I do have 2 dial-peers, the scenario and configuration is here.
dial-peer voice 11 pots
description T6000 to ROW (US)
destination-pattern 0011T
progress_ind setup enable 3
progress_ind progress enable 8
translate-outgoing called 8842001
port 3/0:D
forward-digits all
dial-peer voice 1001345 pots
description T6000 to ROW (Cayman Islands)
destination-pattern 0011345T
When I dialed "0011345T" Calls always hit the US Dial Peer (11).
I tried showing the dial plan, only the US Dial Peer shows up.
voice#show dialplan number 0011345 timeout
Macro Exp.: 0011345
VoiceEncapPeer11
peer type = voice, information type = voice,
description = `T6000 to ROW (US)',
tag = 11, destination-pattern = `0011T',
answer-address = `', preference=0,
CLID Restriction = None
CLID Network Number = `'
CLID Second Number sent
CLID Override RDNIS = disabled,
source carrier-id = `', target carrier-id = `',
source trunk-group-label = `', target trunk-group-label = `',
numbering Type = `unknown'
group = 11, Admin state is up, Operation state is up,
Outbound state is up,
incoming called-number = `', connections/maximum = 0/unlimited,
DTMF Relay = disabled,
URI classes:
Destination =
huntstop = disabled,
in bound application associated: 'DEFAULT'
out bound application associated: ''
dnis-map =
permission :both
incoming COR list:maximum capability
outgoing COR list:minimum requirement
Translation profile (Incoming):
Translation profile (Outgoing):
incoming call blocking:
translation-profile = `'
disconnect-cause = `no-service'
advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4
type = pots, prefix = `',
forward-digits all
session-target = `', voice-port = `3/0:D',
direct-inward-dial = disabled,
digit_strip = enabled,
register E.164 number with H323 GK and/or SIP Registrar = TRUE
fax rate = system, payload size = 20 bytes
supported-language = ''
Time elapsed since last clearing of voice call statistics never
Connect Time = 3427550, Charged Units = 0,
Successful Calls = 84, Failed Calls = 140, Incomplete Calls = 1
Accepted Calls = 0, Refused Calls = 0,
Last Disconnect Cause is "10 ",
Last Disconnect Text is "normal call clearing (16)",
Last Setup Time = 421421030.
No other dial peer shows on the dialplan even though it should check on the longest matched digit right?
Solved! Go to Solution.
Dial-peer 501 is missing the port x/x command, so it should be state down. You can verify by:
show dial-peer voice summary
That is why you do not see a match about it.
Ohh that's why. Great! Thank you so much!
