Outbound Caller ID on CUCM 8.5
benbollinger
Level 2
Level 2
We have CCM 8.5.1 and a  H323 PRI(NI2).  When we place outbound calls the caller id that shows up to the recipient is 12155551212(example), instead of the DID number in the external phone number mask of the DN.
We have use calling parties external phone number mask checked on the route pattern and route list, and no calling number translations or transformations are in place.
Is there any way to determine where the caller id is coming from,  or if the carrier could somehow be responsible for masking the calling phones caller id on outbound call?
12 Replies 12
yahsiel2004
Level 7
Level 7
This issue is more than likely a carrier issue. You should reach out to your carrier and verify that they're not changing your CLID info.
Yosh
HTH Regards, Yosh
Ya, I was trying to find a way to prove that. The debug isdn q931 shows the calling # incorrectly on the outbound gateway, but I was hoping there was a way to find where the gateway got that info from(ccm or telco)
HI ,
If you have run a debug isdn q931 and seen that you are sending the incorrect CLI , then you should use DNA (Dial number analyser) to see what is happening.
It does sound like you are not sending the CLI correctly to the carrier.
regards
Mark
The key things to check here are
1. Is the correct CLI dsiplayed on your gateway..if the answer is YES..then there is no problem with CUCM and gateway presenting the correct CLI
2. The second questions is, is the CLI part of your DDI range...If the answer is NO, then your Telco with replace the advertised number with the main number of your PRI Trunk
3. If the answer to the above is YES, then you can go to your provider and findout what is going on. Some provider require you to pay for this service
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
When I run the debug q931 I see the wrong caller id listed for the outbound call.  Since it is a PRI could the carrier be modifying this,  or does it mean the issue is in the callmanager somewhere?  What locations could the outbound caller ID be modified in callmanager?
I checked the route pattern,  route list,  route group, gateway and the DN on the phone.
CLI can me modified in different places..
1. DN
2External Number mask
3. Translation rules
4. Xlation pattern
Can you send a sh run and
debug voip ccapi inout
debug isdn q931
The debug isdnq931 shows 12155553000(main #),  instead of 2155553579 as the calling number.
Here's the DNA output:
Results Summary
Calling Party Information
Calling Party = 2155553579
Partition = DN_CDC_PT
Device CSS = DEV_CDC_CSS
Line CSS = ALLOW_ALL_CDC_CSS
AAR Group Name =
AAR CSS =
Dialed Digits = 812155551212
Match Result = RouteThisPattern
Matched Pattern Information
Pattern = 81.215XXXXXXX
Partition = CDC_LOCAL_PT
Time Schedule =
Called Party Number = 812155551212
Time Zone = America/New_York
End Device = CDC_LOCAL_RL
Call Classification = OffNet
InterDigit Timeout = NO
Device Override = Disabled
Outside Dial Tone = NO
Call Flow
TranslationPattern :Pattern=
Partition =
Positional Match List = 81:2155551212
Calling Party Number = 2155553579
PreTransform Calling Party Number =
PreTransform Called Party Number =
Calling Party Transformations
External Phone Number Mask = NO
Calling Party Mask =
Prefix =
CallingLineId Presentation =
CallingName Presentation =
ConnectedParty Transformations
ConnectedLineId Presentation =
ConnectedName Presentation =
Called Party Transformations
Called Party Mask =
Discard Digits Instruction =
Prefix =
Called Number =
Route Pattern :Pattern= 81.215XXXXXXX
DialPlan =
Route Filter
Filter Name =
Filter Clause =
Require Forced Authorization Code = Yes
Authorization Level = 20
Require Client Matter Code = No
PreTransform Calling Party Number = 3579
PreTransform Called Party Number = 812155551212
Calling Party Mask = 2155553579
Prefix =
CallingLineId Presentation = Default
CallingName Presentation = Default
Calling Party Number = 2155551212
ConnectedLineId Presentation = Default
ConnectedName Presentation = Default
Called Party Mask =
Discard Digits Instruction = None
Prefix =
Called Number = 812155551212
Route List :Route List Name= CDC_LOCAL_RL
RouteGroup :RouteGroup Name= CDC_PRI_RG
External Phone Number Mask = On
Prefix =
Called Party Mask =
Discard Digits Instructions = PreDot
Prefix =
Called Number =
Device :Type= H323Gateway
End Device Name = 10.210.8.4
PortNumber = 0
Device Status = UnKnown
AAR Group Name =
AAR Calling Search Space =
AAR Prefix Digits =
Inbound Fast Start = Disabled
Outbound Fast Start = Disabled
Call Classification = Use System Default
Tunneled Protocol = None
Calling Party Selection = Originator
Calling Party Presentation = Default
CallerID DN =
Alternate Matches
Partition :Name= CDC_NATIONAL_PT
Pattern
Pattern = 8.1[2-9]XXXXXXXXX
Pattern Type = Enterprise
CallManager Device Type = AccessDevice
PatternPrecedenceLevel = PlDefault
PatternRouteClass = RouteClassDefaul
Debug q931:
Apr  9 15:33:34.106: ISDN Se0/3/0:23 Q931: TX -> SETUP pd = 8  callref = 0x0EF8
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98384
                Exclusive, Channel 4
        Facility i = 0x9F8B0100A11102012C02010080094B656E204769616E67
                Protocol Profile =  Networking Extensions
                0xA11102012C02010080094B656E204769616E67
                Component = Invoke component
                        Invoke Id = 44
                        Operation = CallingName
                                Name Presentation Allowed Extended
                                Name = Ken Giang
        Calling Party Number i = 0x2181, '12159123000'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '2155551212'
Apr  9 15:33:34.142: ISDN Se0/3/0:23 Q931: RX <- STATUS pd = 8  callref = 0x8EF8
        Cause i = 0x82E4 - Invalid information element contents
        Call State i = 0x01
Apr  9 15:33:34.458: ISDN Se0/3/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8EF8
Apr  9 15:33:35.306: ISDN Se0/3/0:23 Q931: RX <- PROGRESS pd = 8  callref = 0x8EF8
        Cause i = 0x82B2 - Requested facility not subscribed
        Progress Ind i = 0x8A81 - Call not end-to-end ISDN, may have in-band info
Apr  9 15:33:35.382: ISDN Se0/3/0:23 Q931: RX <- CONNECT pd = 8  callref = 0x8EF8
Please send the debug voip ccapi inout..
I need to see the VOIP leg before the call is sent to the PSTN
Here's sample call with debug isdn q931, debug h225 asn1, and debug voip ccapi inout.  Called # 6105558749
  h323-ID : {"Berent"}
          sourceInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              productId '436973636F43616C6C4D616E61676572'H
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
          destinationAddress
            dialedDigits : "16105558749"
          activeMC FALSE
          conferenceID '007A5146AD4941161B260F010AD25523'H
          conferenceGoal create : NULL
          callType pointToPoint : NULL
          sourceCallSignalAddress ipAddress :
            ip '0AD2080A'H
            port 1720
          callIdentifier
            guid '007A5146AD4941161B260F010AD25523'H
          mediaWaitForConnect FALSE
          canOverlapSend FALSE
          multipleCalls FALSE
          maintainConnection FALSE
        h245Tunneling FALSE
        nonStandardControl
            nonStandardIdentifier h221NonStandard :
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '82040020040001030003000103'H
009454: Apr  9 17:02:37.259: H225 NONSTD INCOMING ENCODE BUFFER::= 82040020040001030003000103
009455: Apr  9 17:02:37.259:
009456: Apr  9 17:02:37.259: H225 NONSTD INCOMING PDU ::=
value H323_UU_NonStdInfo ::=
      callMgrParam
        interclusterVersion 3
        enterpriseID {}
cch323_ip_best_local_address: IP 10.210.8.4 found for bound IDB GigabitEthernet0/0
009457: Apr  9 17:02:37.259: //-1/007A51461B26/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=Berent
   ----- ccCallInfo IE subfields -----
   cisco-ani=12155553000
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=16105558749
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
009458: Apr  9 17:02:37.259: //-1/007A51461B26/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x317EF024, Call Info(
   Calling Number=12155553000,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=16105558749(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=3100, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=63092
009459: Apr  9 17:02:37.259: //-1/007A51461B26/CCAPI/ccCheckClipClir:
   In: Calling Number=12155553000(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
