Highlighted
Enthusiast
Outbound SIP Issue
Have setup CUBE to support a static SIP service by our provider. We moved from using a dynamic to static setup.  Ran across a strange issue where on the outbound leg of the call to the provider... on the ACK To: field, we are appending the 5060 port number a second time.   This is causing the call to disconnect after 30 seconds.   We are running ISR4331 16.6.4 ios.  Working with TAC and confirmed nothing in the config is causing this.  I created a rule and applied to the outbound 11 digit dialpeer to the carrier that looks like this:   rule 5 request ANY sip-header To modify "@xxx.142.200.14:5060:5060" "@xxx.142.200.14:5060"  which resolved the issue.  However, not happy with this fix and trying to find root cause.  Any idea's or experience something similar??
ACK sip:xxx2831477@xxx.142.200.14:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.77.235.171:5060;branch=z9hG4bK4E2FD
From: "Troy Putnam" <sip:xxxxxx1350@xxx.xx.235.171>;tag=8F72944D-1B7E
To: <sip:xxxxxx1477@xxx.142.200.14:5060:5060>;tag=3835044
Date: Mon, 04 Mar 2019 19:37:34 GMT
Call-ID: CB5C15E8-3DEB11E9-9B8ED21B-BC9A1796@192.77.235.171
Max-Forwards: 70
CSeq: 101 ACK
Allow-Events: telephone-event
Session-ID: 658f0b0c00105000a00000cae54049f2;remote=3ce1abfa092e5678bc8436b2e790ad9a
Content-Length: 0
