07-13-2020 12:53 AM - edited 07-14-2020 05:30 AM
Wonder if you could help me out here, I'm currently setting up a new cube but hitting problems placing outgoing calls, incoming calls are working fine, if I place an outgoing call to my mobile number I get a message (I can hear it) Sorry the service you require can not be connected. Below you will find my running config stripped and a few debugs.
Debug ccsip call Jul 13 07:16:08.075: //96612/B2C67D800000/SIP/Call/sipSPICallInfo: The Call Setup Information is: Call Control Block (CCB) : 0x0x7F0626233170 State of The Call : STATE_DEAD TCP Sockets Used : NO Calling Number : 45000 Called Number : 07973xxxxxx Source IP Address (Sig ): 10.2.251.57 Destn SIP Req Addr:Port : 82.16.19.2:5060 Destn SIP Resp Addr:Port : 82.16.19.2:5060 Destination Name : 82.16.19.2 Jul 13 07:16:08.075: //96612/B2C67D800000/SIP/Call/sipSPIMediaCallInfo: Number of Media Streams: 1 Media Stream : 1 Negotiated Codec : g711alaw Negotiated Codec Bytes : 160 Nego. Codec payload : 8 (tx), 8 (rx) Negotiated Dtmf-relay : 6 Dtmf-relay Payload : 101 (tx), 101 (rx) Source IP Address (Media): 10.2.251.57 Source IP Port (Media): 8190 Destn IP Address (Media): 82.16.19.18 Destn IP Port (Media): 10100 Orig Destn IP Address:Port (Media): [ - ]:0 Jul 13 07:16:08.075: //96612/B2C67D800000/SIP/Call/sipSPICallInfo: Disconnect Cause (CC) : 16 Disconnect Cause (SIP) : 487 Jul 13 07:16:08.076: //96616/B2C67D800000/SIP/Call/sipSPICallInfo: The Call Setup Information is: Call Control Block (CCB) : 0x0x7F0626241C80 State of The Call : STATE_DEAD TCP Sockets Used : YES Calling Number : 45000 Called Number : 07973xxxxxx Source IP Address (Sig ): 10.2.251.57 Destn SIP Req Addr:Port : :0 Destn SIP Resp Addr:Port : :0 Destination Name : Jul 13 07:16:08.077: //96616/B2C67D800000/SIP/Call/sipSPIMediaCallInfo: Number of Media Streams: 1 Media Stream : 1 Negotiated Codec : No Codec Negotiated Codec Bytes : 0 Nego. Codec payload : 255 (tx), 255 (rx) Negotiated Dtmf-relay : 0 Dtmf-relay Payload : 0 (tx), 0 (rx) Source IP Address (Media): 10.2.251.57 Source IP Port (Media): 8192 Destn IP Address (Media): - Destn IP Port (Media): 0 Orig Destn IP Address:Port (Media): [ - ]:0 Jul 13 07:16:08.077: //96616/B2C67D800000/SIP/Call/sipSPICallInfo: Disconnect Cause (CC) : 188 Disconnect Cause (SIP) : 200 Jul 13 07:16:08.080: //96611/B2C67D800000/SIP/Call/sipSPICallInfo: The Call Setup Information is: Call Control Block (CCB) : 0x0x7F062621D0D8 State of The Call : STATE_DEAD TCP Sockets Used : YES Calling Number : 45000 Called Number : 07973xxxxxx Source IP Address (Sig ): 10.0.12.30 Destn SIP Req Addr:Port : 10.0.12.17:5060 Destn SIP Resp Addr:Port : 10.0.12.17:34867 Destination Name : 10.0.12.17 Jul 13 07:16:08.080: //96611/B2C67D800000/SIP/Call/sipSPIMediaCallInfo: Number of Media Streams: 1 Media Stream : 1 Negotiated Codec : g711alaw Negotiated Codec Bytes : 160 Nego. Codec payload : 8 (tx), 8 (rx) Negotiated Dtmf-relay : 6 Dtmf-relay Payload : 101 (tx), 101 (rx) Source IP Address (Media): 10.0.12.30 Source IP Port (Media): 8188 Destn IP Address (Media): 172.30.152.11 Destn IP Port (Media): 32362 Orig Destn IP Address:Port (Media): [ - ]:0 Jul 13 07:16:08.080: //96611/B2C67D800000/SIP/Call/sipSPICallInfo: Disconnect Cause (CC) : 38 Disconnect Cause (SIP) : 503