009460: Apr  9 17:02:37.259: //-1/007A51461B26/CCAPI/ccCheckClipClir:
   Out: Calling Number=12155553000(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
009461: Apr  9 17:02:37.259: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
009462: Apr  9 17:02:37.259: :cc_get_feature_vsa malloc success
009463: Apr  9 17:02:37.259: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
009464: Apr  9 17:02:37.259:  cc_get_feature_vsa count is 45
009465: Apr  9 17:02:37.259: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
009466: Apr  9 17:02:37.259: :FEATURE_VSA attributes are: feature_name:0,feature_time:1091599992,feature_id:63090
009467: Apr  9 17:02:37.259: //63092/007A51461B26/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=12155553000(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=16105558749(TON=Unknown, NPI=Unknown))
009468: Apr  9 17:02:37.259: //63092/007A51461B26/CCAPI/cc_process_call_setup_ind:
   Event=0x41CDDEF8
009469: Apr  9 17:02:37.259: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 16105558749
009470: Apr  9 17:02:37.259: //63092/007A51461B26/CCAPI/ccCallSetContext:
   Context=0x410ED648
009471: Apr  9 17:02:37.259: //63092/007A51461B26/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 63092 with tag 3100 to app "_ManagedAppProcess_Default"
009472: Apr  9 17:02:37.263: //63092/007A51461B26/CCAPI/ccCallProceeding:
009473: Apr  9 17:02:37.267: //63092/007A51461B26/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=206, Params=0x400FD044, Progress Indication=NULL(0)
009474: Apr  9 17:02:37.267: //63092/007A51461B26/CCAPI/ccCheckClipClir:
009475: Apr  9 17:02:37.267: //63092/007A51461B26/CCAPI/ccCheckClipClir:
009476: Apr  9 17:02:37.267: //63092/007A51461B26/CCAPI/ccCallSetupRequest:
   Destination Pattern=1%610.%, Called Number=16105558749, Digit Strip=TRUE
009477: Apr  9 17:02:37.267: //63092/007A51461B26/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=Berent
   Account Number=Berent, Final Destination Flag=TRUE,
   Guid=007A5146-AD49-4116-1B26-0F010AD25523, Outgoing Dial-peer=206
009478: Apr  9 17:02:37.267: //63092/007A51461B26/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=16105558749
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
009479: Apr  9 17:02:37.267: //63092/007A51461B26/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x425D5E0C, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=12155553000,(Calling Name=Berent)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=16105558749(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=206, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
009480: Apr  9 17:02:37.267: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
009481: Apr  9 17:02:37.267: :cc_get_feature_vsa malloc success
009482: Apr  9 17:02:37.267: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
009483: Apr  9 17:02:37.267:  cc_get_feature_vsa count is 46
009484: Apr  9 17:02:37.267: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
009485: Apr  9 17:02:37.267: :FEATURE_VSA attributes are: feature_name:0,feature_time:1091604472,feature_id:63091
009486: Apr  9 17:02:37.267: //63093/007A51461B26/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
009487: Apr  9 17:02:37.267: //63093/007A51461B26/CCAPI/ccCallSetContext:
   Context=0x400FCFF4
009488: Apr  9 17:02:37.267: //63092/007A51461B26/CCAPI/ccSaveDialpeerTag:
009489: Apr  9 17:02:37.267: ISDN Se0/3/0:23 Q931: Applying typeplan for sw-type 0xD is 0x2 0x1, Calling num 12155553000
009490: Apr  9 17:02:37.267: ISDN Se0/3/0:23 Q931: Sending SETUP  callref = 0x0F3C callID = 0x8EBF switch = primary-ni interface = User
009491: Apr  9 17:02:37.267: ISDN Se0/3/0:23 Q931: TX -> SETUP pd = 8  callref = 0x0F3C
                Standard = CCITT
        Channel ID i = 0xA98382
                Exclusive, Channel 2
        Facility i = 0x9F8B0100A115020170020100800D426572656E7420476C617A6572
                0xA115020170020100800D426572656E7420476C617A6572
                        Invoke Id = 112
                                Name = Berent
        Calling Party Number i = 0x2181, '12155553000'
        Called Party Number i = 0xA1, '16105558749'
009492: Apr  9 17:02:37.271: H225.0 OUTGOING PDU ::=
value H323_UserInformation ::=
      h323-uu-pdu
        h323-message-body callProceeding :
          protocolIdentifier { 0 0 8 2250 0 4 }
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
          h245Address ipAddress :
            ip '0AD20804'H
            port 41488
          callIdentifier
          multipleCalls FALSE
        h245Tunneling FALSE
009493: Apr  9 17:02:37.271: H225.0 OUTGOING ENCODE BUFFER::= 21C0060008914A00042800B500001240013C050100000AD20804A210110C1100007A5146AD4941161B260F010AD255230100010010800100
009494: Apr  9 17:02:37.271:
009495: Apr  9 17:02:37.303: ISDN Se0/3/0:23 Q931: RX <- STATUS pd = 8  callref = 0x8F3C
        Call State i = 0x01
009496: Apr  9 17:02:37.623: ISDN Se0/3/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8F3C
009497: Apr  9 17:02:37.623: //63093/007A51461B26/CCAPI/cc_api_call_proceeding:
   Interface=0x425D5E0C, Progress Indication=NULL(0)
009498: Apr  9 17:02:38.523: //63090/187BDF0CA88B/CCAPI/cc_api_call_feature:
   Feature Type=13, Interface=0x425D5E0C, Call Id=63090
009499: Apr  9 17:02:38.527: //63091/187BDF0CA88B/CCAPI/ccCallFeature:
   Feature Type=13, Call Id=63091
009500: Apr  9 17:02:38.875: ISDN Se0/3/0:23 Q931: RX <- PROGRESS pd = 8  callref = 0x8F3C
        Progress Ind i = 0x8488 - In-band info or appropriate now available
009501: Apr  9 17:02:38.875: //63093/007A51461B26/CCAPI/cc_api_call_cut_progress:
   Interface=0x425D5E0C, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
   Cause Value=50
009502: Apr  9 17:02:38.875: //63093/007A51461B26/CCAPI/cc_api_call_cut_progress:
   Call Entry(Responsed=TRUE)
009503: Apr  9 17:02:38.875: //63092/007A51461B26/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=50
   Voice Call Send Alert=TRUE, Call Entry(Alert Sent=FALSE)
009504: Apr  9 17:02:38.875: //63092/007A51461B26/CCAPI/ccCallCutProgress:
   Call CallAlert;
009505: Apr  9 17:02:38.875: //63092/007A51461B26/CCAPI/ccCallAlert:
009506: Apr  9 17:02:38.875: //63092/007A51461B26/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
009507: Apr  9 17:02:38.875: //63093/007A51461B26/CCAPI/cc_api_get_called_ccm_detected:
   CallInfo(ccm detected=0)
009508: Apr  9 17:02:38.875: //63092/007A51461B26/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID1=0xF674, gcid=0-0-0-0, tag=0x0)
009509: Apr  9 17:02:38.875: //63093/007A51461B26/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID2=0xF675, gcid=0-0-0-0, tag=0x0)
009510: Apr  9 17:02:38.875: //63092/007A51461B26/CCAPI/ccConferenceCreate:
   Conference Id=0xFFFFFFFF, Call Id1=63092, Call Id2=63093, Tag=0x0
009511: Apr  9 17:02:38.875: //63092/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
009512: Apr  9 17:02:38.875: cc_api_get_xcode_stream : 4825
009513: Apr  9 17:02:38.875: //63092/007A51461B26/CCAPI/cc_api_bridge_done:
   Conference Id=0x78EA, Source Interface=0x317EF024, Source Call Id=63092,
   Destination Call Id=63093, Disposition=0x0, Tag=0x0
009514: Apr  9 17:02:38.875: //63093/007A51461B26/CCAPI/cc_api_bridge_done:
   Conference Id=0x78EA, Source Interface=0x425D5E0C, Source Call Id=63093,
   Destination Call Id=63092, Disposition=0x0, Tag=0xFFFFFFFF
009515: Apr  9 17:02:38.875: //63092/007A51461B26/CCAPI/cc_generic_bridge_done:
009516: Apr  9 17:02:38.875: //63092/007A51461B26/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x78EA, Destination Call Id=63093)
009517: Apr  9 17:02:38.879: //63093/007A51461B26/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x78EA, Destination Call Id=63092)
009518: Apr  9 17:02:38.879: //63092/007A51461B26/CCAPI/ccConferenceCreate:
009519: Apr  9 17:02:38.879: confID:0x78EA; callEntry1 callID1:0xF674, type:1; callEntry2 callID2:0xF675, type:6
009520: Apr  9 17:02:38.879: //63093/007A51461B26/CCAPI/cc_api_caps_ind:
   Destination Interface=0x317EF024, Destination Call Id=63092, Source Call Id=63093,
   Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
009521: Apr  9 17:02:38.879: //63093/007A51461B26/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
009522: Apr  9 17:02:38.879: //63092/007A51461B26/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=63092
009523: Apr  9 17:02:38.879: //63093/007A51461B26/CCAPI/cc_api_get_called_ccm_detected:
009524: Apr  9 17:02:38.879: //63092/007A51461B26/CCAPI/cc_api_get_delay_xport:
   CallInfo(delay xport=FALSE)
009525: Apr  9 17:02:38.879: H225 NONSTD OUTGOING PDU ::=
