.4
access-list 101 deny ip host 10.1.10.1 host 192.168.2.3
access-list 101 permit ip host 10.1.10.1 any
access-list 102 permit ip 10.10.10.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 102 permit ip 192.168.10.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 102 permit ip 10.10.10.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 102 permit ip 192.168.10.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 102 permit ip 192.168.0.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 103 remark SDM_ACL Category=4
access-list 103 remark IPSec Rule
access-list 103 permit ip 10.10.10.0 0.0.0.255 192.0.0.0 0.0.0.255
access-list 109 deny ip 192.168.10.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 109 deny ip 10.10.10.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 109 deny ip 10.10.10.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 109 deny ip 192.168.10.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 109 permit ip 10.10.10.0 0.0.0.255 any
access-list 109 permit ip 192.168.10.0 0.0.0.255 any
access-list 109 permit ip 192.168.1.0 0.0.0.255 any
access-list 115 permit ip 10.10.10.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 115 permit ip 192.168.10.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 115 permit ip 10.10.10.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 115 permit ip 192.168.10.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 125 permit ip 0.0.0.0 255.255.255.0 0.0.0.0 255.255.255.0
access-list 190 permit ip 10.10.10.0 0.0.0.255 any
access-list 190 permit ip 192.168.10.0 0.0.0.255 any
access-list 190 permit ip 192.168.1.0 0.0.0.255 any
access-list 191 permit udp any any eq ntp
route-map nonat-vpn permit 10
match ip address 115
set ip next-hop 1.1.1.2
tftp-server flash:TERM70.7-0-3-0S.loads
tftp-server flash:term70.default.loads
tftp-server flash:term71.default.loads
tftp-server flash:CVM70.2-0-2-26.sbn
tftp-server flash:cnu70.2-7-6-26.sbn
tftp-server flash:Jar70.2-9-2-26.sbn
tftp-server flash:P0030702T023.loads
tftp-server flash:P0030702T023.sb2
tftp-server flash:P0030702T023.sbn
tftp-server flash:P0030702T023.bin
tftp-server flash:P00307020300.bin
tftp-server flash:cmterm_7920.4.0-02-00.bin
tftp-server flash:List.xml
tftp-server flash:TN-CampusNight.png
tftp-server flash:campusnight.png
tftp-server flash:music-on-hold.au
tftp-server flash:/c2500-js-l.122-10b
tftp-server flash:analog1.raw
tftp-server flash:Ringlist.xml
tftp-server flash:Bass.raw
tftp-server flash:Jamaica.raw
tftp-server flash:Sax1.raw
tftp-server flash:Pop.raw
tftp-server flash:apps70.8-2-2ES6.sbn
tftp-server flash:cnu70.8-2-2ES6.sbn
tftp-server flash:cvm70sccp.8-2-2ES6.sbn
tftp-server flash:dsp70.8-2-2ES6.sbn
tftp-server flash:jar70sccp.8-2-2ES6.sbn
tftp-server flash:SCCP70.8-2-2SR4S.loads
tftp-server flash:P00308000500.bin
tftp-server flash:P00308000500.loads
tftp-server flash:P00308000500.sb2
tftp-server flash:P00308000500.sbn
tftp-server flash:P00308000500..loads
tftp-server flash:/CP7921G-1.0.3/CP7921G-1.0.3.LOADS alias CP7921G-1.0.3.LOADS
tftp-server flash:CP7921G-1.0.3/CP7921G-1.0.3.LOADS
tftp-server flash:CP7921G-1.0.3.loads
tftp-server flash:Apps-1.0.3.sbn
tftp-server flash:Gui-1.0.3.sbn
tftp-server flash:Sys-1.0.3.sbn
tftp-server flash:Tnux-1.0.3.sbn
tftp-server flash:Tnuxr-1.0.3.sbn
tftp-server flash:Wlan-1.0.3.sbn
tftp-server flash:/phone/cmterm_7936.3-3-13-0.bin alias cmterm_7936.3-3-13-0.bin
tftp-server flash:/phone/P00308000500.bin alias P00308000500.bin
tftp-server flash:/phone/P00308000500.loads alias P00308000500.loads
tftp-server flash:/phone/P00308000500.sb2 alias P00308000500.sb2
tftp-server flash:/phone/P00308000500.sbn alias P00308000500.sbn
tftp-server flash:/phone/apps41.8-2-2TR2.sbn alias apps41.8-2-2TR2.sbn
tftp-server flash:/phone/cnu41.8-2-2TR2.sbn alias cnu41.8-2-2TR2.sbn
tftp-server flash:/phone/cvm41sccp.8-2-2TR2.sbn alias cvm41sccp.8-2-2TR2.sbn
tftp-server flash:/phone/dsp41.8-2-2TR2.sbn alias dsp41.8-2-2TR2.sbn
tftp-server flash:/phone/jar41sccp.8-2-2TR2.sbn alias jar41sccp.8-2-2TR2.sbn
tftp-server flash:/phone/SCCP41.8-2-2SR2S.loads alias SCCP41.8-2-2SR2S.loads
tftp-server flash:/phone/term41.default.loads alias term41.default.loads
tftp-server flash:/phone/term61.default.loads alias term61.default.loads
tftp-server flash:/phone/apps11.8-2-2TR2.sbn alias apps11.8-2-2TR2.sbn
tftp-server flash:/phone/cnu11.8-2-2TR2.sbn alias cnu11.8-2-2TR2.sbn
tftp-server flash:/phone/cvm11sccp.8-2-2TR2.sbn alias cvm11sccp.8-2-2TR2.sbn
tftp-server flash:/Cp7921g-1.0.3.loads
tftp-server flash:/P00308000500.loads
tftp-server flash:/CP7921G-1.0.3/APPS-1.0.3.SBN alias APPS-1.0.3.SBN
tftp-server flash:/CP7921G-1.0.3/GUI-1.0.3.SBN alias GUI-1.0.3.SBN
tftp-server flash:/CP7921G-1.0.3/SYS-1.0.3.SBN alias SYS-1.0.3.SBN
tftp-server flash:/CP7921G-1.0.3/TNUX-1.0.3.SBN alias TNUX-1.0.3.SBN
tftp-server flash:/CP7921G-1.0.3/TNUXR-1.0.3.SBN alias TNUXR-1.0.3.SBN
tftp-server flash:/CP7921G-1.0.3/WLAN-1.0.3.SBN alias WLAN-1.0.3.SBN