Debug ccsip message Jul 13 07:10:30.638: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: INVITE sip:07973xxxxxx@10.0.12.30:5060 SIP/2.0 Via: SIP/2.0/TCP 10.0.12.17:5060;branch=z9hG4bK1eead65cae8f3 From: "VM SIP TEST 2" <sip:45000@10.0.12.17>;tag=404459~9c2c55f8-f6da-4001-942f-f8cb268e11d0-49787915 To: <sip:0797xxxxxx@10.0.12.30> Date: Mon, 13 Jul 2020 07:10:30 GMT Call-ID: ee147c80-f0c108e6-15b0f-110c000a@10.0.12.17 Supported: 100rel,timer,resource-priority,replaces Min-SE: 1800 User-Agent: Cisco-CUCM11.5 Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY CSeq: 101 INVITE Expires: 180 Allow-Events: presence Supported: X-cisco-srtp-fallback,X-cisco-original-called Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=VIDEO_UNSPECIFIED Session-ID: 30bca1117401e23b8117f8034def3ba0;remote=00000000000000000000000000000000 Cisco-Guid: 3994320000-0000065536-0000004169-0285999114 Session-Expires: 1800 P-Asserted-Identity: "VM SIP TEST 2" <sip:45000@10.0.12.17> Contact: <sip:45000@10.0.12.17:5060;transport=tcp> Max-Forwards: 70 Content-Length: 0 Jul 13 07:10:30.642: //96514/EE147C800000/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 100 Trying Via: SIP/2.0/TCP 10.0.12.17:5060;branch=z9hG4bK1eead65cae8f3 From: "VM SIP TEST 2" <sip:45000@10.0.12.17>;tag=404459~9c2c55f8-f6da-4001-942f-f8cb268e11d0-49787915 To: <sip:07973xxxxxx@10.0.12.30> Date: Mon, 13 Jul 2020 07:10:30 GMT Call-ID: ee147c80-f0c108e6-15b0f-110c000a@10.0.12.17 CSeq: 101 INVITE Allow-Events: kpml, telephone-event Server: Cisco-SIPGateway/IOS-16.6.6 Session-ID: 00000000000000000000000000000000;remote=30bca1117401e23b8117f8034def3ba0 Content-Length: 0 Jul 13 07:10:30.645: //96515/EE147C800000/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:07973xxxxxx@82.16.19.2:5060 SIP/2.0 Via: SIP/2.0/UDP 10.2.251.57:5060;branch=z9hG4bK12084228B From: "VM SIP TEST 2" <sip:45000@10.2.251.57>;tag=14803119-1814 To: <sip:07973xxxxxx@82.16.19.2> Date: Mon, 13 Jul 2020 07:10:30 GMT Call-ID: C544F9D6-C40E11EA-B9A3B5A2-101A3230@10.2.251.57 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 3994320000-0000065536-0000004169-0285999114 User-Agent: Cisco-SIPGateway/IOS-16.6.6 Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 101 INVITE Timestamp: 1594624230 Contact: <sip:45000@10.2.251.57:5060> Expires: 180 Allow-Events: telephone-event Max-Forwards: 69 P-Asserted-Identity: "VM SIP TEST 2" <sip:45000@10.2.251.57> Session-ID: 30bca1117401e23b8117f8034def3ba0;remote=00000000000000000000000000000000 