      version 2
      protoParam qsigNonStdInfo :
        iei 8
        rawMesg '080282B21E0284881C269E810003677464000000...'H
009526: Apr  9 17:02:38.879: H225 NONSTD OUTGOING ENCODE BUFFER::= 60010200010830080282B21E0284881C269E8100036774640000001B4350472C0D0A50524E2C6973646E2A2C2C4E492A2A2A2C0D0A0D0A
009527: Apr  9 17:02:38.879:
009528: Apr  9 17:02:38.879: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body alerting :
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
            ip '0AD20804'H
            port 41488
          callIdentifier
          multipleCalls FALSE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '60010200010830080282B21E0284881C269E8100...'H
        tunnelledSignallingMessage
          tunnelledProtocolID
            id tunnelledProtocolAlternateID :
              protocolType "gtd"
          messageContent
            '4350472C0D0A50524E2C6973646E2A2C2C4E492A...'H
          tunnellingRequired NULL
009529: Apr  9 17:02:38.879: H225.0 OUTGOING ENCODE BUFFER::= 23C0060008914A00042800B500001240013C050100000AD20804A2101B0C001100007A5146AD4941161B260F010AD255230100010010A801003E0140B50000123760010200010830080282B21E0284881C269E8100036774640000001B4350472C0D0A50524E2C6973646E2A2C2C4E492A2A2A2C0D0A0D0A224204677464011B4350472C0D0A50524E2C6973646E2A2C2C4E492A2A2A2C0D0A0D0A
009530: Apr  9 17:02:38.879:
009531: Apr  9 17:02:38.883: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body notify :
          callIdentifier
        h245Tunneling FALSE
009532: Apr  9 17:02:38.883: H225.0 OUTGOING ENCODE BUFFER::= 28501900060008914A000400007A5146AD4941161B260F010AD2552310800100
009533: Apr  9 17:02:38.883:
009534: Apr  9 17:02:38.883: //63092/007A51461B26/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x78EA, Call Id1=63092, Call Id2=63093
009535: Apr  9 17:02:38.907: //63092/007A51461B26/CCAPI/cc_api_caps_ind:
   Destination Interface=0x425D5E0C, Destination Call Id=63093, Source Call Id=63092,
   Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x1,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
009536: Apr  9 17:02:38.907: //63092/007A51461B26/CCAPI/cc_api_caps_ind:
009537: Apr  9 17:02:38.907: //63092/007A51461B26/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=6122)
009538: Apr  9 17:02:38.907: //63093/007A51461B26/CCAPI/cc_api_caps_ack:
009539: Apr  9 17:02:38.911: //63093/007A51461B26/CCAPI/cc_api_voice_mode_event:
   Call Id=63093
009540: Apr  9 17:02:38.911: //63093/007A51461B26/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x400FCFF4)cch323_ip_best_local_address: IP 10.210.8.4 found for bound IDB GigabitEthernet0/0
009541: Apr  9 17:02:42.219: ISDN Se0/3/0:23 Q931: RX <- ALERTING pd = 8  callref = 0x8F3C
009542: Apr  9 17:02:42.219: //63093/007A51461B26/CCAPI/cc_api_call_alert:
   Interface=0x425D5E0C, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
009543: Apr  9 17:02:42.219: //63093/007A51461B26/CCAPI/cc_api_call_alert:
   Call Entry(Retry Count=0, Responsed=TRUE)
009544: Apr  9 17:02:42.219: //63092/007A51461B26/CCAPI/ccCallAlert:
009545: Apr  9 17:02:42.219: //63092/007A51461B26/CCAPI/ccCallAlert:
009546: Apr  9 17:02:42.219: //63093/007A51461B26/CCAPI/cc_api_get_called_ccm_detected:
009547: Apr  9 17:02:42.219: //63092/007A51461B26/CCAPI/cc_api_get_delay_xport:
009548: Apr  9 17:02:43.139: //63045/9E86B001A4AF/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 0 to dstCallId 0xF647
009549: Apr  9 17:02:43.139: //63045/9E86B001A4AF/CCAPI/cc_relay_digit_begin_for_3way_conference:
   Check DTMF relay digit begin for 3way conf
009550: Apr  9 17:02:43.247: //63045/9E86B001A4AF/CCAPI/cc_api_call_digit_end:
009551: Apr  9 17:02:43.247: //63045/9E86B001A4AF/CCAPI/cc_relay_digit_end_for_3way_conference:
   Check DTMF relay digit end for 3way conf
009552: Apr  9 17:02:45.959: H225.0 INCOMING ENCODE BUFFER::= 2580060008914A00051100110080490BF728494116E70A1B050ADC984010800100
009553: Apr  9 17:02:45.959:
009554: Apr  9 17:02:45.959: H225.0 INCOMING PDU ::=
      h323-uu-pdu
        h323-message-body releaseComplete :
          protocolIdentifier { 0 0 8 2250 0 5 }
          callIdentifier
            guid '80490BF728494116E70A1B050ADC9840'H
        h245Tunneling FALSE
009555: Apr  9 17:02:45.959: //63063/80490BF7E70A/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x317EF024, Call Id=63063
009556: Apr  9 17:02:45.959: //63063/80490BF7E70A/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
009557: Apr  9 17:02:45.963: //63063/80490BF7E70A/CCAPI/ccConferenceDestroy:
   Conference Id=0x78DB, Tag=0x0
009558: Apr  9 17:02:45.963: //63063/80490BF7E70A/CCAPI/ccConferenceDestroy:
009559: Apr  9 17:02:45.963: confID:0x78DB; callEntry1 callID1:0xF657, type:1; callEntry2 callID2:0xF658, type:6
009560: Apr  9 17:02:45.963: //63063/80490BF7E70A/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x78DB, Source Interface=0x317EF024, Source Call Id=63063,
   Destination Call Id=63064, Disposition=0x0, Tag=0x0
009561: Apr  9 17:02:45.963: //63064/80490BF7E70A/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x78DB, Source Interface=0x425D5E0C, Source Call Id=63064,
   Destination Call Id=63063, Disposition=0x0, Tag=0x0
009562: Apr  9 17:02:45.963: //63063/80490BF7E70A/CCAPI/cc_generic_bridge_done:
009563: Apr  9 17:02:45.963: //63063/80490BF7E70A/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
009564: Apr  9 17:02:45.963: //63063/80490BF7E70A/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
009565: Apr  9 17:02:45.963: //63063/80490BF7E70A/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
009566: Apr  9 17:02:45.963: //63064/80490BF7E70A/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
009567: Apr  9 17:02:45.963: //63064/80490BF7E70A/CCAPI/ccCallDisconnect:
009568: Apr  9 17:02:45.963: //63064/80490BF7E70A/CCAPI/cc_api_get_transfer_info:
009569: Apr  9 17:02:45.967: //63063/80490BF7E70A/CCAPI/cc_api_get_transfer_info:
009570: Apr  9 17:02:45.967: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
009571: Apr  9 17:02:45.967: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A00041100110080490BF728494116E70A1B050ADC984010800100
009572: Apr  9 17:02:45.967:
009573: Apr  9 17:02:45.971: //63063/80490BF7E70A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x317EF024, Tag=0x0, Call Id=63063,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
009574: Apr  9 17:02:45.971: //63063/80490BF7E70A/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
009575: Apr  9 17:02:45.971: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
009576: Apr  9 17:02:45.971: :cc_free_feature_vsa freeing 41109990
009577: Apr  9 17:02:45.971: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
009578: Apr  9 17:02:45.971:  vsacount in free is 45
009579: Apr  9 17:02:45.979: ISDN Se0/3/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x0F39
        Cause i = 0x8090 - Normal call clearing
009580: Apr  9 17:02:46.019: ISDN Se0/3/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x8F39
009581: Apr  9 17:02:46.019: ISDN Se0/3/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0F39
009582: Apr  9 17:02:46.023: //63064/80490BF7E70A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x425D5E0C, Tag=0x0, Call Id=63064,
009583: Apr  9 17:02:46.023: //63064/80490BF7E70A/CCAPI/cc_api_call_disconnect_done:
009584: Apr  9 17:02:46.023: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
009585: Apr  9 17:02:46.023: :cc_free_feature_vsa freeing 4110AB10
009586: Apr  9 17:02:46.023: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
009587: Apr  9 17:02:46.023:  vsacount in free is 44
009588: Apr  9 17:02:48.927: ISDN Se0/3/0:23 Q931: RX <- CONNECT pd = 8  callref = 0x8F3C
009589: Apr  9 17:02:48.927: ISDN Se0/3/0:23 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0F3C
009590: Apr  9 17:02:48.927: //63093/007A51461B26/CCAPI/cc_api_call_connected:
   Interface=0x425D5E0C, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
009591: Apr  9 17:02:48.927: //63093/007A51461B26/CCAPI/cc_api_call_connected:
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
009592: Apr  9 17:02:48.927: //63092/007A51461B26/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
009593: Apr  9 17:02:48.927: //63093/007A51461B26/CCAPI/cc_api_get_called_ccm_detected:
009594: Apr  9 17:02:48.927: //63092/007A51461B26/CCAPI/ccCallConnect:
   Call Entry(Connected=TRUE, Responsed=TRUE)
009595: Apr  9 17:02:48.927: //63092/007A51461B26/CCAPI/ccCallNotify:
009596: Apr  9 17:02:48.927: //63093/007A51461B26/CCAPI/cc_api_get_called_ccm_detected:
009597: Apr  9 17:02:48.931: H225 NONSTD OUTGOING PDU ::=