tftp-server flash:/phone/cmterm_7920.4.0-03-02.bin alias cmterm_7920.4.0-03-02.bin
tftp-server flash:/phone/apps31.8-2-2TR2.sbn alias apps31.8-2-2TR2.sbn
tftp-server flash:/phone/S00105000200.sbn alias S00105000200.sbn
tftp-server flash:/phone/apps70.8-2-2TR2.sbn alias apps70.8-2-2TR2.sbn
tftp-server flash:/phone/CP7905080002SCCP060817A.sbin alias CP7905080002SCCP060817A.sbin
tftp-server flash:/phone/cmterm_7985.4-1-2-0.bin alias cmterm_7985.4-1-2-0.bin
tftp-server flash:/phone/CP7902080002SCCP060817A.sbin alias CP7902080002SCCP060817A.sbin
tftp-server flash:/phone/CP7912080002SCCP060817A.sbin alias CP7912080002SCCP060817A.sbin
tftp-server flash:/phone/P00405000700.bin alias P00405000700.bin
tftp-server flash:/phone/cnu31.8-2-2TR2.sbn alias cnu31.8-2-2TR2.sbn
tftp-server flash:/phone/P00503021500.bin alias P00503021500.bin
tftp-server flash:/phone/dsp11.8-2-2TR2.sbn alias dsp11.8-2-2TR2.sbn
tftp-server flash:/phone/jar11sccp.8-2-2TR2.sbn alias jar11sccp.8-2-2TR2.sbn
tftp-server flash:/phone/SCCP11.8-2-2SR2S.loads alias SCCP11.8-2-2SR2S.loads
tftp-server flash:/phone/term06.default.loads alias term06.default.loads
tftp-server flash:/phone/term11.default.loads alias term11.default.loads
tftp-server flash:/phone/cvm31sccp.8-2-2TR2.sbn alias cvm31sccp.8-2-2TR2.sbn
tftp-server flash:/phone/dsp31.8-2-2TR2.sbn alias dsp31.8-2-2TR2.sbn
tftp-server flash:/phone/jar31sccp.8-2-2TR2.sbn alias jar31sccp.8-2-2TR2.sbn
tftp-server flash:/phone/SCCP31.8-2-2SR2S.loads alias SCCP31.8-2-2SR2S.loads
tftp-server flash:/phone/term31.default.loads alias term31.default.loads
tftp-server flash:/phone/cnu70.8-2-2TR2.sbn alias cnu70.8-2-2TR2.sbn
tftp-server flash:/phone/cvm70sccp.8-2-2TR2.sbn alias cvm70sccp.8-2-2TR2.sbn
tftp-server flash:/phone/dsp70.8-2-2TR2.sbn alias dsp70.8-2-2TR2.sbn
tftp-server flash:/phone/jar70sccp.8-2-2TR2.sbn alias jar70sccp.8-2-2TR2.sbn
tftp-server flash:/phone/SCCP70.8-2-2SR2S.loads alias SCCP70.8-2-2SR2S.loads
tftp-server flash:/phone/term70.default.loads alias term70.default.loads
tftp-server flash:/phone/term71.default.loads alias term71.default.load
tftp-server flash:/phone/CP7905080002SCCP060817A.zup alias CP7905080002SCCP060817A.zup
tftp-server flash:/phone/P00405000700.sbn alias P00405000700.sbn
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:Desktops/320x212x12/NantucketFlowers.png
tftp-server flash:Desktops/320x212x12/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x12/Fountain.png
tftp-server flash:Desktops/320x212x12/TN-Fountain.png
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x212x12/CampusNight.png
tftp-server flash:Desktops/320x212x12/TN-CampusNight.png
tftp-server flash:Desktops/320x212x12/CiscoFountain.png
tftp-server flash:Desktops/320x212x12/TN-CiscoFountain.png
tftp-server flash:Desktops/320x212x12/MorroRock.png
tftp-server flash:Desktops/320x212x12/TN-MorroRock.png
tftp-server flash:cnu70.62-2-0-19.sbn
tftp-server flash:Jar70.62-2-0-19.sbn
tftp-server flash:jvm70.602SR2R19.sbn
tftp-server flash:TERM70.6-0-2SR2-0s.loads
control-plane
voice-port 0/0/0:23
translation-profile outgoing outboundCLID
voice-port 0/1/0
connection plar 7500
station-id name Front Door
caller-id enable
voice-port 0/1/1
station-id name Back Door
caller-id enable
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
station-id name Service Gate
caller-id enable
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
station-id name Front Gate
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
dial-peer cor custom
name internal
name local
name domestic
name international
name 900
name 976
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-domestic
member domestic
dial-peer cor list call-international
member international
dial-peer cor list call-900
member 900
dial-peer cor list call-976
member 976
dial-peer cor list user-internal
member internal
dial-peer cor list user-local
member internal
member local
dial-peer cor list user-domestic
member internal
member local
member domestic
dial-peer cor list user-international
member internal
member local
member domestic
dial-peer cor list user900-internal
member internal
member 900
member 976
dial-peer cor list user900-local
member internal
member local
member 900
member 976
dial-peer cor list user900-domestic
member internal
member local
member domestic
member 900
member 976
dial-peer cor list user900-international
member internal
member local
member domestic
member 900
member 976
dial-peer voice 1 pots
description ** T1 PRI pots dial-peer **
destination-pattern 9911
direct-inward-dial
port 0/0/0:23
forward-digits 4
dial-peer voice 2 pots
corlist outgoing call-local
destination-pattern 9.T
port 0/0/0:23
dial-peer voice 3 pots
corlist outgoing call-domestic
destination-pattern 91T
port 0/0/0:23
dial-peer voice 4 pots
corlist outgoing call-international
destination-pattern 9011T
port 0/0/0:23
dial-peer voice 5 pots
corlist outgoing call-900
destination-pattern 91900.......