Session-Expires: 1800 Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 243 v=0 o=CiscoSystemsSIP-GW-UserAgent 1948 8484 IN IP4 10.2.251.57 s=SIP Call c=IN IP4 10.2.251.57 t=0 0 m=audio 8184 RTP/AVP 8 101 c=IN IP4 10.2.251.57 a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 Jul 13 07:10:30.649: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: OPTIONS sip:10.0.12.30:5060 SIP/2.0 Via: SIP/2.0/TCP 10.0.12.17:5060;branch=z9hG4bK1eeae2d555626 From: <sip:10.0.12.17>;tag=524611185 To: <sip:10.0.12.30> Date: Mon, 13 Jul 2020 07:10:30 GMT Call-ID: ee147c80-f0c108e6-15b10-110c000a@10.0.12.17 User-Agent: Cisco-CUCM11.5 CSeq: 101 OPTIONS Contact: <sip:10.0.12.17:5060;transport=tcp> Max-Forwards: 0 Content-Length: 0 Jul 13 07:10:30.651: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/TCP 10.0.12.17:5060;branch=z9hG4bK1eeae2d555626 From: <sip:10.0.12.17>;tag=524611185 To: <sip:10.0.12.30>;tag=1480311F-2001 Date: Mon, 13 Jul 2020 07:10:30 GMT Call-ID: ee147c80-f0c108e6-15b10-110c000a@10.0.12.17 Server: Cisco-SIPGateway/IOS-16.6.6 CSeq: 101 OPTIONS Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: kpml, telephone-event Accept: application/sdp Supported: 100rel,timer,resource-priority,replaces,sdp-anat Content-Type: application/sdp Content-Length: 163 v=0 o=CiscoSystemsSIP-GW-UserAgent 8832 2086 IN IP4 10.0.12.30 s=SIP Call c=IN IP4 10.0.12.30 t=0 0 m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3 c=IN IP4 10.0.12.30 Jul 13 07:10:30.654: //96515/EE147C800000/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 100 Trying Via: SIP/2.0/UDP 10.2.251.57:5060;branch=z9hG4bK12084228B From: "VM SIP TEST 2" <sip:45000@10.2.251.57>;tag=14803119-1814 To: <sip:07973xxxxxx@82.16.19.2> Call-ID: C544F9D6-C40E11EA-B9A3B5A2-101A3230@10.2.251.57 CSeq: 101 INVITE Timestamp: 1594624230 Content-Length: 0 Jul 13 07:10:30.662: //96515/EE147C800000/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 407 Proxy Authentication Required Via: SIP/2.0/UDP 10.2.251.57:5060;branch=z9hG4bK12084228B Proxy-Authenticate: Digest realm="Realm",nonce="MTU5NDYyMDIyMTg3NjU3ZTRlZGJjZTRiNTdlYjQ4OGU5NTFiMzQyY2Q1Yzc5",stale=false,algorithm=MD5,qop="auth" To: <sip:07973xxxxxx@82.16.19.2>;tag=3803613030-698069643 From: "VM SIP TEST 2" <sip:45000@10.2.251.57;user=phone>;tag=14803119-1814 Call-ID: C544F9D6-C40E11EA-B9A3B5A2-101A3230@10.2.251.57 CSeq: 101 INVITE Allow: UPDATE,PRACK,INFO,NOTIFY,OPTIONS,BYE,INVITE,ACK,CANCEL Contact: <sip:07973xxxxxx@82.16.19.2:5060> Content-Length: 0 Jul 13 07:10:30.663: //96515/EE147C800000/SIP/Msg/ccsipDisplayMsg: Sent: ACK sip:07973xxxxxx@82.16.19.2:5060 SIP/2.0 Via: SIP/2.0/UDP 10.2.251.57:5060;branch=z9hG4bK12084228B From: "VM SIP TEST 2" <sip:45000@10.2.251.57>;tag=14803119-1814 To: <sip:07973xxxxxx@82.16.19.2>;tag=3803613030-698069643 Date: Mon, 13 Jul 2020 07:10:30 GMT Call-ID: C544F9D6-C40E11EA-B9A3B5A2-101A3230@10.2.251.57 Max-Forwards: 70 