      version 2
        iei 28
        rawMesg '1C269E8100036774640000001B414E4D2C0D0A50...'H
009598: Apr  9 17:02:48.931: H225 NONSTD OUTGOING ENCODE BUFFER::= 60010200011C281C269E8100036774640000001B414E4D2C0D0A50524E2C6973646E2A2C2C4E492A2A2A2C0D0A0D0A
009599: Apr  9 17:02:48.931:
009600: Apr  9 17:02:48.931: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body connect :
            ip '0AD20804'H
            port 41488
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
          callIdentifier
          multipleCalls FALSE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '60010200011C281C269E8100036774640000001B...'H
          tunnelledProtocolID
              protocolType "gtd"
          messageContent
            '414E4D2C0D0A50524E2C6973646E2A2C2C4E492A...'H
009601: Apr  9 17:02:48.931: H225.0 OUTGOING ENCODE BUFFER::= 22C0060008914A0004000AD20804A2102800B500001240013C05010000007A5146AD4941161B260F010AD255231D0C001100007A5146AD4941161B260F010AD255230100010010A80100360140B50000122F60010200011C281C269E8100036774640000001B414E4D2C0D0A50524E2C6973646E2A2C2C4E492A2A2A2C0D0A0D0A224204677464011B414E4D2C0D0A50524E2C6973646E2A2C2C4E492A2A2A2C0D0A0D0A
009602: Apr  9 17:02:48.931:
009603: Apr  9 17:02:48.931: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
009604: Apr  9 17:02:48.935: H225.0 OUTGOING ENCODE BUFFER::= 28501900060008914A000400007A5146AD4941161B260F010AD2552310800100
009605: Apr  9 17:02:48.935:
009606: Apr  9 17:02:49.019: //63067/D969B2AFA4DA/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x31FAED5C, Call Id=63067
009607: Apr  9 17:02:49.019: //63067/D969B2AFA4DA/CCAPI/cc_api_call_disconnected:
009608: Apr  9 17:02:49.019: //63067/D969B2AFA4DA/CCAPI/ccConferenceDestroy:
   Conference Id=0x78DE, Tag=0x0
009609: Apr  9 17:02:49.019: //63067/D969B2AFA4DA/CCAPI/ccConferenceDestroy:
009610: Apr  9 17:02:49.019: confID:0x78DE; callEntry1 callID1:0xF65B, type:6; callEntry2 callID2:0xF65E, type:1
009611: Apr  9 17:02:49.019: //63067/D969B2AFA4DA/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x78DE, Source Interface=0x31FAED5C, Source Call Id=63067,
   Destination Call Id=63070, Disposition=0x0, Tag=0x0
009612: Apr  9 17:02:49.019: //63070/D969B2AFA4DA/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x78DE, Source Interface=0x317EF024, Source Call Id=63070,
   Destination Call Id=63067, Disposition=0x0, Tag=0x0
009613: Apr  9 17:02:49.019: //63067/D969B2AFA4DA/CCAPI/cc_generic_bridge_done:
009614: Apr  9 17:02:49.019: //63067/D969B2AFA4DA/CCAPI/ccCallDisconnect:
009615: Apr  9 17:02:49.019: //63067/D969B2AFA4DA/CCAPI/ccCallDisconnect:
009616: Apr  9 17:02:49.019: //63067/D969B2AFA4DA/CCAPI/cc_api_get_transfer_info:
009617: Apr  9 17:02:49.019: //63070/D969B2AFA4DA/CCAPI/ccCallDisconnect:
009618: Apr  9 17:02:49.019: //63070/D969B2AFA4DA/CCAPI/ccCallDisconnect:
009619: Apr  9 17:02:49.019: //63070/D969B2AFA4DA/CCAPI/cc_api_get_transfer_info:
009620: Apr  9 17:02:49.023: //63070/D969B2AFA4DA/CCAPI/cc_api_get_transfer_info:
009621: Apr  9 17:02:49.023: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          callIdentifier
            guid 'D969B2AFA06D11E2A4DCF54F6D1A6205'H
        h245Tunneling FALSE
009622: Apr  9 17:02:49.027: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A000411001100D969B2AFA06D11E2A4DCF54F6D1A620510800100
009623: Apr  9 17:02:49.027:
009624: Apr  9 17:02:49.027: //63070/D969B2AFA4DA/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x317EF024, Tag=0x0, Call Id=63070,
009625: Apr  9 17:02:49.027: //63070/D969B2AFA4DA/CCAPI/cc_api_call_disconnect_done:
009626: Apr  9 17:02:49.027: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
009627: Apr  9 17:02:49.027: :cc_free_feature_vsa freeing 4110A250
009628: Apr  9 17:02:49.027: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
009629: Apr  9 17:02:49.027:  vsacount in free is 43
009630: Apr  9 17:02:49.439: //63067/D969B2AFA4DA/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x31FAED5C, Tag=0x0, Call Id=63067,
009631: Apr  9 17:02:49.439: //63067/D969B2AFA4DA/CCAPI/cc_api_call_disconnect_done:
009632: Apr  9 17:02:49.439: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
009633: Apr  9 17:02:49.439: :cc_free_feature_vsa freeing 4110A4F0
009634: Apr  9 17:02:49.439: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
009635: Apr  9 17:02:49.439:  vsacount in free is 42
009636: Apr  9 17:02:53.271: //63044/9BE615BDA4AB/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x4264027C, Call Id=63044
009637: Apr  9 17:02:53.271: //63044/9BE615BDA4AB/CCAPI/cc_api_call_disconnected:
009638: Apr  9 17:02:53.271: //63044/9BE615BDA4AB/CCAPI/ccConferenceDestroy:
   Conference Id=0x78D2, Tag=0x0
009639: Apr  9 17:02:53.271: //63044/9BE615BDA4AB/CCAPI/ccConferenceDestroy:
009640: Apr  9 17:02:53.271: confID:0x78D2; callEntry1 callID1:0xF644, type:6; callEntry2 callID2:0xF646, type:1
009641: Apr  9 17:02:53.271: //63044/9BE615BDA4AB/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x78D2, Source Interface=0x4264027C, Source Call Id=63044,
   Destination Call Id=63046, Disposition=0x0, Tag=0x0
009642: Apr  9 17:02:53.271: //63046/9BE615BDA4AB/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x78D2, Source Interface=0x317EF024, Source Call Id=63046,
   Destination Call Id=63044, Disposition=0x0, Tag=0x0
009643: Apr  9 17:02:53.271: //63044/9BE615BDA4AB/CCAPI/cc_generic_bridge_done:
009644: Apr  9 17:02:53.271: //63044/9BE615BDA4AB/CCAPI/ccCallDisconnect:
009645: Apr  9 17:02:53.271: //63044/9BE615BDA4AB/CCAPI/ccCallDisconnect:
009646: Apr  9 17:02:53.271: //63044/9BE615BDA4AB/CCAPI/cc_api_get_transfer_info:
009647: Apr  9 17:02:53.271: //63046/9BE615BDA4AB/CCAPI/ccCallDisconnect:
009648: Apr  9 17:02:53.271: //63046/9BE615BDA4AB/CCAPI/ccCallDisconnect:
009649: Apr  9 17:02:53.271: //63046/9BE615BDA4AB/CCAPI/cc_api_get_transfer_info:
009650: Apr  9 17:02:53.279: //63046/9BE615BDA4AB/CCAPI/cc_api_get_transfer_info:
009651: Apr  9 17:02:53.279: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          callIdentifier
            guid '9BE615BDA06D11E2A4ADF54F6D1A6205'H
        h245Tunneling FALSE
009652: Apr  9 17:02:53.279: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A0004110011009BE615BDA06D11E2A4ADF54F6D1A620510800100
009653: Apr  9 17:02:53.279:
009654: Apr  9 17:02:53.279: //63046/9BE615BDA4AB/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x317EF024, Tag=0x0, Call Id=63046,
009655: Apr  9 17:02:53.283: //63046/9BE615BDA4AB/CCAPI/cc_api_call_disconnect_done:
009656: Apr  9 17:02:53.283: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
009657: Apr  9 17:02:53.283: :cc_free_feature_vsa freeing 4110C2B0
009658: Apr  9 17:02:53.283: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
009659: Apr  9 17:02:53.283:  vsacount in free is 41
009660: Apr  9 17:02:53.695: //63044/9BE615BDA4AB/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4264027C, Tag=0x0, Call Id=63044,
009661: Apr  9 17:02:53.695: //63044/9BE615BDA4AB/CCAPI/cc_api_call_disconnect_done:
009662: Apr  9 17:02:53.695: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
009663: Apr  9 17:02:53.695: :cc_free_feature_vsa freeing 4110B4B0
009664: Apr  9 17:02:53.695: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
009665: Apr  9 17:02:53.695:  vsacount in free is 40
009666: Apr  9 17:02:53.987: //63045/9E86B001A4AF/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 1 to dstCallId 0xF647
009667: Apr  9 17:02:53.987: //63045/9E86B001A4AF/CCAPI/cc_relay_digit_begin_for_3way_conference:
009668: Apr  9 17:02:54.019: //63047/9E86B001A4AF/CCAPI/cc_api_caps_ind:
   Destination Interface=0x31FBB274, Destination Call Id=63045, Source Call Id=63047,
009669: Apr  9 17:02:54.019: //63047/9E86B001A4AF/CCAPI/cc_api_caps_ind:
009670: Apr  9 17:02:54.019: //63047/9E86B001A4AF/CCAPI/cc_api_caps_ack:
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=15722)
009671: Apr  9 17:02:54.019: //63045/9E86B001A4AF/CCAPI/cc_api_caps_ack:
   Destination Interface=0x317EF024, Destination Call Id=63047, Source Call Id=63045,
009672: Apr  9 17:02:54.019: //63045/9E86B001A4AF/CCAPI/cc_api_voice_mode_event:
   Call Id=63045
009673: Apr  9 17:02:54.019: //63045/9E86B001A4AF/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x300FE200)cch323_ip_best_local_address: IP 10.210.8.4 found for bound IDB GigabitEthernet0/0
009674: Apr  9 17:02:54.095: //63045/9E86B001A4AF/CCAPI/cc_api_call_digit_end:
009675: Apr  9 17:02:54.095: //63045/9E86B001A4AF/CCAPI/cc_relay_digit_end_for_3way_conference:
