Hi All,
There is an issue with the FXO port. Users are not able to make the outgoing calls from FXO numbers.
when they try to make the outing calls they listen blank and after 6 to 10 sec. Call got automatically disconnected.
I have taken the debug for the voice ports.
.May 3 07:11:33.184: HTSP endpoint_info=aaln/S0/SU2/2, type=2, under_specified=0,
service_type=2htsp_allocate_if: MATCH!
.May 3 07:11:33.188: htsp_timer_stop3 htsp_setup_req
.May 3 07:11:33.192: htsp_process_event: [0/2/2, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
.May 3 07:11:33.192: [0/2/2] set signal state = 0xC timestamp = 0
.May 3 07:11:33.192: dsp_set_sig_state: [0/2/2] packet_len=12 channel_id=130 packet_id=39 state=0xC timestamp=0x0
.May 3 07:11:33.192: TGRM: reg_invoke_tgrm_call_update(0, 2, 2, 65535, 1, TGRM_CALL_BUSY, TGRM_CALL_VOICE, TGRM_DIRECTION_OUT)
.May 3 07:11:33.196: htsp_timer - 1300 msec
.May 3 07:11:34.496: htsp_process_event: [0/2/2, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER]fxols_wait_dial_timer htsp_dial
.May 3 07:11:34.496: mars_flex_dsprm_current_codec_comp:DSP:0 FLEX Complexity Codec
.May 3 07:11:36.148: htsp_process_event: [0/2/2, FXOLS_WAIT_DIAL_DONE, E_DSP_DIALING_DONE]fxols_wait_dial_done htsp_progress
.May 3 07:11:36.148: htsp_timer - 350 msec
.May 3 07:11:36.152: htsp_call_bridged invoked
.May 3 07:11:36.152: mars_flex_dsprm_current_codec_comp:DSP:0 FLEX Complexity Codec
.May 3 07:11:36.152: flex_dsprm_forking_mixing_support:
.May 3 07:11:36.156: mars_flex_dsprm_current_codec_comp:DSP:0 FLEX Complexity Codec
.May 3 07:11:36.156: htsp_process_event: [0/2/2, FXOLS_WAIT_CUT_THRU, E_HTSP_VOICE_CUT_THROUGH]fxols_handle_cut_thru
.May 3 07:11:36.156: htsp_timer_stop
.May 3 07:11:36.628: htsp_process_event: [0/2/2, FXOLS_OFFHOOK, E_DSP_SIG_1100]fxols_offhook_disc
.May 3 07:11:36.628: htsp_timer2 - 350 msec
.May 3 07:11:36.980: htsp_process_event: [0/2/2, FXOLS_OFFHOOK, E_HTSP_EVENT_TIMER2]fxols_disc_confirm
.May 3 07:11:36.980: htsp_timer_stop
.May 3 07:11:36.980: htsp_timer_stop2
and below is the configuration on gateway for voice ports
voice-port 0/2/0
supervisory disconnect dualtone mid-call
no battery-reversal
timeouts call-disconnect 1
timeouts wait-release 1
timing hookflash-out 50
timing guard-out 1000
voice-port 0/2/1
Kindly suggest which thing i have to change i either configuration or from service provoider.
Also plzzzzz confirm that is it an issue with CUCM end or service provider end.
Thanks in advance !!!
Vatandeep Singh
One more think i forget to mention,
I am using CUCM 8.5 and voice gateway 2811 and FXO card is VIC2-4FXO.
Vatandeep,
Start by proving that you can make calls on the lines feeding the FXOs.
Disconnect from the FXO and use an analogue (POTS) phone to prove you hear dial tone and
can make outgoing calls
Alex.
Please rate useful posts.
