Onebutton CallFwdAll - CUCM 8.5
Hey.
Is it possible to make a Onebutton CallFwdAll to a redefined number.
The user wants to only press this button, and then All calls are forwarded to his mobile phone
I'm running a communication Manager 8.5 with 6945 ip phones.
Thomas
Jaime Valencia
No, best thing you can do is configure the mobile as a speed dial so they just press CFA + speed dial button.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi ThomasGunnar,
The plan of Javalenc is an excellent one.. I tested it worked fine...I used Cisco IP Phone 7942 model for that literally it has 2 lines.
I configured the 1st line for the DN. Then i made the 2nd line as speed dial by modifying button items.
So you have to configure the number as speed dial to which you want to forward all the calls. For my testing purpose i used 86213673 as my call forward number. Below image for your reference.
So now press the CFwdALL + the 2nd line ( Since it is configured as SD ) in the same time or else hold
CFwdALL key then press the 2nd line.... Then you can see the call forward on display.
Kulasekara Raja. K