009676: Apr  9 17:02:54.679: //63081/EE91EE4FA4F7/CCAPI/cc_api_caps_ind:
   Destination Interface=0x31FBB274, Destination Call Id=63078, Source Call Id=63081,
009677: Apr  9 17:02:54.679: //63081/EE91EE4FA4F7/CCAPI/cc_api_caps_ind:
009678: Apr  9 17:02:54.679: //63081/EE91EE4FA4F7/CCAPI/cc_api_caps_ack:
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=11982)
009679: Apr  9 17:02:54.679: //63078/EE91EE4FA4F7/CCAPI/cc_api_caps_ack:
   Destination Interface=0x317EF024, Destination Call Id=63081, Source Call Id=63078,
009680: Apr  9 17:02:54.679: //63078/EE91EE4FA4F7/CCAPI/cc_api_voice_mode_event:
   Call Id=63078
009681: Apr  9 17:02:54.679: //63078/EE91EE4FA4F7/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x300FCD90)cch323_ip_best_local_address: IP 10.210.8.4 found for bound IDB GigabitEthernet0/0
009682: Apr  9 17:02:55.859: //-1/285D66B7A510/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
009683: Apr  9 17:02:55.859: //-1/285D66B7A510/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x4264027C, Call Info(
   Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=100, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
009684: Apr  9 17:02:55.859: //-1/285D66B7A510/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
009685: Apr  9 17:02:55.859: //-1/285D66B7A510/CCAPI/ccCheckClipClir:
   Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
009686: Apr  9 17:02:55.859: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
009687: Apr  9 17:02:55.859: :cc_get_feature_vsa malloc success
009688: Apr  9 17:02:55.859: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
009689: Apr  9 17:02:55.859:  cc_get_feature_vsa count is 41
009690: Apr  9 17:02:55.859: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
009691: Apr  9 17:02:55.859: :FEATURE_VSA attributes are: feature_name:0,feature_time:1091613880,feature_id:63092
009692: Apr  9 17:02:55.859: //63094/285D66B7A510/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
009693: Apr  9 17:02:55.859: //63094/285D66B7A510/CCAPI/cc_process_call_setup_ind:
   Event=0x41CDDEF8
009694: Apr  9 17:02:55.859: //63094/285D66B7A510/CCAPI/ccCallSetContext:
   Context=0x410F6558
009695: Apr  9 17:02:55.859: //63094/285D66B7A510/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 63094 with tag 100 to app "_ManagedAppProcess_Default"
009696: Apr  9 17:02:55.863: //63094/285D66B7A510/CCAPI/ccCallSetupAck:
   Call Id=63094
009697: Apr  9 17:02:55.863: //63094/285D66B7A510/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
009698: Apr  9 17:02:55.863: //63094/285D66B7A510/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=63094
009699: Apr  9 17:02:55.863: //63094/285D66B7A510/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
009700: Apr  9 17:02:55.863: //63094/285D66B7A510/CCAPI/ccSetDigitTimeouts:
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
009701: Apr  9 17:02:55.863: //63094/285D66B7A510/CCAPI/ccCallReportDigits:
   (callID=0xF676, digit_event=0x1, enable=TRUE, consume=FALSE)
009702: Apr  9 17:02:55.863: //63094/285D66B7A510/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=63094
009703: Apr  9 17:02:55.863: //63094/285D66B7A510/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x4264027C, callID=0xF676, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
009704: Apr  9 17:02:55.863: //63094/285D66B7A510/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x4264027C, Call Id=63094
009705: Apr  9 17:02:55.863: //63094/285D66B7A510/CCAPI/cc_api_call_report_digits_done:
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
009706: Apr  9 17:02:56.103: //63055/C578BC32A4C2/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x31FBB274, Call Id=63055
009707: Apr  9 17:02:56.103: //63055/C578BC32A4C2/CCAPI/cc_api_call_disconnected:
009708: Apr  9 17:02:56.103: //63055/C578BC32A4C2/CCAPI/ccConferenceDestroy:
   Conference Id=0x78D8, Tag=0x0
009709: Apr  9 17:02:56.103: //63055/C578BC32A4C2/CCAPI/ccConferenceDestroy:
009710: Apr  9 17:02:56.103: confID:0x78D8; callEntry1 callID1:0xF64F, type:6; callEntry2 callID2:0xF656, type:1
009711: Apr  9 17:02:56.103: //63055/C578BC32A4C2/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x78D8, Source Interface=0x31FBB274, Source Call Id=63055,
   Destination Call Id=63062, Disposition=0x0, Tag=0x0
009712: Apr  9 17:02:56.103: //63062/C578BC32A4C2/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x78D8, Source Interface=0x317EF024, Source Call Id=63062,
   Destination Call Id=63055, Disposition=0x0, Tag=0x0
009713: Apr  9 17:02:56.103: //63055/C578BC32A4C2/CCAPI/cc_generic_bridge_done:
009714: Apr  9 17:02:56.103: //63055/C578BC32A4C2/CCAPI/ccCallDisconnect:
009715: Apr  9 17:02:56.103: //63055/C578BC32A4C2/CCAPI/ccCallDisconnect:
009716: Apr  9 17:02:56.103: //63055/C578BC32A4C2/CCAPI/cc_api_get_transfer_info:
009717: Apr  9 17:02:56.103: //63062/C578BC32A4C2/CCAPI/ccCallDisconnect:
009718: Apr  9 17:02:56.103: //63062/C578BC32A4C2/CCAPI/ccCallDisconnect:
009719: Apr  9 17:02:56.103: //63062/C578BC32A4C2/CCAPI/cc_api_get_transfer_info:
009720: Apr  9 17:02:56.111: //63062/C578BC32A4C2/CCAPI/cc_api_get_transfer_info:
009721: Apr  9 17:02:56.111: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          callIdentifier
            guid 'C578BC32A06D11E2A4C4F54F6D1A6205'H
        h245Tunneling FALSE
009722: Apr  9 17:02:56.111: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A000411001100C578BC32A06D11E2A4C4F54F6D1A620510800100
009723: Apr  9 17:02:56.111:
009724: Apr  9 17:02:56.111: //63062/C578BC32A4C2/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x317EF024, Tag=0x0, Call Id=63062,
009725: Apr  9 17:02:56.111: //63062/C578BC32A4C2/CCAPI/cc_api_call_disconnect_done:
009726: Apr  9 17:02:56.111: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
009727: Apr  9 17:02:56.111: :cc_free_feature_vsa freeing 41109FB0
009728: Apr  9 17:02:56.111: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
009729: Apr  9 17:02:56.111:  vsacount in free is 40
009730: Apr  9 17:02:56.311: //63094/285D66B7A510/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x1, Destination Call Id=-1,
   Source Call Id=63094, Digit=3, DigitBeginFlags=0x1,
   Rtp Timestamp=0x93FD52CD, Rtp Expiration=0x0
009731: Apr  9 17:02:56.363: //63094/285D66B7A510/CCAPI/cc_api_call_digit_end:
   Source Call Id=63094, Digit=3, Duration=87,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
009732: Apr  9 17:02:56.363: //63094/285D66B7A510/CCAPI/cc_api_call_digit_end:
   Call Entry(Handoff Depth=0)
009733: Apr  9 17:02:56.431: //63094/285D66B7A510/CCAPI/cc_api_call_digit_begin:
   Source Call Id=63094, Digit=2, DigitBeginFlags=0x1,
   Rtp Timestamp=0x93FD568D, Rtp Expiration=0x0
009734: Apr  9 17:02:56.467: ISDN Se0/3/0:23 Q931: RX <- SETUP pd = 8  callref = 0x7442
        Bearer Capability i = 0x9090A2
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
        Channel ID i = 0xA18387
                Preferred, Channel 7
        Facility i = 0x9F8B0100A117020101020100800F43414C49464F524E49412020202020
                0xA117020101020100800F43414C49464F524E49412020202020
                        Invoke Id = 1
                                Name = CALIFORNIA
        Progress Ind i = 0x8283 - Origination address is non-ISDN
        Calling Party Number i = 0x2183, '5598649455'
        Called Party Number i = 0x80, '3202'
                Plan:Unknown, Type:Unknown
009735: Apr  9 17:02:56.467: ISDN Se0/3/0:23 Q931: Received SETUP  callref = 0xF442 callID = 0x288B switch = primary-ni interface = User
009736: Apr  9 17:02:56.471: //-1/28BA2D93A88C/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=5598649455
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=3202
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
009737: Apr  9 17:02:56.471: //-1/28BA2D93A88C/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x425D5E0C, Call Info(
   Calling Number=5598649455,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=3202(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=100, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
009738: Apr  9 17:02:56.471: //-1/28BA2D93A88C/CCAPI/ccCheckClipClir:
   In: Calling Number=5598649455(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
009739: Apr  9 17:02:56.471: //-1/28BA2D93A88C/CCAPI/ccCheckClipClir:
   Out: Calling Number=5598649455(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
009740: Apr  9 17:02:56.471: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
009741: Apr  9 17:02:56.471: :cc_get_feature_vsa malloc success
009742: Apr  9 17:02:56.471: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
