Showing results forĀ
Search instead forĀ
Did you mean:Ā
Outgoing calls issue with FXO lines
Yazen Alaa
I have CCM ver 7 with H323 voice gateway with 16 analog lines (FXO lines) and IPCC server  , so that each analog line connected to greeting pilot number by PLAR for a certain company . as mension as below :
port 0/0/0
connection plar 1500 ----> geeting extension no for company A
port 0/0/1
connection plar 1600 ----> geeting extension no for company B
port 0/1/0
connection plar 1700 ----> geeting extension no for company C
port 0/2/0
connection plar 1800 ----> geeting extension no for company D
my question is
regarding  outgoing calls , if  the users or phones  in company D make calls , i need to  go through port 0/2/0 and not other ports
and in company A go through port 0/0/0 directly and not other ports  , is there specfic configuration i have to add in voice gateway to make this scenaio well????
thanks and regards
Yazen Alaa
please any reply
thanks and regards
You could try using a different PSTN access code
for each company
91 for Comp A
92 for comp B
93 for Comp C
94 for comp D
Then write a dial peer for each
dial-peer voice 91 pots
desc ### PSTN ACCESS FOR COMP A ###
destination-pattern 91T
incoming called-number .
direct-inward-dial
port 1/0/0
dial-peer voice 92 pots
desc ### PSTN ACCESS FOR COMP B ###
destination-pattern 92T
direct-inward-dial
port 1/0/1
dial-peer voice 93 pots
desc ### PSTN ACCESS FOR COMP C ###
destination-pattern 93T
direct-inward-dial
port 1/1/0
dial-peer voice 94 pots
desc ### PSTN ACCESS FOR COMP D ###
destination-pattern 94T
direct-inward-dial
port 1/1/1
You would also have to amend you dial patterns
in Call Manager to suit.
Hope this helps
Alex
Regards, Alex. Please rate useful posts.
