outbound dialing pattern conflict with internal extensions
haider.rizwan
I am having strange issue while making outbound calls having CUCM 10.5 environment.
let's say i am dialing <00971551234567> and internal extension range is 5xx. one user extension is 567.
as soon as i dial above number, instead of going outbound it rings internal extension.
what can be the issue? thanks in advance.
6 Replies 6
saurabh94
You need to check internal call flow. Which all translation patterns are involved or route pattern or sip trunk.
You need to check if digit manipulation is applied to any of the above entity and ensure you have right partition /CSS for the 10 digit dialing behaviour.
(rate if this helps)
we don't have translation pattern and sip trunk.
we have 2 separate PRI. please check attached config for reference.
please advise how to troubleshoot.
Can you please share below debug traces
debug voice ccapi inout
debug isdn q931
also mention calling & called number
Can you provide following logs along with calling and called number
1. H323 logs -- from dial-peer it seems you are using this as h323 gateway, if this is sip integration then ccsip messages
2.ccapi logs
3. ISDN q931 logs
regards
Sanjay Bishnoi
it seems issue with your translation pattern.... ensure you have mentioned 5xx conversion in translation not transformation
Jaime Valencia
Use DNA to find out what you're hitting in your dial plan
java
if this helps, please rate