009743: Apr  9 17:02:56.471:  cc_get_feature_vsa count is 41
009744: Apr  9 17:02:56.471: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
009745: Apr  9 17:02:56.471: :FEATURE_VSA attributes are: feature_name:0,feature_time:1091608504,feature_id:63093
009746: Apr  9 17:02:56.471: //63095/28BA2D93A88C/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=5598649455(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=3202(TON=Unknown, NPI=Unknown))
009747: Apr  9 17:02:56.471: //63095/28BA2D93A88C/CCAPI/cc_process_call_setup_ind:
   Event=0x41CDDEF8
009748: Apr  9 17:02:56.471: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 3202
009749: Apr  9 17:02:56.471: //63095/28BA2D93A88C/CCAPI/ccCallSetContext:
   Context=0x400F69C4
009750: Apr  9 17:02:56.471: //63095/28BA2D93A88C/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 63095 with tag 100 to app "_ManagedAppProcess_Default"
009751: Apr  9 17:02:56.475: //63095/28BA2D93A88C/CCAPI/ccCallProceeding:
009752: Apr  9 17:02:56.475: //63095/28BA2D93A88C/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=3100, Params=0x41036644, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
009753: Apr  9 17:02:56.475: //63095/28BA2D93A88C/CCAPI/ccCheckClipClir:
009754: Apr  9 17:02:56.475: //63095/28BA2D93A88C/CCAPI/ccCheckClipClir:
009755: Apr  9 17:02:56.479: //63095/28BA2D93A88C/CCAPI/ccCallSetupRequest:
   Destination Pattern=3...T, Called Number=3202, Digit Strip=FALSE
009756: Apr  9 17:02:56.479: //63095/28BA2D93A88C/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=CALIFORNIA
   Account Number=, Final Destination Flag=TRUE,
   Guid=28BA2D93-A06E-11E2-A88C-F866F2F55220, Outgoing Dial-peer=3100
009757: Apr  9 17:02:56.479: //63095/28BA2D93A88C/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=3202
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
009758: Apr  9 17:02:56.479: //63095/28BA2D93A88C/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x317EF024, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=5598649455,(Calling Name=CALIFORNIA     )(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=3202(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=3100, Call Count On=FALSE,
009759: Apr  9 17:02:56.479: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
009760: Apr  9 17:02:56.479: :cc_get_feature_vsa malloc success
009761: Apr  9 17:02:56.479: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
009762: Apr  9 17:02:56.479:  cc_get_feature_vsa count is 42
009763: Apr  9 17:02:56.479: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
009764: Apr  9 17:02:56.479: :FEATURE_VSA attributes are: feature_name:0,feature_time:1091617464,feature_id:63094
009765: Apr  9 17:02:56.479: //63096/28BA2D93A88C/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
009766: Apr  9 17:02:56.479: //63096/28BA2D93A88C/CCAPI/ccCallSetContext:
   Context=0x410365F4
009767: Apr  9 17:02:56.479: //63095/28BA2D93A88C/CCAPI/ccSaveDialpeerTag:
009768: Apr  9 17:02:56.479: //63096/28BA2D93A88C/CCAPI/ccGetMediaClassTag:
   media class tag 0
009769: Apr  9 17:02:56.479: //63096/28BA2D93A88C/CCAPI/ccSetMediaclassIp2ipTags:
   media class tags set: NR 0, ASP 0
009770: Apr  9 17:02:56.479: //63095/28BA2D93A88C/CCAPI/ccSetMediaclassIp2ipTags:
009771: Apr  9 17:02:56.479: //63096/28BA2D93A88C/CCAPI/ccGet_xc_nr_asp_info:
   media class tags: NR 0, ASP 0
009772: Apr  9 17:02:56.479: //63095/28BA2D93A88C/CCAPI/ccGet_xc_nr_asp_info:
   media class tags: NR 0, ASP 0cch323_ip_best_local_address: IP 10.210.8.4 found for bound IDB GigabitEthernet0/0cch323_ip_best_local_address: IP 10.210.8.4 found for bound IDB GigabitEthernet0/0
009773: Apr  9 17:02:56.483: //63094/285D66B7A510/CCAPI/cc_api_call_digit_end:
   Source Call Id=63094, Digit=2, Duration=87,
009774: Apr  9 17:02:56.483: //63094/285D66B7A510/CCAPI/cc_api_call_digit_end:
009775: Apr  9 17:02:56.483: ISDN Se0/3/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0xF442
        Channel ID i = 0xA98387
                Exclusive, Channel 7cch323_ip_best_local_address: IP 10.210.8.4 found for bound IDB GigabitEthernet0/0
009776: Apr  9 17:02:56.483: H225 NONSTD OUTGOING PDU ::=
      version 2
        iei 4
        rawMesg '04039090A21803A18387001D9F8B0100A1170201...'H
      progIndParam progIndIEinfo :
        progIndIE '00000003'H
009777: Apr  9 17:02:56.487: H225 NONSTD OUTGOING ENCODE BUFFER::= 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
009778: Apr  9 17:02:56.487:
009779: Apr  9 17:02:56.487: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body setup :
          sourceInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
          activeMC FALSE
          conferenceID '28BA2D93A06E11E2A88CF866F2F55220'H
            ip '0AD20804'H
            port 47791
          callIdentifier
            guid '28BAC9BBA06E11E2A516F54F6D1A6205'H
          fastStart
            '0000000D4001800B050001000AD2080473AF00'H,
            '400000060401004D40018012150001000AD20804...'H,
            '0000010C6013800B050001000AD2080473AF00'H,
            '400001060401004C60138012150001000AD20804...'H
          multipleCalls TRUE
          maintainConnection TRUE
          symmetricOperationRequired NULL
        h245Tunneling TRUE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data 'E00102000104814E04039090A21803A18387001D...'H
          tunnelledProtocolID
              protocolType "gtd"
          messageContent
            '49414D2C0D0A50524E2C6973646E2A2C2C4E492A...'H
009780: Apr  9 17:02:56.487: H225.0 OUTGOING ENCODE BUFFER::= 2080060008914A00042800B500001240013C0501000028BA2D93A06E11E2A88CF866F2F5522000CD1D820007000AD20804BAAF110028BAC9BBA06E11E2A516F54F6D1A62056704130000000D4001800B050001000AD2080473AF001E400000060401004D40018012150001000AD2080473AE000AD2080473AF00130000010C6013800B050001000AD2080473AF001E400001060401004C60138012150001000AD2080473AE000AD2080473AF000100010001800180010010A8018081680140B50000128160E00102000104814E04039090A21803A18387001D9F8B0100A117020101020100800F43414C49464F524E494120202020201E0282836C0C218335353938363439343535700580333230320D8201089E810003677464000000FD49414D2C0D0A50524E2C6973646E2A2C2C4E492A2A2A2C0D0A5553492C726174652C632C332C632C310D0A5553492C6C6179312C756C61770D0A544D522C30320D0A43504E2C30302C2C752C333230320D0A43474E2C30342C2C312C792C342C353539383634393435350D0A4350432C30390D0A4643492C2C2C2C2C2C2C792C0D0A4743492C32386261326439336130366531316532613838636638363666326635353232300D0A47454E2C792C792C302C43414C49464F524E494120202020200D0A5546432C47454E2C352C66616368642C39663862303130300D0A5546432C47454E2C352C696E7064752C3032303130313032303130300D0A0D0A18800006000400000003810542046774640180FD49414D2C0D0A50524E2C6973646E2A2C2C4E492A2A2A2C0D0A5553492C726174652C632C332C632C310D0A5553492C6C6179312C756C61770D0A544D522C30320D0A43504E2C30302C2C752C333230320D0A43474E2C30342C2C312C792C342C353539383634393435350D0A4350432C30390D0A4643492C2C2C2C2C2C2C792C0D0A4743492C32386261326439336130366531316532613838636638363666326635353232300D0A47454E2C792C792C302C43414C49464F524E494120202020200D0A5546432C47454E2C352C66616368642C39663862303130300D0A5546432C47454E2C352C696E7064752C3032303130313032303130300D0A0D0A
009781: Apr  9 17:02:56.491:
009782: Apr  9 17:02:56.495: H225.0 INCOMING ENCODE BUFFER::= 2180060008914A000522C0B50000120F436973636F43616C6C4D616E6167657200310110C0110028BAC9BBA06E11E2A516F54F6D1A62050100010010A00100100140B500001209820400000400010300
009783: Apr  9 17:02:56.495:
009784: Apr  9 17:02:56.495: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
          callIdentifier
          multipleCalls FALSE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '820400000400010300'H
009785: Apr  9 17:02:56.499: H225 NONSTD INCOMING ENCODE BUFFER::= 820400000400010300
009786: Apr  9 17:02:56.499:
009787: Apr  9 17:02:56.499: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
009788: Apr  9 17:02:56.499: //63096/28BA2D93A88C/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
009789: Apr  9 17:02:56.499: //63096/28BA2D93A88C/CCAPI/cc_api_call_proceeding:
   Interface=0x317EF024, Progress Indication=NULL(0)
009790: Apr  9 17:02:56.515: H225.0 INCOMING ENCODE BUFFER::= 2380060008914A000522C0B50000120F436973636F43616C6C4D616E61676572003101B0C000110028BAC9BBA06E11E2A516F54F6D1A62050100010010A00100100140B500001209820400000400010300
009791: Apr  9 17:02:56.515:
009792: Apr  9 17:02:56.515: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
          callIdentifier
          multipleCalls FALSE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
