10-10-2011 04:49 AM - edited 03-16-2019 07:24 AM
Verified that the trunk registers to the secondary Sip-Server when the primary is unavailable, however; outbound calls are still directed to the primary and subsequently fail (404 not found). Inbound calls complete successfully.
Cisco IAD 2431
C2430-is-mz.124-11.xw7.bin
dial-peer voice 100 voip
destination-pattern xxxx
voice-class codec 711
session protocol sipv2
session target sip-server
sip-ua
no remote-party-id
set pstn-cause 47 sip-status 486
retry invite 2
retry response 3
retry bye 3
retry prack 6
timers expires 300000
registrar dns:FQDN expires 3600
sip-server dns:FQDN
10-10-2011 06:48 AM
John,
The issue here looks to be DNS related.
Your dial peer
points at the SIP-SERVER
The SIP-SERVER is DNS contolled
sip-ua
no remote-party-id
retry invite 2
retry response 3
retry bye 3
retry prack 6
sip-server dns:FQDN
You could try just using IP addrsses and 2 dial peers
session target ipv4:10.10.10.100
voice-class sip options-keepalive up 30 down 5
peference 1
dial-peer voice 200 voip
session target ipv4:10.10.10.200
peference 2
This will give preference to the 1st dial peer and conrinually check for the remote end being alive
When it fails the 2nd dial peer would kick in.
Alex
06-24-2013 11:17 AM
Hey Guys,
Is this still the best way to do this? I only have a single sip server defined in my configuration and was wondering how to setup a backup sip server in case the primary goes down.
sip-ua
no remote-party-id
retry invite 2
retry register 10
timers connect 100
sip-server ipv4:4.XX.XX.13:5070
dial-peer voice 450 voip
translation-profile outgoing SIPDIVERSION_OUT
destination-pattern 011T
voice-class sip profiles 1
dtmf-relay rtp-nte
codec g711ulaw
fax-relay ecm disable
fax rate 9600
fax nsf 000000
ip qos dscp cs5 media
no vad
06-24-2013 03:01 PM
Luis,
There are two ways you can achieve this
1. Use DNS SRV records
2. Multiple dial-peers with prefeences
With DNS SRV records you can have a single dial-peer that will send calls to multiple SIP servers. You will use DNS SRV records to define the FQDN of these servers
This needs a bit of work to get it going..So the easies option is to use multiple dial-peers...To learn how to setup both method please read this article
http://beaccie.blogspot.co.uk/2009_07_01_archive.html
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
