One way audio with IP Communicator
Hi Guys,
I am having the follow problem reference the IP Communicator. When I call between IP Communicator the audio it is Ok. When I do the call of IP Communicator to Deskphone there are audio only one direction (one way audio). This problem occurr if I am connect by VPN or no.
Any have idea to solve this problem?
Wilson
Jaime Valencia
One way audio or no audio are most of the times routing issues, make sure the RTP can go both ways between your endpoints, and that nothing is blocking it.
java
if this helps, please rate
Jaime Valencia
java
Hi Jaime,
Thanks a lot for Your answer. The problem were relationship with routing issues same.
Best Regards,
Wilson