009793: Apr  9 17:02:56.515: H225 NONSTD INCOMING ENCODE BUFFER::= 820400000400010300
009794: Apr  9 17:02:56.515:
009795: Apr  9 17:02:56.515: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
009796: Apr  9 17:02:56.515: //63096/28BA2D93A88C/CCAPI/cc_api_set_called_ccm_detected:
009797: Apr  9 17:02:56.515: //63096/28BA2D93A88C/CCAPI/cc_api_set_delay_xport:
   CallInfo(delay xport=TRUE)
009798: Apr  9 17:02:56.515: //63096/28BA2D93A88C/CCAPI/cc_api_call_alert:
   Interface=0x317EF024, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
009799: Apr  9 17:02:56.515: //63096/28BA2D93A88C/CCAPI/cc_api_call_alert:
009800: Apr  9 17:02:56.515: H225.0 INCOMING ENCODE BUFFER::= 28501900060008914A00050028BAC9BBA06E11E2A516F54F6D1A620510800100
009801: Apr  9 17:02:56.515:
009802: Apr  9 17:02:56.515: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
009803: Apr  9 17:02:56.515: //63096/28BA2D93A88C/CCAPI/cc_api_set_called_ccm_detected:
009804: Apr  9 17:02:56.515: //63096/28BA2D93A88C/CCAPI/cc_api_call_notify:
   Data Bitmask=0x7, Interface=0x317EF024, Call Id=63096
009805: Apr  9 17:02:56.519: //63095/28BA2D93A88C/CCAPI/ccCallAlert:
009806: Apr  9 17:02:56.519: //63095/28BA2D93A88C/CCAPI/ccCallAlert:
009807: Apr  9 17:02:56.523: //63055/C578BC32A4C2/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x31FBB274, Tag=0x0, Call Id=63055,
009808: Apr  9 17:02:56.523: //63055/C578BC32A4C2/CCAPI/cc_api_call_disconnect_done:
009809: Apr  9 17:02:56.523: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
009810: Apr  9 17:02:56.523: :cc_free_feature_vsa freeing 411097D0
009811: Apr  9 17:02:56.523: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
009812: Apr  9 17:02:56.523:  vsacount in free is 41
009813: Apr  9 17:02:56.523: ISDN Se0/3/0:23 Q931: TX -> ALERTING pd = 8  callref = 0xF442
        Progress Ind i = 0x8188 - In-band info or appropriate now available
009814: Apr  9 17:02:56.523: H225.0 INCOMING ENCODE BUFFER::= 22C0060008914A0005000AD2080AE3B122C0B50000120F436973636F43616C6C4D616E6167657200310028BA2D93A06E11E2A88CF866F2F552201D0C00110028BAC9BBA06E11E2A516F54F6D1A62050100010010A00100120140B50000120B8204020004000103000100
009815: Apr  9 17:02:56.523:
009816: Apr  9 17:02:56.523: H225.0 INCOMING PDU ::=
      h323-uu-pdu
            ip '0AD2080A'H
            port 58289
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
          callIdentifier
          multipleCalls FALSE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '8204020004000103000100'H
009817: Apr  9 17:02:56.527: H225 NONSTD INCOMING ENCODE BUFFER::= 8204020004000103000100
009818: Apr  9 17:02:56.527:
009819: Apr  9 17:02:56.527: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
      videoCapableStatusParam
        isVideoCapable FALSE
009820: Apr  9 17:02:56.527: //63096/28BA2D93A88C/CCAPI/ccIsInfoRingback:
   Returning dpRingBack=0
009821: Apr  9 17:02:56.527: H225.0 INCOMING ENCODE BUFFER::= 28501900060008914A00050028BAC9BBA06E11E2A516F54F6D1A620510800100
009822: Apr  9 17:02:56.527:
009823: Apr  9 17:02:56.527: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
009824: Apr  9 17:02:56.527: //63096/28BA2D93A88C/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=FALSE)
009825: Apr  9 17:02:56.527: //63096/28BA2D93A88C/CCAPI/cc_api_get_ccm_detected:
   CallInfo(ccm detected=TRUE)
009826: Apr  9 17:02:56.527: //63095/28BA2D93A88C/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=63095cch323_ip_best_local_address: IP 10.210.8.4 found for bound IDB GigabitEthernet0/0
009827: Apr  9 17:02:56.543: //63096/28BA2D93A88C/CCAPI/cc_api_call_connected:
   Interface=0x317EF024, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
009828: Apr  9 17:02:56.543: //63096/28BA2D93A88C/CCAPI/cc_api_call_connected:
009829: Apr  9 17:02:56.543: //63096/28BA2D93A88C/CCAPI/cc_api_set_called_ccm_detected:
009830: Apr  9 17:02:56.543: //63096/28BA2D93A88C/CCAPI/cc_api_call_notify:
   Data Bitmask=0x5, Interface=0x317EF024, Call Id=63096
009831: Apr  9 17:02:56.543: //63095/28BA2D93A88C/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=63095
009832: Apr  9 17:02:56.543: //63095/28BA2D93A88C/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID1=0xF677, gcid=28BA2D93-A06E11E2-A88CF866-F2F55220, tag=0x0)
009833: Apr  9 17:02:56.543: //63096/28BA2D93A88C/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID2=0xF678, gcid=28BA2D93-A06E11E2-A88CF866-F2F55220, tag=0x0)
009834: Apr  9 17:02:56.543: //63095/28BA2D93A88C/CCAPI/ccConferenceCreate:
   Conference Id=0xFFFFFFFF, Call Id1=63095, Call Id2=63096, Tag=0x0
009835: Apr  9 17:02:56.543: //63095/28BA2D93A88C/CCAPI/cc_api_bridge_done:
   Conference Id=0x78EB, Source Interface=0x425D5E0C, Source Call Id=63095,
   Destination Call Id=63096, Disposition=0x0, Tag=0xFFFFFFFF
009894: Apr  9 17:02:56.887: //63072/E533E05AA4E5/CCAPI/cc_api_voice_mode_event:
   Call Id=63072
009895: Apr  9 17:02:56.887: //63072/E533E05AA4E5/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x410EEAB8)cch323_ip_best_local_address: IP 10.210.8.4 found for bound IDB GigabitEthernet0/0
009896: Apr  9 17:02:57.939: ISDN Se0/3/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x7440
        Cause i = 0x8490 - Normal call clearing
009897: Apr  9 17:02:57.939: ISDN Se0/3/0:23 Q931: TX -> RELEASE pd = 8  callref = 0xF440
009898: Apr  9 17:02:57.939: //63088/0FAF1281A88A/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x425D5E0C, Call Id=63088
009899: Apr  9 17:02:57.939: //63088/0FAF1281A88A/CCAPI/cc_api_call_disconnected:
009900: Apr  9 17:02:57.943: //63088/0FAF1281A88A/CCAPI/ccConferenceDestroy:
   Conference Id=0x78E8, Tag=0x0
009901: Apr  9 17:02:57.943: //63088/0FAF1281A88A/CCAPI/ccConferenceDestroy:
009902: Apr  9 17:02:57.943: confID:0x78E8; callEntry1 callID1:0xF670, type:6; callEntry2 callID2:0xF671, type:1
009903: Apr  9 17:02:57.943: //63088/0FAF1281A88A/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x78E8, Source Interface=0x425D5E0C, Source Call Id=63088,
   Destination Call Id=63089, Disposition=0x0, Tag=0x0
009904: Apr  9 17:02:57.943: //63089/0FAF1281A88A/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x78E8, Source Interface=0x317EF024, Source Call Id=63089,
   Destination Call Id=63088, Disposition=0x0, Tag=0x0
009905: Apr  9 17:02:57.943: //63088/0FAF1281A88A/CCAPI/cc_generic_bridge_done:
009906: Apr  9 17:02:57.943: //63088/0FAF1281A88A/CCAPI/ccCallDisconnect:
009907: Apr  9 17:02:57.943: //63088/0FAF1281A88A/CCAPI/ccCallDisconnect:
009908: Apr  9 17:02:57.943: //63088/0FAF1281A88A/CCAPI/cc_api_get_transfer_info:
009909: Apr  9 17:02:57.943: //63089/0FAF1281A88A/CCAPI/ccCallDisconnect:
009910: Apr  9 17:02:57.943: //63089/0FAF1281A88A/CCAPI/ccCallDisconnect:
009911: Apr  9 17:02:57.943: //63089/0FAF1281A88A/CCAPI/cc_api_get_transfer_info:
009912: Apr  9 17:02:57.951: //63089/0FAF1281A88A/CCAPI/cc_api_get_transfer_info:
009913: Apr  9 17:02:57.951: H225 NONSTD OUTGOING PDU ::=
      version 2
        iei 8
        rawMesg '080284901C269E8100036774640000001B52454C...'H
009914: Apr  9 17:02:57.951: H225 NONSTD OUTGOING ENCODE BUFFER::= 6001020001082C080284901C269E8100036774640000001B52454C2C0D0A50524E2C6973646E2A2C2C4E492A2A2A2C0D0A0D0A
009915: Apr  9 17:02:57.951:
009916: Apr  9 17:02:57.951: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          callIdentifier
            guid '0FAFAEA9A06E11E2A506F54F6D1A6205'H
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '6001020001082C080284901C269E810003677464...'H
          tunnelledProtocolID
              protocolType "gtd"
          messageContent
            '52454C2C0D0A50524E2C6973646E2A2C2C4E492A...'H
009917: Apr  9 17:02:57.951: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A0004110011000FAFAEA9A06E11E2A506F54F6D1A620510A801003A0140B5000012336001020001082C080284901C269E8100036774640000001B52454C2C0D0A50524E2C6973646E2A2C2C4E492A2A2A2C0D0A0D0A224204677464011B52454C2C0D0A50524E2C6973646E2A2C2C4E492A2A2A2C0D0A0D0A
009918: Apr  9 17:02:57.951:
009919: Apr  9 17:02:57.951: //63089/0FAF1281A88A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x317EF024, Tag=0x0, Call Id=63089,
009920: Apr  9 17:02:57.951: //63089/0FAF1281A88A/CCAPI/cc_api_call_disconnect_done:
009921: Apr  9 17:02:57.951: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
009922: Apr  9 17:02:57.951: :cc_free_feature_vsa freeing 4110C390
009923: Apr  9 17:02:57.951: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
009924: Apr  9 17:02:57.951:  vsacount in free is 40
009925: Apr  9 17:02:57.959: ISDN Se0/3/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x7440
