Outbound Dial peer not matching
shaucall46
I am adding a more specific dial-peer to point outbound calls to a new provider (Teams Direct) however all out bound calls match the original 9.T dial peer for example, sho dial plan matches correct dial peer but debugs and SIP messaging shows calls going to the 9.T dial peer
dial-peer voice 10 voip
description *** Outgoing Calls ***
destination-pattern 9.T
session protocol sipv2
session target ipv4:x.x.x.x
session transport udp
voice-class codec 3
voice-class sip rel1xx supported "100rel"
voice-class sip early-offer forced
voice-class sip options-keepalive
dtmf-relay rtp-nte
dial-peer voice 1 voip
description *** Outgoing Teams Direct ***
destination-pattern 944444444444
session target ipv4:x.x.x.x.
voice-class codec 3
dtmf-relay rtp-nte
you mean, you dail 944444444444 and the call hit on dial-peer 10 ?
Response Signature
Yes, correct and I want to match on DP 1
Please add the needed output from a debug of the call for us to be able to help. Add it as a file, not as text in the post itself, as that makes it so much harder to look through the output.
Response Signature
Have you verified all dial-peers are up?  Show dialpeer voice summary
