08-16-2018 03:01 AM - edited 03-17-2019 01:21 PM
I'm having one- way audio issues on both inbound/outbound calls on my phone ( I can hear caller but they cant hear me). I swapped my phone with a working phone and experienced the same issue, so I'm guessing something should be wrong with the switch port rather than phone setting as even the replaced phone didn't work when I plugged in to my port.
I compared the switch port config with other ports and it has the same config. any idea what the issue could be?
Many thanks
08-16-2018 04:40 AM
Typically a firewall issue or a network routing issue.
Did this just start happening? Were there any changes made in the environment?
08-17-2018 01:30 AM
this is the only phone in the same network that doesnt work. so port config and routing for this phone are the same as others.
08-16-2018 05:19 AM
10-11-2018 03:32 AM
Hi Syed, how do you verify the route path for RTP stream from one ip phone to other ip phone and also if ip phone has reachability to the voice gateway.
10-11-2018 03:33 PM
I would use wireshark to do this,
so these types of issues you would also need to look at the SIP SDP to see what the IP addresses are in the RTP stream.
but again, wireshark can confirm if you are actually receiving RTP (used in conjucntion with Jabber softphone)
