On a CME with "no forward local-calls" configured on the DN's, is there a way to treat incoming VoIP calls from another CME site as "local calls" so they are not forwarded ?
I would like the call forward setiings to apply to incoming PSTN calls only, not calls from local or remote site phones. I have tried using the dialplan-pattern command, which doesn't seem to work and also loopback-dn's which works but causes 1 way voice issues with forwarded and transferred calls which I may try and troubleshoot. However I would be grateful if anyone knows a better way to do it.
Phil
