Open SIP phone or not model Cisco 6922, 7811, 7940
ankshbh
Dear Team,
Can you please tell me, is below cisco phones open SIP or not?
Because i want to connect below cisco model phone to NEC EPABX
Models-
1) Cisco 6922
2) Cisco 7811
3) Cisco 7940
Awaiting of your reply.
5 Replies 5
Leo Laohoo
Those phones will support SIP, HOWEVER, only 78XX will support 3PCC firmware.
It means Cisco 6922 & 7940 SIP phone is open SIP & can support NEC EPABX.?
There is no such thing as an "open SIP".  It is either SIP or not SIP (like Cisco's SCCP).
Enterprise firmware (SIP) can "integrate" with NEC PABX if the call manager supports SIP.
And here is the "gotcha", 69XX and 79XX do not support 3PCC.  Which means they "can" be supported by a SIP call manager server BUT they need to be individually configured.
If you do not know what you are doing, then don't.  It can/will test your patience.
My recommendation is to find phones that support 3PCC firmware.
Thank you
The first thing you need to check is your NEC  compatibility guide. you need to check with NEC which firmware version is required for  these phones to register  with NEC PBX.
69XX and 79XX will support both sip and SCCP. if these phones are loaded with SCCP, you need to convert them to  SIP.
7811 is a sip phone.
I have registered 7945 on Huawei with SIP, we loaded the fimrware as per their Guide.
Response Signature