port 0/0/0:23
dial-peer voice 6 pots
corlist outgoing call-976
destination-pattern 91976.......
port 0/0/0:23
dial-peer voice 7 pots
incoming called-number .
direct-inward-dial
port 0/0/0:23
dial-peer voice 8 voip
description ** cue voicemail pilot number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 600
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 9 voip
description ** cue auto attendant number **
destination-pattern 601
codec g711ulaw
no vad
dial-peer voice 32 voip
codec g711ulaw
no vad
dial-peer voice 33 voip
codec g711ulaw
no vad
dial-peer voice 12 pots
description ** FXS pots dial-peer **
destination-pattern 7509
port 0/2/1
dial-peer voice 13 pots
destination-pattern 7201
port 0/2/2
dial-peer voice 14 pots
description ** FXO pots dial-peer **
destination-pattern 1900.......
dial-peer voice 15 pots
destination-pattern 1976.......
dial-peer voice 16 pots
destination-pattern 911
forward-digits 3
dial-peer voice 17 pots
destination-pattern .T
dial-peer voice 18 pots
destination-pattern 1.............
dial-peer voice 19 pots
destination-pattern 011T
dial-peer voice 20 pots
dial-peer voice 21 pots
dial-peer voice 22 pots
forward-digits 7
dial-peer voice 23 pots
dial-peer voice 24 pots
dial-peer voice 25 pots
dial-peer voice 27 pots
dial-peer voice 28 pots
forward-digits 7
dial-peer voice 29 pots
dial-peer voice 30 pots
dial-peer voice 31 pots
dial-peer voice 10 pots
forward-digits 7
dial-peer voice 11 pots
dial-peer voice 40 pots
translation-profile incoming Redial
direct-inward-dial
dial-peer voice 60 pots
destination-pattern 500
port 0/2/0
dial-peer voice 61 pots
destination-pattern 501
port 0/2/3
dial-peer voice 62 pots
port 0/1/0
dial-peer voice 63 voip
destination-pattern 41674
progress_ind setup enable 3
voice-class codec 1
session target ipv4:192.168.100.11
session transport udp
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 64 pots
destination-pattern 502
telephony-service
no auto-reg-ephone
load 7910 P00405000700
load 7935 P00503021500
load 7960-7940 P00308000500
load 7914 S00105000200
load 7905 CP7905080002SCCP060817A
load 7902 CP7902080002SCCP060817A
load 7921 CP7921G-1.0.3
load 7920 cmterm_7920.4.0-03-02
load 7931 SCCP31.8-2-2SR2S
load 7941 SCCP41.8-2-2SR2S
load 7961 SCCP41.8-2-2SR2S
load 7971 TERM70.7-0-3-0S
load 7970 TERM70.7-0-3-0S
load 7936 cmterm_7936.3-3-13-0
load 7985 cmterm_7985.4-1-2-0
load 7906 SCCP11.8-2-2SR2S
load 7911 SCCP11.8-2-2SR2S
load 7912 CP7912080002SCCP060817A
max-ephones 96
max-dn 192
ip source-address 10.10.10.1 port 2000
service phone daysDisplayNotActive ,
service phone displayOnTime 07:00
service phone displayOnDuration 15:00
service phone displayIdleTimeout 00:05
service phone videoCapability 1
timeouts interdigit 3
system message Pugliese Residence
time-zone 13
voicemail 600
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh music-on-hold.au
web admin system name admin secret 5 $1$CMk3$FQPva0sNm5WUGPuroFmKn/
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern .T
create cnf-files version-stamp 7960 Mar 31 2015 15:07:09
ephone-template 1
ephone-dn 1
number 101
label Page All Inside
name Page Inside
paging ip 239.1.1.1 port 2000
paging group 1,2,4
ephone-dn 2
number 102
label Page All Outside
name Page Outside
paging ip 239.1.1.2 port 2000
ephone-dn 3
number 103
label Page All
name Page All
paging ip 239.1.1.3 port 2000
paging group 1,2,4
ephone-dn 4
number 104
label Staff
name Staff
paging ip 239.1.1.4 port 2000
ephone-dn 5 dual-line
number 201
label 201
description User1 Name
name Main Number
call-forward busy 600
call-forward noan 600 timeout 10
corlist incoming user900-international
ephone-dn 6 dual-line
number 202 secondary 7508
label 202
description 455-7508
name Staff
ephone-dn 7 dual-line
number 203 secondary 7519
label 203
description User3 Name
name Staff
call-forward noan 600 timeout 15
ephone-dn 8 dual-line
number 204
label 204
description Main Foyer
name Main Foyer
ephone-dn 9 dual-line
number 206
label 206
description Club Room
name Club Room
ephone-dn 10 dual-line
number 207 secondary 7818
label 206
description Elevator
name Elevator
ephone-dn 11 dual-line
number 212
label 212
description AVP Closet
name AVP Closet
ephone-dn 12 dual-line
number 208
label 208
description Kitchen Bar
name Kitchen Bar
ephone-dn 13 dual-line
number 209
label 209
name Kitchen Bar
ephone-dn 14 dual-line
number 210
label 210
description Kitchen Desk
name Kitchen Desk
ephone-dn 15 dual-line
number 211
label 211
name Kitchen Desk
ephone-dn 16 dual-line
number 205
label 205
name Main Foyer
ephone-dn 17 dual-line
