08-16-2011 07:50 AM - edited 03-16-2019 06:30 AM
Hi All,
I am currently using Cisco 3845 for my SIP.When ever i dial my inbound number, out of 10 call only 5 calls are getting establishe and remaining 5 calls getting engaged. I did debug isdn q931 and below are the output.Can some one suggest on this??
Calling Party Number i = 0x2183, '2267582968'
Plan:ISDN, Type:National
*Aug 15 15:43:36.371: ISDN Se0/1/1:15 Q931: Received SETUP callref = 0x82B5 cal
lID = 0x001E switch = primary-net5 interface = User
*Aug 15 15:43:36.375: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 i
s 0x2 0x1, Calling num 2267582968
s 0x0 0x0, Called num 3154
*Aug 15 15:43:36.375: ISDN Se0/1/1:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x
82B5
Channel ID i = 0xA9838F
Exclusive, Channel 15
Progress Ind i = 0x8188 - In-band info or appropriate now available
*Aug 15 15:43:36.379: ISDN Se0/1/1:15 Q931: Applying typeplan for sw-type 0x12 i
*Aug 15 15:43:36.379: ISDN Se0/1/1:15 Q931: Sending SETUP callref = 0x008E call
ID = 0x8027 switch = primary-net5 interface = User
*Aug 15 15:43:36.379: ISDN Se0/1/1:15 Q931: TX -> SETUP pd = 8 callref = 0x008E
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Progress Ind i = 0x8283 - Origination address is non-ISDN
Called Party Number i = 0x80, '3154'
Plan:Unknown, Type:Unknown
*Aug 15 15:43:36.415: ISDN Se0/1/1:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x
808E
*Aug 15 15:43:36.467: ISDN Se0/1/1:15 Q931: RX <- DISCONNECT pd = 8 callref = 0
x808E
Cause i = 0x829C - Invalid number format (incomplete number)
Progress Ind i = 0x8288 - In-band info or appropriate now available
*Aug 15 15:43:36.467: ISDN Se0/1/1:15 Q931: call_disc: PI received in disconnect
; Postpone sending RELEASE for callid 0x8027
*Aug 15 15:43:36.467: ISDN Se0/1/1:15 Q931: TX -> DISCONNECT pd = 8 callref = 0
x82B5
Cause i = 0x809C - Invalid number format (incomplete number)
*Aug 15 15:43:36.519: ISDN Se0/1/1:15 Q931: RX <- RELEASE pd = 8 callref = 0x02
B5
*Aug 15 15:43:36.519: ISDN Se0/1/1:15 Q931: TX -> RELEASE_COMP pd = 8 callref =
0x82B5
*Aug 15 15:43:36.523: ISDN Se0/1/1:15 Q931: TX -> RELEASE pd = 8 callref = 0x00
8E
*Aug 15 15:43:36.543: ISDN Se0/1/1:15 Q931: RX <- RELEASE_COMP pd = 8 callref =
0x808E
*Aug 15 15:43:47.135: ISDN Se0/1/1:15 Q931: RX <- SETUP pd = 8 callref = 0x02B6
Sending Complete
Standard = CCITT
*Aug 15 15:43:47.135: ISDN Se0/1/1:15 Q931: Received SETUP callref = 0x82B6 cal
lID = 0x001F switch = primary-net5 interface = User
*Aug 15 15:43:47.139: ISDN Se0/1/1:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x
82B6
*Aug 15 15:43:47.151: ISDN Se0/1/1:15 Q931: TX -> ALERTING pd = 8 callref = 0x8
2B6
*Aug 15 15:43:47.155: ISDN Se0/1/1:15 Q931: TX -> CONNECT pd = 8 callref = 0x82
B6
*Aug 15 15:43:47.191: ISDN Se0/1/1:15 Q931: RX <- CONNECT_ACK pd = 8 callref =
0x02B6
*Aug 15 15:43:47.191: %ISDN-6-CONNECT: Interface Serial0/1/1:30 is now connected
to 2267582968 N/A
to 2267582968 N/A
to 2267582968 N/A
*Aug 15 15:43:53.191: %ISDN-6-CONNECT: Interface Serial0/1/1:30 is now connected
to 2267582968 N/A
*Aug 15 15:44:00.111: ISDN Se0/1/1:15 Q931: RX <- DISCONNECT pd = 8 callref = 0
x02B6
Cause i = 0x8290 - Normal call clearing
*Aug 15 15:44:00.111: %ISDN-6-DISCONNECT: Interface Serial0/1/1:30 disconnected
from 2267582968 , call lasted 12 seconds
*Aug 15 15:44:00.111: ISDN Se0/1/1:15 Q931: call_disc: PI received in disconnect
; Postpone sending RELEASE for callid 0x1F
*Aug 15 15:44:00.131: ISDN Se0/1/1:15 Q931: TX -> RELEASE pd = 8 callref = 0x82
B6
*Aug 15 15:44:00.147: ISDN Se0/1/1:15 Q931: RX <- RELEASE_COMP pd = 8 callref =
0x02B6
08-16-2011 08:06 AM
All all 10 calls to the same DID? How many cuncurrent calls? Was this working before?