009926: Apr  9 17:02:57.967: //63088/0FAF1281A88A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x425D5E0C, Tag=0x0, Call Id=63088,
009927: Apr  9 17:02:57.967: //63088/0FAF1281A88A/CCAPI/cc_api_call_disconnect_done:
009928: Apr  9 17:02:57.967: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
009929: Apr  9 17:02:57.967: :cc_free_feature_vsa freeing 411089D0
009930: Apr  9 17:02:57.967: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
009931: Apr  9 17:02:57.967:  vsacount in free is 39
009932: Apr  9 17:02:58.247: H225.0 INCOMING ENCODE BUFFER::= 2480060008914A00050B001100E533E05AA06D11E2A4E7F54F6D1A620510800100
009933: Apr  9 17:02:58.247:
009934: Apr  9 17:02:58.247: H225.0 INCOMING PDU ::=
      h323-uu-pdu
        h323-message-body information :
          callIdentifier
            guid 'E533E05AA06D11E2A4E7F54F6D1A6205'H
        h245Tunneling FALSE
009935: Apr  9 17:02:58.247: //63076/E533E05AA4E5/CCAPI/cc_api_call_userinfo:
   Interface=0x317EF024, Signal Indication=TONES OFF(63)
009936: Apr  9 17:02:58.247: //63072/E533E05AA4E5/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=63072
009937: Apr  9 17:02:58.251: H225.0 INCOMING ENCODE BUFFER::= 2480060008914A00050B001100E533E05AA06D11E2A4E7F54F6D1A620510800100
009938: Apr  9 17:02:58.251:
009939: Apr  9 17:02:58.251: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
009940: Apr  9 17:02:58.251: //63076/E533E05AA4E5/CCAPI/cc_api_call_userinfo:
009941: Apr  9 17:02:58.251: //63072/E533E05AA4E5/CCAPI/ccGenerateToneInfo:
009942: Apr  9 17:02:58.251: H225.0 INCOMING ENCODE BUFFER::= 28501900060008914A000500E533E05AA06D11E2A4E7F54F6D1A620510800100
009943: Apr  9 17:02:58.251:
009944: Apr  9 17:02:58.251: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
009945: Apr  9 17:02:58.251: //63076/E533E05AA4E5/CCAPI/cc_api_set_called_ccm_detected:
009946: Apr  9 17:02:58.251: //63076/E533E05AA4E5/CCAPI/cc_api_call_notify:
   Data Bitmask=0x7, Interface=0x317EF024, Call Id=63076
009947: Apr  9 17:02:58.251: //63076/E533E05AA4E5/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
009948: Apr  9 17:02:58.251: //63076/E533E05AA4E5/CCAPI/cc_api_get_ccm_detected:
009949: Apr  9 17:02:58.251: //63072/E533E05AA4E5/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=63072
009950: Apr  9 17:02:58.255: H225.0 INCOMING ENCODE BUFFER::= 2480060008914A00050B001100E533E05AA06D11E2A4E7F54F6D1A620510800100
009951: Apr  9 17:02:58.255:
009952: Apr  9 17:02:58.255: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
009953: Apr  9 17:02:58.259: //63076/E533E05AA4E5/CCAPI/cc_api_call_userinfo:
009954: Apr  9 17:02:58.259: H225.0 INCOMING ENCODE BUFFER::= 28501900060008914A000500E533E05AA06D11E2A4E7F54F6D1A620510800100
009955: Apr  9 17:02:58.259:
009956: Apr  9 17:02:58.259: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
009957: Apr  9 17:02:58.259: //63076/E533E05AA4E5/CCAPI/cc_api_set_called_ccm_detected:
009958: Apr  9 17:02:58.259: //63076/E533E05AA4E5/CCAPI/cc_api_call_notify:
009959: Apr  9 17:02:58.259: //63072/E533E05AA4E5/CCAPI/ccGenerateToneInfo:
009960: Apr  9 17:02:58.263: //63076/E533E05AA4E5/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
009961: Apr  9 17:02:58.263: //63076/E533E05AA4E5/CCAPI/cc_api_get_ccm_detected:
009962: Apr  9 17:02:58.263: //63072/E533E05AA4E5/CCAPI/ccCallNotify:
009963: Apr  9 17:02:58.271: //63076/E533E05AA4E5/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4264027C, Destination Call Id=63072, Source Call Id=63076,
009964: Apr  9 17:02:58.271: //63076/E533E05AA4E5/CCAPI/cc_api_caps_ind:
009965: Apr  9 17:02:58.271: //63076/E533E05AA4E5/CCAPI/cc_api_caps_ack:
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=5881)
009966: Apr  9 17:02:58.271: //63072/E533E05AA4E5/CCAPI/cc_api_caps_ack:
   Destination Interface=0x317EF024, Destination Call Id=63076, Source Call Id=63072,
009967: Apr  9 17:02:58.271: //63072/E533E05AA4E5/CCAPI/cc_api_voice_mode_event:
   Call Id=63072
CDCVG2921#
CDCVG2921#
CDCVG2921#
009968: Apr  9 17:02:58.271: //63072/E533E05AA4E5/CCAPI/cc_api_voice_mode_event:
CDCVG2921#
009969: Apr  9 17:03:00.439: H225.0 INCOMING ENCODE BUFFER::= 2480060008914A00050B001100EE91EE4FA06D11E2A4F9F54F6D1A620510800100
009970: Apr  9 17:03:00.439:
009971: Apr  9 17:03:00.439: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          callIdentifier
            guid 'EE91EE4FA06D11E2A4F9F54F6D1A6205'H
        h245Tunneling FALSE
009972: Apr  9 17:03:00.439: //63081/EE91EE4FA4F7/CCAPI/cc_api_call_userinfo:
009973: Apr  9 17:03:00.439: //63078/EE91EE4FA4F7/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=63078
009974: Apr  9 17:03:00.439: H225.0 INCOMING ENCODE BUFFER::= 2480060008914A00050B001100EE91EE4FA06D11E2A4F9F54F6D1A620510800100
009975: Apr  9 17:03:00.443:
009976: Apr  9 17:03:00.443: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
009977: Apr  9 17:03:00.443: //63081/EE91EE4FA4F7/CCAPI/cc_api_call_userinfo:
009978: Apr  9 17:03:00.443: H225.0 INCOMING ENCODE BUFFER::= 28501900060008914A000500EE91EE4FA06D11E2A4F9F54F6D1A620510800100
009979: Apr  9 17:03:00.443:
009980: Apr  9 17:03:00.443: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
009981: Apr  9 17:03:00.443: //63081/EE91EE4FA4F7/CCAPI/cc_api_set_called_ccm_detected:
009982: Apr  9 17:03:00.443: //63081/EE91EE4FA4F7/CCAPI/cc_api_call_notify:
   Data Bitmask=0x5, Interface=0x317EF024, Call Id=63081
009983: Apr  9 17:03:00.443: //63078/EE91EE4FA4F7/CCAPI/ccGenerateToneInfo:
009984: Apr  9 17:03:00.443: //63081/EE91EE4FA4F7/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
009985: Apr  9 17:03:00.443: //63081/EE91EE4FA4F7/CCAPI/cc_api_get_ccm_detected:
009986: Apr  9 17:03:00.443: //63078/EE91EE4FA4F7/CCAPI/ccCallNotify:
   Data Bitmask=0x5, Call Id=63078
009987: Apr  9 17:03:00.459: //63081/EE91EE4FA4F7/CCAPI/cc_api_caps_ind:
009988: Apr  9 17:03:00.459: //63081/EE91EE4FA4F7/CCAPI/cc_api_caps_ind:
009989: Apr  9 17:03:00.459: //63081/EE91EE4FA4F7/CCAPI/cc_api_caps_ack:
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=11982)cch323_ip_best_local_address: IP 10.210.8.4 found for bound IDB GigabitEthernet0/0
009990: Apr  9 17:03:00.459: //63078/EE91EE4FA4F7/CCAPI/cc_api_caps_ack:
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=11982)no
009991: Apr  9 17:03:00.459: //63078/EE91EE4FA4F7/CCAPI/cc_api_voice_mode_event:
   Call Id=63078
009992: Apr  9 17:03:00.459: //63078/EE91EE4FA4F7/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x300FCD90) debug a
009993: Apr  9 17:03:02.215: H225.0 INCOMING ENCODE BUFFER::= 20B0060008914A000501401F00520075007400680020004400690061007A0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000022C0B50000120F436973636F43616C6C4D616E616765720031000105004548C48C9450802C3855C64941161C2610010AD2A14C00D50D800007000AD2080A06B81100802C3855C64941161C2610010AD2A14C018001000100010010A00100250140B50000121E9010740E00008F3132313539313233393132204002040001030003000103
009994: Apr  9 17:03:02.215:
009995: Apr  9 17:03:02.215: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          sourceAddress
            h323-ID : {"Ruth Diaz..."}
          sourceInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              productId '436973636F43616C6C4D616E61676572'H
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
          destinationAddress
            dialedDigits : "12159159612"
          activeMC FALSE
          conferenceID '802C3855C64941161C2610010AD2A14C'H
          conferenceGoal create : NULL
          callType pointToPoint : NULL
          sourceCallSignalAddress ipAddress :
            ip '0AD2080A'H
            port 1720
          callIdentifier
            guid '802C3855C64941161C2610010AD2A14C'H
          mediaWaitForConnect TRUE
          canOverlapSend FALSE
          multipleCalls FALSE
          maintainConnection FALSE
        h245Tunneling FALSE
        nonStandardControl
            nonStandardIdentifier h221NonStandard :
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '9010740E00008F31323135393132333931322040...'H
This is clearly a CUCM issue ..
The logs show that the ANI presented is this...
cisco-ani=12155553000
we will neeed to look at CUCM logs to figure out whats going on
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Hi.
If you are using Route List and Route Group, check there if you are doing some kind of digit manipulation , and also check H323 gateway configuration page.
A show run of your Gateway would be useful.
Please attach it and we' ll have a look
Carlo
Please rate all helpful posts "The more you help the more you learn"
