Outbound FXO calls based on Signal detection
mrmhar1408
Level 4
Level 4
Hi Team,
FXO and outbound calls while the line not connected to the FXO port, is there a way to do signal detection so the call will jump to the next fxo port
Terry Cheema
For outbound call hunting you can use Trunk groups. You can assign multiple fxo ports to the trunk group and assign them priorty etc. From your dial-peer reference the trunk group and it will hunt the available line.
Refer to: http://www.cisco.com/en/US/docs/ios/12_3/vvf_r/vrg_t1_ps1839_TSD_Products_Command_Reference_Chapter.html#wp1491022
Also Refer: https://supportforums.cisco.com/discussion/12056631/need-sample-cme-multiple-fxo-ports-hunt-fashion
-Terry
Please rate all helpful posts and mark thread as answered if you have no other queries.