number 213 secondary 2725757
label 213
name AVP Closet
ephone-dn 18 dual-line
number 218
label 218
description Master Fireplace
name Master Fireplace
ephone-dn 19 dual-line
number 215
label 215
description Romans Bath
name Romans Bath
ephone-dn 20 dual-line
number 216 secondary 7507
label 216
description 455-7507
name Romans Room
ephone-dn 21 dual-line
number 217
label 217
description Romans Room
name Romans Room
ephone-dn 22 dual-line
number 214 secondary 7507
label 214
name Romans Bath
hold-alert 30 originator
ephone-dn 23 dual-line
number 219
label 219
ephone-dn 24 dual-line
number 220
label 220
description Laura's Bedroom
name Laura's Bedroom
ephone-dn 25 dual-line
number 221
label 221
ephone-dn 26 dual-line
number 222
label 222
description AVP Bedroom
name AVP Bedroom
ephone-dn 27 dual-line
number 223
label 223
description Mr P Bedroom
name AVP Bedroom
ephone-dn 28 dual-line
number 224
label 224
name Lauras Office
ephone-dn 29 dual-line
number 225
label 225
description Lauras Office
name Lauras Office
ephone-dn 30 dual-line
number 226
label 226
description Upstairs Laundry Rm
name Upstairs Laundry Rm
ephone-dn 31 dual-line
number 227
label 227
description Laura's Closet
ephone-dn 32 dual-line
number 228
label 228
description Romans Porch
name Romans Porch
ephone-dn 33 dual-line
number 229
label 229
name Romans Porch
ephone-dn 34 dual-line
number 230
label 230
description AVP Bath
name AVP Bath
call-forward all 600
ephone-dn 35 dual-line
number 231
label 231
description Mr P Bath
name AVP Bath
ephone-dn 36 dual-line
number 232
label 232
description Laura's Bath
name Laura's Bath
ephone-dn 37 dual-line
number 233
label 233
name Laura's Bath
ephone-dn 38 dual-line
number 234 secondary 7502
label 234
description 455-7502
name Room 2
ephone-dn 39 dual-line
number 235
label 235
description Room 2
name Room 2
ephone-dn 40 dual-line
number 236 secondary 7503
label 236
description 455-7503
name Room 3
ephone-dn 41 dual-line
number 237
label 237
description Room 3
name Room 3
ephone-dn 42 dual-line
number 238 secondary 7504
label 238
description 455-7504
name Room 4
ephone-dn 43 dual-line
number 239
label 239
description Room 4
name Room 4
ephone-dn 44 dual-line
number 240
label 240
description Gym
name Gym
ephone-dn 45 dual-line
number 241
label 241
description Gym
name Gym
ephone-dn 46 dual-line
number 242
label 242
description Family Room
name Family Room
ephone-dn 47 dual-line
number 243
label 243
name Family Room
ephone-dn 48 dual-line
number 244
label 244
description Powder Room
name Powder Room
ephone-dn 49 dual-line
number 245
label 245
name Powder Room
ephone-dn 50 dual-line
number 246
label 246
description Powder Room Bath
name Powder Room Bath
ephone-dn 51 dual-line
number 247
label 247
ephone-dn 52 dual-line
number 248 secondary 7501
label 248
description 455-7501
name Room 1
ephone-dn 53 dual-line
number 249
label 249
description Room 1
name Room 1
ephone-dn 54 dual-line
number 250 secondary 7505
label 250
description 455-7505
name Room 5
ephone-dn 55 dual-line
number 251
label 251
description Room 5
name Room 5
ephone-dn 56 dual-line
number 252 secondary 7505
label 252
description Bar
name Bar
ephone-dn 57 dual-line
number 253
label 253
description Bar
name Bar
ephone-dn 58 dual-line
number 254
label 254
description Game Room
name Game Room
ephone-dn 59 dual-line
number 255
label 255
name Game Room
ephone-dn 60 dual-line
number 256 secondary 7508
label 256
description Gun Range
name Gun Range
ephone-dn 61 dual-line
number 257
label 257
name Gun Range
ephone-dn 62 dual-line
number 258
label 258
description Wine Room
name Wine Room
ephone-dn 63 dual-line
number 259
label 259
name Wine Room
ephone-dn 64 dual-line
number 260 secondary 7200
label 260
description 455-7200
name AVP Office
ephone-dn 65 dual-line
number 261
label 261
description AVP Office
name AVP Office
ephone-dn 66 dual-line
number 262 secondary 7200
label 262
name AVP Office Desk
ephone-dn 67 dual-line
number 263
label 263
description AVP Office Desk
ephone-dn 68 dual-line
number 264
label 264
description AVP Office Sitting Area
name AVP Office Sitting Area
ephone-dn 69 dual-line
number 265
label 265
ephone-dn 70 dual-line
number 266
label 266
description Safe Room
name Safe Room
ephone-dn 71 dual-line
number 267
label 267
name Safe Room
ephone-dn 72 dual-line
number 268
label 268
description Cabana Laundry
name Cabana Laundry
ephone-dn 73 dual-line
number 269
label 269
description Cordless 1
name Cordless 1
ephone-dn 74 dual-line
number 270
label 270
name Cordless 1
ephone-dn 75
number 800...
