Outbound call from PRI fails , Q931: call_disc: PI received in disconnect
saurabh_om
I have 3 PRi and none of outbound call work. It gives a engage tone .I see calls are going and extablished but disconnect soon with cause code Q931: call_disc: PI received in disconnect.
i have cisco 2921 H323 GW with 15.1 M(7) IOS. CUCM 8.6
Feb  2 18:22:41.687: ISDN Se0/0/1:15 Q931: Sending SETUP  callref = 0x008B callI
D = 0x800C switch = primary-net5 interface = User
Feb  2 18:22:41.687: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8  callref = 0x008B
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Called Party Number i = 0x80, '099XX136070'
                Plan:Unknown, Type:Unknown
Feb  2 18:22:41.707: ISDN Se0/0/1:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x8
08B
Feb  2 18:22:46.739: ISDN Se0/0/1:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8
08B
Feb  2 18:22:47.295: ISDN Se0/0/1:15 Q931: RX <- PROGRESS pd = 8  callref = 0x80
8B
        Progress Ind i = 0x8288 - In-band info or appropriate now available
        Progress Ind i = 0x8282 - Destination address is non-ISDN
Feb  2 18:22:47.343: ISDN Se0/0/1:15 Q931: RX <- CONNECT pd = 8  callref = 0x808
B
        Date/Time i = 0x0C02021732
                Date (dd-mm-yr)   = 12-02-02
                Time (hr:mnt:sec) = 23:50:194
Feb  2 18:22:47.343: %ISDN-6-CONNECT: Interface Serial0/0/1:30 is now connected
to 09930136070 N/A
Feb  2 18:22:47.343: ISDN Se0/0/1:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0
x008B
Feb  2 18:22:52.275: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/1
:30, changed state to up
csim err csimDisconnected recvd DISC cid(19)
Feb  2 18:22:55.499: ISDN Se0/0/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x
808B
        Cause i = 0x849F - Normal, unspecified
Feb  2 18:22:55.499: %ISDN-6-DISCONNECT: Interface Serial0/0/1:30  disconnected
from 099XX136070 , call lasted 8 seconds
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
G-KOL-VG01#
Feb  2 18:22:55.499: ISDN Se0/0/1:15 Q931: call_disc: PI received in disconnect;
Postpone sending RELEASE for callid 0x800C
Feb  2 18:22:55.503: ISDN Se0/0/1:15 Q931: TX -> RELEASE pd = 8  callref = 0x008
B
Feb  2 18:22:55.519: ISDN Se0/0/1:15 Q931: RX <- RELEASE_COMP pd = 8  callref =
0x808B
Thanks Saurabh
6 Replies 6
saurabh_om
ONE MORE LOG OUTPUT:
G-KOL-VG01#
Feb  2 19:33:59.439: ISDN Se0/0/1:15 Q931: Applying typeplan for sw-type 0x12 is
0x0 0x0, Calling num 525827
Feb  2 19:33:59.439: ISDN Se0/0/1:15 Q931: Sending SETUP  callref = 0x008F callI
D = 0x8010 switch = primary-net5 interface = User
Feb  2 19:33:59.439: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8  callref = 0x008F
                Standard = CCITT
        Calling Party Number i = 0x0081, '525827'
        Called Party Number i = 0x80, '66280607'
Feb  2 19:33:59.459: ISDN Se0/0/1:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x8
08F
Feb  2 19:34:04.487: ISDN Se0/0/1:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8
08F
Feb  2 19:34:04.847: ISDN Se0/0/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x
808F
        Cause i = 0x829F - Normal, unspecified
Feb  2 19:34:04.847: ISDN Se0/0/1:15 Q931: call_disc: PI received in disconnect;
Postpone sending RELEASE for callid 0x8010
Feb  2 19:34:04.851: ISDN Se0/0/1:15 Q931: TX -> RELEASE pd = 8  callref = 0x008
F
Feb  2 19:34:04.867: ISDN Se0/0/1:15 Q931: RX <- RELEASE_COMP pd = 8  callref =
0x808F
G-KOL-VG01#
                Standard = CCITT
08F
08F
808F
F
0x808F
Thanks Saurabh
Saurabh,
Don't know what the problem is.. Do you expect a Disconnect because the PSTN user disconnected? Does it ring the PSTN phone at all? Or do you want that there should be no tone when call is disconnected?
If you are worried why you are getting Disconnect, check with your provider.
Udit
Hello Udit,
While calling otherparty never ring and called user hear busy tone. I dont expect disconnect from any party, call should through.
Thanks Saurabh
Saurabh,
I dont see a voip dialpeer in the config. How u r testing outbound call? r u using csim  ?
Hello Aravind,
dialing outbound only from csim and ip phone both.  call never hit called party.
Thanks Saurabh
I got problem and solution,
PRI is registered for Do not disturb facility. It do not ring numbers which are registered for DND facility.
You will never see DID number for call orignating from this PRI.
Thanks Saurabh
