Outgoing calls failed (sip-ua) configuration
kamilm001
Hello everyone. I have a problem with outgoing calls...Here is my debug call messages..PLZ HELP..!
All incoming calls working properly...
Apr 2 2018 20:03:53.821: //60647/6F4100000000/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x7F46F6BBD668
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 125981655
Called Number : 5414747
Source IP Address (Sig ): 10.200.21.28
Destn SIP Req Addr:Port : 10.0.1.228:5060
Destn SIP Resp Addr:Port : 10.0.1.228:5060
Destination Name : 10.0.1.228
Apr 2 2018 20:03:53.821: //60647/6F4100000000/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : No Codec
Negotiated Codec Bytes : 0
Nego. Codec payload : 255 (tx), 255 (rx)
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Address (Media): 10.200.21.28
Source IP Port (Media): 13116
Destn IP Address (Media): -
Destn IP Port (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC) : 41
Disconnect Cause (SIP) : 500
Apr 2 2018 20:03:53.825: //60646/6F4100000000/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x7F46F6B83928
Calling Number : 1117
Source IP Address (Sig ): 10.0.32.14
Destn SIP Req Addr:Port : 10.0.8.11:5060
Destn SIP Resp Addr:Port : 10.0.8.11:5060
Destination Name : 10.0.8.11
Apr 2 2018 20:03:53.825: //60646/6F4100000000/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Address (Media): 10.0.32.14
Source IP Port (Media): 13114
Disconnect Cause (SIP) : 503