mwi on
ephone-dn 76
number 801...
mwi off
ephone-dn 77
number 800...
mwi on
ephone-dn 78
number 801...
mwi off
ephone-dn 79
number 100
label Main Number
ephone-dn 80
number 7500
preference 1
call-forward noan 600 timeout 25
no huntstop
ephone-dn 81
number 7500
preference 2
no huntstop
ephone-dn 82
number 7500
preference 3
no huntstop
ephone-dn 83
number 7500
preference 4
no huntstop
ephone-dn 84
number 7500
preference 5
no huntstop
ephone-dn 85
number 7500
preference 6
no huntstop
ephone-dn 86
number 7500
preference 7
no huntstop
ephone-dn 87
number 7500
preference 8
no huntstop
ephone-dn 88
number 7500
preference 9
no huntstop
ephone-dn 89
number 7500
description Main Number
name Main Number
preference 10
ephone-dn 90 dual-line
number 271
label 271
description Cordless 2
name Cordless 2
ephone-dn 91 dual-line
number 272
label 272
name Cordless 2
ephone-dn 92 dual-line
number 273
label 273
description Cordless 3
name Cordless 3
ephone-dn 93 dual-line
number 274
label 274
name Cordless 3
ephone-dn 94 dual-line
number 275
label 275
description Cordless 4
name Cordless 4
ephone-dn 95 dual-line
number 276
label 276
name Cordless 4
ephone-dn 96 dual-line
number 277
label 277
description Cordless 5
name Cordless 5
ephone-dn 97 dual-line
number 279
label 279
name Cordless 5
ephone-dn 98 dual-line
number 280
label 280
description Cordless 6
name Cordless 6
ephone-dn 99 dual-line
number 281
label 281
name Cordless 6
ephone-dn 100 dual-line
number 282
label 282
description Cordless 7
name Cordless 7
ephone-dn 101 dual-line
number 283
label 283
name Cordless 7
ephone-dn 102 dual-line
number 284
label 284
description Cordless 8
name Cordless 8
ephone-dn 103 dual-line
number 285
label 285
name Cordless 8
ephone-dn 104 dual-line
number 286
label 286
description Cordless 9
name Cordless 9
ephone-dn 105 dual-line
number 287
label 287
name Cordless 9
ephone-dn 106 dual-line
number 288
label 288
description Cordless 10
name Cordless 10
ephone-dn 107 dual-line
number 289
label 289
name Cordless 10
ephone-dn 108 dual-line
number 290
label 290
description Cordless 11
name Cordless 11
ephone-dn 109 dual-line
number 291
label 291
name Cordless 11
ephone-dn 110 dual-line
number 292
label 292
description Theater
name Theater
ephone-dn 111 dual-line
number 293
label 293
description Theater
name Theater
ephone-dn 112 dual-line
number 294
label 294
description Laundry Rm
name Laundry Rm
ephone-dn 113 dual-line
number 295
label 295
description Cordless 13
name Laundry Rm
ephone-dn 114 dual-line
number 296
label 296
description Library
name Library
ephone-dn 115 dual-line
number 297
label 297
description Library
name Library
ephone-dn 116 dual-line
number 298
label 298
description Art Studio Bath
name Art Studio Bath
ephone-dn 117 dual-line
number 299
label 299
ephone-dn 118 dual-line
number 300
label 300
description Cordless 16
name Cordless 16
ephone-dn 119 dual-line
number 301
label 301
description Kitchen
name Kitchen
ephone-dn 120 dual-line
number 302
label 302
description Kitchen
name Kitchen
ephone-dn 121 dual-line
number 303
label 303
description Cordless 17
name Cordless 17
ephone-dn 122 dual-line
number 304 secondary 7204
label 304
description 455-7204
name 4 Car Garage
call-forward noan 600 timeout 60
ephone-dn 123 dual-line
number 305
label 305
description 4 Car Garage
name 4 Car Garage
ephone-dn 124 dual-line
number 306 secondary 7207
label 306
description Bowling Alley
name Bowling Alley
ephone-dn 125 dual-line
number 307
label 307
name Bowling Alley
ephone-dn 126 dual-line
number 308
label 308
description Racuqetball
name Racuqetball
ephone-dn 127 dual-line
number 309
label 309
name Racuqetball
ephone-dn 128 dual-line
number 310 secondary 7202
label 310
description 455-7202
name 2 Car Garage
ephone-dn 129 dual-line
number 311
label 311
description 2 Car Garage
name 2 Car Garage
ephone-dn 130 dual-line
number 312
label 312
description Pool House
name Pool House
ephone-dn 131 dual-line
number 313
label 313
name Pool House
ephone-dn 132 dual-line
number 314
label 314
description Electric Room
name Electric Room
ephone-dn 133 dual-line
number 315
label 315
name Electric Room
ephone-dn 134 dual-line
number 316
label 316
description Massage Room
name Massage Room
