one way voice PSTN calls via H.323
I have two CUCM running, one is version5 other is version8.6..By using the same voicegateway (H.323), phones registered to new CUCM unable to communicate both way while in PSTN call. From outside we can hear voice, but from ip phone we heard nothing not even a ringing tone. No issue with internal calls.
VG ip address : 192.168.2.6
old CM : 192.168.2.11 & 12
new CUCM : 192.168.2.21
phone ip address : 10.23.21.0/24
I tried put my ip phone in the same segment as the gateway, the PSTN call works fine.
my dial peer config as per below;
dial-peer voice 100 voip
description ***Connection to CCM-PUB***
destination-pattern .T
progress_ind setup enable 3
session target ipv4:192.168.2.11
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 101 voip
description ***Connection to CCM-SEC***
session target ipv4:192.168.2.12
codec g711ulaw
no vad
dial-peer voice 102 voip
description ***Connection to CCM8-PUB***
session target ipv4:192.168.2.21
codec g711ulaw
no vad
Chris Deren
One way audio is 99% of times related to routing issues, couple of things to check:
  1. ensure you have ip routing enabled on the router/GW
  2. ensure your H323 protocol is bound to an interface via:
interface X/X
h323-gateway voip interface
h323-gateway voip bind srcaddr x.x.x.x
HTH,
Chris
Chris Deren
interface X/X
HTH,
Chris
This is our VG current config;
interface GigabitEthernet0/0
ip address 192.168.2.6 255.255.255.0
duplex full
speed 1000
no negotiation auto
h323-gateway voip bind srcaddr 192.168.2.6
any phones that still registered to old CM had no issue with both communication, only phones that had migrate to new CUCM experience this.
Problem solved, add routing to allow reachability from VG to voice vlans.
Chris Deren
As I said one way audio is caused by ip routing issue 99% of the time.
Please rate all useful posts!
Chris
