01-13-2016 12:22 PM - edited 03-17-2019 05:29 AM
I am experiencing an issue with one way audio on the 8841 Series phones after I put someone on hold and take them off hold. Scenarios:
User A 8841
User B 8841
User A calls User B via ICT User B answers and conversation begins. User A puts user B on Hold and once resumed there is one way audio user A can hear B but B cannot hear A.
User A calls User B via ICT User B answers and conversation begins. User B puts user A on Hold and once resumed all is fine.
We try these scenarios with 79XX series phones and all works as expected.
CUCM V 8.6.2.2
8841 Firmware Phone 10.3.1.20
01-13-2016 02:52 PM
That ICT , between what CUCM versions is that?
if they are same versions, did you check, double check and check again, that the settings are the same at both ends?
01-13-2016 02:58 PM
Hi Dennis,
I have checked but not triple checked. Both CUCM Version are the same 8.6.2. The ICT works with none SIP phones. It actually works with sip phones except when the caller placed the call on hold.
01-13-2016 03:04 PM
So do you have an MRGL specified for the SIP phones or are you inheriting the default null MRGL (which by default, would utilize the software MTP resources on each cluster node that has the IP Streaming Voice and Media Application service running on it)?
Ryan
01-13-2016 06:04 PM
Hi Ryan,
MRGL's are speficied for SIP Phones/all phones. Each MRGL has 2 MRG's assigned. One of which is the software MRG which contains MTP's. The Software MRG has "Use Multi-cast for MOH Audio (If at least one multi-cast MOH resource is available)" checked.
Please note that the current configuration works if the Scenario is:
User A 88XX (SIP) calls (ICT) User B79XX (SCCP)and place call on hold by User A once resumed no issues. Seems to only occur when both endpoints are Sip and the caller initiates the hold.User A 88XX (SIP) calls (ICT) User B88XX (SIP)
01-13-2016 08:12 PM
You can check if MTP required is enabled on both trunks and reset them once. If the issue persists you should capture detailed callmanager traces from both clusters to check if it is a MTP allocation or some signaling issue.
Manish
01-15-2016 11:09 AM
Hi Manish,
I have found the cause of the issue I am facing. This is not mentioned in 8.6 but this is my issue 100%. When i use uni-cast it works fines, the down side is I break MOH streaming from Voice Gateway's. Any thought on the best way to resolve this issue?
https://tools.cisco.com/bugsearch/bug/CSCtc55640/?referring_site=bugquickviewredir
01-29-2016 06:55 AM