ephone-dn 135 dual-line
number 317
label 317
name Massage Room
ephone-dn 136 dual-line
number 318
label 318
description Pool Bar
name Pool Bar
ephone-dn 137 dual-line
number 319
label 319
name Pool Bar
ephone-dn 138 dual-line
number 320
label 320
description Dining Room
name Dining Room
ephone-dn 139 dual-line
number 321
label 321
name Dining Room
ephone-dn 140 dual-line
number 322
label 322
name Art Studio
ephone-dn 141 dual-line
number 323
label 323
name Art Studio
ephone-dn 142 dual-line
number 324
label 324
description Tiki Hut
name Tiki Hut
ephone-dn 143 dual-line
number 325
label 325
name Tiki Hut
ephone-dn 144 dual-line
number 326
label 326
description Tree House
name Tree House
ephone-dn 145 dual-line
number 327
label 327
name Tree House
ephone-dn 146 dual-line
number 328
label 328
description Zen Garden
name Zen Garden
ephone-dn 147 dual-line
number 330
label 330
description Romans room
name Romans Room
ephone 1
device-security-mode none
description Kitchen
video
mac-address 0017.956D.D428
speed-dial 1 101 label "Page All Inside"
speed-dial 2 102 label "Page All Outside"
speed-dial 3 103 label "Page All"
speed-dial 4 97044127 label "Police"
paging-dn 1
type 7970
button 1c8,80,81,82,83,84,85,87,88,89 2:16
ephone 2
video
mac-address 0017.95F9.D77D
paging-dn 1
type 7970
button 1c119,80,81,82,83,84,85,87,88 2:120
ephone 3
video
mac-address 0017.0E74.EB82
type 7970
button 1o12,80,81,82,83,84,85,87,88 2:13
ephone 4
video
mac-address 0019.56A6.A5EF
username "user7800" password rpf902983
type 7960
button 1o14,80,81,82,83,84,85,87,88 2:15
ephone 5
video
mac-address 0019.56AF.4ED1
username "user7503" password cqc454006
speed-dial 5 97044127 label "Police"
paging-dn 1
type 7960
button 1c40,80,81,82,83,84,85,87,88,89 2:41
ephone 6
video
mac-address 001B.D433.192A
paging-dn 1
type 7970
button 1c58,80,81,82,83,84,85,87,88,89 2:59
ephone 7
video
mac-address 0013.8022.70CC
username "user7" password 207
paging-dn 2
type 7960
button 1:32 2:18
ephone 8
video
mac-address 0015.621A.C948
username "user7502" password lyu752889
paging-dn 1
type 7960
button 1c38,80,81,82,83,84,85,87,88,89 2:39
ephone 9
video
mac-address 0017.0EBC.1BD4
paging-dn 1
type 7960
button 1c42,80,81,82,83,84,85,87,88,89 2:43
ephone 10
video
mac-address 001A.2F26.5434
paging-dn 1
type 7960
button 1c132,80,81,82,83,84,85,87,88,89 2:133
ephone 11
video
mac-address 001B.2A8A.04CE
paging-dn 1
type 7960
button 1:52 2:53
ephone 12
video
mac-address 0017.9406.EEB9
speed-dial 7 97044127 label "Police"
paging-dn 1
type 7970
button 1c9,80,81,82,83,84,85,87,88,89 2:10
ephone 13
video
mac-address 0017.9406.ED42
ephone-template 1
paging-dn 1
type 7970
button 1c26,80,81,82,83,84,85,87,88,89 2:27
ephone 14
video
mac-address 0017.94D7.2AFE
ephone-template 1
paging-dn 1
type 7970
button 1c50,80,81,82,83,84,85,87,88,89 2:51
ephone 15
video
mac-address 0017.9406.F265
paging-dn 1
type 7970
button 1c34,80,81,82,83,84,85,87,88,89 2:35
ephone 16
video
mac-address 0017.E00C.C1E0
paging-dn 1
type 7970
ephone 17
video
mac-address 0017.9529.5DDB
ephone-template 1
paging-dn 1
type 7970
button 1c21,80,81,82,83,84,85,87,88,89 2:20
ephone 18
video
mac-address 001D.4595.8528
ephone-template 1
username "user7508" password lry227868
paging-dn 4
type 7960
button 1:6 2:7
ephone 19
video
mac-address 0017.95F9.D7AF
ephone-template 1
paging-dn 1
type 7970
button 1c23,80,81,82,83,84,85,87,88,89 2:18
ephone 20
video
mac-address 0017.94D7.2BFF
paging-dn 1
type 7970
button 1c56,80,81,82,83,84,85,87,88 2:57
ephone 21
video
mac-address 0017.956D.D40B
username "user7506" password jcr821998
paging-dn 1
type 7970
button 1c28,80,81,82,83,84,85,87,88,89 2:29
ephone 22
video
mac-address 0007.EB64.54C6
paging-dn 1
type 7960
button 1:26
ephone 23
video
mac-address 0017.956D.CEF9
ephone-template 1
paging-dn 1
type 7970
button 1c130,80,81,82,83,84,85,87,88,89 2:131
ephone 25
video
mac-address 000F.23FC.A34C
ephone-template 1
paging-dn 1
type 7970
button 1c44,80,81,82,83,84,85,87,88,89 2:45
ephone 26
video
mac-address 0012.8055.981D
ephone-template 1
paging-dn 1
type 7970
button 1c46,80,81,82,83,84,85,87,88,89 2:47
ephone 27
video
mac-address 0017.9406.ED86
ephone-template 1
paging-dn 1
type 7970
button 1c48,80,81,82,83,84,85,87,88,89 2:49
ephone 28
video
