One Click to Home Screen
goranpilat
Level 3
Level 3
I have CUCM 10.5 with IP phone 8941 and 9.4.1.9 firmware.
Customer asked for One Click to Home Screen feature. In documentation I can't find any useful info about this (only that no configuration is rrequired).
So, as silly as it sounds, I just can't figure out which button am I supposed to push to go back to home screen? How to set up the feature?
Thnx a lot
Goran
Hi.
The contacts button does that function.
Wherever you are on the phone, just push that key to turn back to the home screen
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8941_8945/9_0/english/user_guide/P415_BK_C2704923_00_user-guide-8941-8945.pdf
Carlo
Please rate all helpful posts "The more you help the more you learn"
I saw this user guide, but unfortunatelly I'm not getting home screen, I get the corporate /personal directory screen, which is the behavior I would expect without the feature.
Am I missing something? should this feature be explicitely turned on somewhere?
Thanks for the answer
Goran