mac-address 0017.956D.D269
paging-dn 1
type 7970
ephone 29
video
mac-address 0017.956D.D42F
paging-dn 1
type 7970
ephone 30
video
mac-address 0017.596E.C398
paging-dn 1
type 7970
button 1c128,80,81,82,83,84,85,87,88,89 2:129
ephone 31
video
mac-address 001A.6CA9.87E2
paging-dn 1
type 7920
button 1c110,80,81,82,83,84,85,86,87,88 2:111
ephone 32
video
mac-address 001A.6CA9.87DA
type 7920
button 1c73,80,81,82,83,84,85,87,88,89 2:74
ephone 33
video
mac-address 001A.6CA9.87E0
type 7920
button 1c94,80,81,82,83,84,85,87,88,89 2:95
ephone 34
video
mac-address 001A.6CA9.87E3
ephone-template 1
username "user34" password 234
paging-dn 2
type 7920
button 1c95,80,81,82,83,84,85,87,88,89 2:96
ephone 35
video
mac-address 001A.6CA9.87DD
ephone-template 1
username "user35" password 235
type 7920
button 1c98,80,81,82,83,84,85,87,88,89 2:99
ephone 36
video
mac-address 0019.56A6.A6B1
ephone-template 1
username "user36" password 236
paging-dn 1
type 7970
button 1c22,80,81,82,83,84,85,87,88,89 2:19
ephone 37
video
mac-address 001A.6CA9.87D9
ephone-template 1
username "user37" password 237
type 7920
button 1c101,80,81,82,83,84,85,87,88,89 2:102
ephone 38
video
mac-address 0017.9406.F160
username "user38" password 238
paging-dn 1
type 7970
button 1c64,80,81,82,83,84,85,87,88,89 2:65
ephone 39
video
mac-address 0016.C79D.6EDD
username "user7200" password fks455806
speed-dial 1 101 label "Page Inside"
speed-dial 2 102 label "Page Outside"
speed-dial 3 102 label "Page All"
paging-dn 1
type 7970
button 1c66,80,81,82,83,84,85,87,88,89 2:67
ephone 40
video
mac-address 0021.D8BB.A10A
username "user7505" password rvb545163
paging-dn 1
type 7960
button 1c54,80,81,82,83,84,85,87,88,89 2:55
ephone 42
video
mac-address 001A.6CA9.87C1
username "user42" password 242
type 7920
button 1c92,80,81,82,83,84,85,87,88,89 2:93
ephone 43
video
mac-address 0017.951C.C10C
paging-dn 1
type 7970
button 1c11,80,81,82,83,84,85,87,88,89 2:17
ephone 44
video
mac-address 0017.9529.5E2B
username "user44" password 244
paging-dn 1
type 7970
button 1c34,80,81,82,83,84,85,86,87,88 2:35
ephone 45
video
mac-address 0017.956D.D28C
username "user45" password 245
paging-dn 1
type 7970
button 1c36,80,81,82,83,84,85,86,87,88 2:37
ephone 46
video
mac-address 001A.6CA9.87BE
username "user46" password 246
paging-dn 1
type 7920
button 1c20,80,81,82,83,84,85,86,87,88 2:21
ephone 47
video
mac-address 001A.6CA9.87BA
username "user47" password 247
paging-dn 1
type 7920
button 1c116,80,81,82,83,84,85,86,87,88 2:117
ephone 48
video
mac-address 001A.6CA9.87C3
username "user48" password 248
type 7920
button 1c113,80,81,82,83,84,85,86,87,88 2:114
ephone 49
video
mac-address 001A.6CA9.87BB
username "user49" password 249
type 7920
button 1c128,80,81,82,83,84,85,86,87,88 2:57
ephone 50
video
mac-address 001A.6CA9.87BD
username "user50" password 250
paging-dn 1
type 7920
button 1c119,80,81,82,83,84,85,86,87,88 2:120
ephone 51
video
mac-address 001A.6CA9.87C4
username "user51" password 251
type 7920
ephone 52
video
mac-address 001A.6CA9.87C7
username "user52" password 252
type 7920
button 1c108,80,81,82,83,84,85,86,87,88 2:109
ephone 53
video
mac-address 001A.6CA9.87C0
username "user53" password 253
type 7920
button 1c112,80,81,82,83,84,85,86,87,88 2:113
ephone 54
video
mac-address 001A.6CA9.87C6
username "user54" password 254
type 7920
button 1c106,80,81,82,83,84,85,86,87,88 2:107
ephone 55
video
mac-address 0017.0EF0.38D0
username "user55" password 255
paging-dn 1
type 7960
ephone 56
video
mac-address 0013.7F7A.ABF3
username "user56" password 256
paging-dn 1
type 7960
button 1c66,80,81,82,83,84,85,86,87,88 2:67
ephone 57
video
mac-address 0015.C65C.64B0
username "user57" password 257
paging-dn 1
type 7960
button 1c62,80,81,82,83,84,85,86,87,88 2:63
ephone 58
video
mac-address 0015.2B03.6758
username "user58" password 258
paging-dn 1
type 7960
button 1c114,80,81,82,83,84,85,86,87,88 2:115
ephone 59
video
mac-address 0019.06ED.A7BC
username "user59" password 259
paging-dn 1
type 7960
ephone 60
video
mac-address 001B.D433.1C7D
username "user60" password 260
paging-dn 1
type 7970
button 1c60,80,81,82,83,84,85,86,87,88 2:61
ephone 61
video
mac-address 0019.2F90.470E
username "user61" password 261
paging-dn 1
type 7970
button 1c130,80,81,82,83,84,85,86,87,88 2:131
ephone 62
video
mac-address 0019.56A6.A8F5
username "user62" password 262
paging-dn 1
type 7970
ephone 63
video
mac-address 0015.2BB5.C89E
username "user63" password 263
paging-dn 1
type 7970
ephone 64
video
mac-address 0017.956D.D37C
username "user64" password 264
paging-dn 1
type 7970
button 1c124,80,81,82,83,84,85,86,87,88 2:125
ephone 65
video
mac-address 001E.4AF3.6387
username "user65" password 265
paging-dn 1
type 7960
button 1c72,80,81,82,83,84,85,87,88,89
ephone 66
video
mac-address 0011.2111.18DF
username "user66" password 266
paging-dn 1
type 7970
button 1c134,80,81,82,83,84,85,87,88,89 2:135
ephone 67
video
mac-address 0015.FAA0.E7AD
username "user67" password 267
paging-dn 1
type 7960
button 1c122,80,81,82,83,84,85,86,87,88 2:128
ephone 68
video
mac-address 001B.D458.B20F
username "user68" password 268
paging-dn 1
type 7921
ephone 69
video
mac-address 001B.D458.A8D0
username "user69" password 269
paging-dn 1
type 7921
ephone 70
video
mac-address 001B.D458.A7A4
paging-dn 1
type 7921
button 1c46,80,81,82,83,84,85,86,87,88 2:47
ephone 71
video
mac-address 001B.D458.A68A
paging-dn 1
type 7921
ephone 72
video
mac-address 001B.D458.A9C6
paging-dn 1
type 7921
button 1c138,80,81,82,83,84,85,87,88,89,2,139
ephone 73
video
mac-address 001B.D458.ABCD
paging-dn 1
type 7921
ephone 74
video
mac-address 001B.D458.A7F5
paging-dn 1
type 7921
button 1c24,80,81,82,83,84,85,87,88,89 2:25
ephone 75
video
mac-address 0022.90BA.3C87
paging-dn 1
type 7960
button 1c122,80,81,82,83,84,85,87,88,89 2:123
ephone 76
video
mac-address 001B.5495.1526
paging-dn 1
type 7960
button 1c126,80,81,82,83,84,85,87,88,89 2:127
ephone 77
video
mac-address 0017.0E01.10F8
paging-dn 2
type 7971
button 1c136,80,81,82,83,84,85,87,88,89 2:137
ephone 78
video
mac-address 0017.0EF0.3490
paging-dn 2
type 7971
button 1c140,80,81,82,83,84,85,87,88,89 2:141
ephone 79
video
mac-address 0017.0EBC.1BFA
paging-dn 1
type 7971
button 1c116,80,81,82,83,84,85,87,88,89 2:117
ephone 80
video
mac-address 001A.6CA9.87DC
type 7920
ephone 81
video
mac-address 0015.C696.E2B4
username "user43" password 243
paging-dn 1
type 7971
ephone 82
video
mac-address 0015.621A.CDED
paging-dn 1
type 7971
button 1o22,80,81,82,83,84,85,86,87,88 2:19
ephone 83
video
mac-address 0019.56A6.A8BB
paging-dn 1
type 7971
ephone 84
video
mac-address 001E.4AF3.6372
paging-dn 1
type 7960
button 1c126,80,81,82,83,84,85,86,87,88 2:127
ephone 85
video
mac-address 0015.629E.8089
paging-dn 1
type 7971
ephone 86
video
mac-address 001E.7ABB.4856
paging-dn 1
type 7921
ephone 87
video
mac-address 0019.55EC.B043
ephone-template 1
paging-dn 1
type 7970
button 1c21,80,81,82,83,84,85,87,88,89 2:147
banner login ^CC
Unauthorized Use Is Prohibited
Access to this device or attached networks is expressly
prohibited without express written permission.
Violators will be prosecuted to the fullest extent
of both civil and criminal law.
^C
banner motd ^CC
Welcome
All activity is logged and audited.
^C
alias exec cue service-module service-engine 0/0 session
alias exec s show ip interface brief
line con 0
exec-timeout 30 0
logging synchronous
line aux 0
line 194
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
access-class 23 in
exec-timeout 30 0
password xxxxxxxxxx
logging synchronous
transport input telnet ssh
line vty 5 15
access-class 23 in
exec-timeout 30 0
logging synchronous
transport input ssh
no scheduler allocate
ntp clock-period 17180125
ntp server 216.187.142.207
ntp server 216.218.192.202
ntp server 209.81.9.7
ntp server 204.152.184.72
ntp server 128.2.129.21
webvpn cef
end
CME2851#
Philip D'Ath
Have you tried giving it a power cycle?  Sometimes the old CME modules just stop working.  Sometimes they corrupt themselves.
Philip D'Ath
Here I am thinking there was a problem with the configuration and you showed me the way!
I powered the CME router off, opened it, cleaned it with a vacuum, removed the CUE-AIM module, removed the Memory chips and the flash card, blew all sockets, put everything back together, powered the router up and after a few minutes of waiting as the CUE-AIM module takes A WHILE to load completely to the point where I was thinking (this did not worked), then everything worked perfect.
Thanks Philip!!