CSeq: 101 ACK Allow-Events: telephone-event Session-ID: ;remote= Content-Length: 0 Jul 13 07:10:30.664: //96515/EE147C800000/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:07973xxxxxx@82.16.19.2:5060 SIP/2.0 Via: SIP/2.0/UDP 10.2.251.57:5060;branch=z9hG4bK12085A0C From: "VM SIP TEST 2" <sip:45000@10.2.251.57>;tag=14803119-1814 To: <sip:07973xxxxxx@82.16.19.2> Date: Mon, 13 Jul 2020 07:10:30 GMT Call-ID: C544F9D6-C40E11EA-B9A3B5A2-101A3230@10.2.251.57 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 3994320000-0000065536-0000004169-0285999114 User-Agent: Cisco-SIPGateway/IOS-16.6.6 Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 102 INVITE Timestamp: 1594624230 Contact: <sip:45000@10.2.251.57:5060> Expires: 180 Allow-Events: telephone-event Proxy-Authorization: Digest username="onboard09",realm="Realm",uri="sip:07973xxxxxx@82.16.19.2:5060",response="ad85f4c9c9878a2375cec50674659789",nonce="MTU5NDYyMDIyMTg3NjU3ZTRlZGJjZTRiNTdlYjQ4OGU5NTFiMzQyY2Q1Yzc5",cnonce="E6D38045",qop=auth,algorithm=MD5,nc=00000001 Max-Forwards: 69 P-Asserted-Identity: "VM SIP TEST 2" <sip:45000@10.2.251.57> Session-ID: 30bca1117401e23b8117f8034def3ba0;remote=00000000000000000000000000000000 Session-Expires: 1800 Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 243 v=0 o=CiscoSystemsSIP-GW-UserAgent 1948 8484 IN IP4 10.2.251.57 s=SIP Call c=IN IP4 10.2.251.57 t=0 0 m=audio 8184 RTP/AVP 8 101 c=IN IP4 10.2.251.57 a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 Jul 13 07:10:30.673: //96515/EE147C800000/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 100 Trying Via: SIP/2.0/UDP 10.2.251.57:5060;branch=z9hG4bK12085A0C From: "VM SIP TEST 2" <sip:45000@10.2.251.57>;tag=14803119-1814 To: <sip:07973xxxxxx@82.16.19.2> Call-ID: C544F9D6-C40E11EA-B9A3B5A2-101A3230@10.2.251.57 CSeq: 102 INVITE Timestamp: 1594624230 Content-Length: 0 Jul 13 07:10:30.725: //96515/EE147C800000/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 183 Session Progress Via: SIP/2.0/UDP 10.2.251.57:5060;branch=z9hG4bK12085A0C To: <sip:07973xxxxxx@82.16.19.2>;tag=3803613030-1020988772 From: "VM SIP TEST 2" <sip:45000@10.2.251.57;user=phone>;tag=14803119-1814 Call-ID: C544F9D6-C40E11EA-B9A3B5A2-101A3230@10.2.251.57 CSeq: 102 INVITE Allow: UPDATE,PRACK,INFO,NOTIFY,OPTIONS,BYE,INVITE,ACK,CANCEL Contact: <sip:07973xxxxxx@82.16.19.2:5060> Content-Type: application/sdp Content-Length: 252 v=0 o=brnt-voiponboardsbc1-a 201206121 201206121 IN IP4 82.16.19.2 s=sip call c=IN IP4 82.16.19.18 t=0 0 m=audio 10098 RTP/AVP 8 101 a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=ptime:20 a=silenceSupp:off - - - - Jul 13 07:10:30.728: //96514/EE147C800000/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 183 Session Progress Via: SIP/2.0/TCP 10.0.12.17:5060;branch=z9hG4bK1eead65cae8f3 From: "VM SIP TEST 2" <sip:45000@10.0.12.17>;tag=404459~9c2c55f8-f6da-4001-942f-f8cb268e11d0-49787915 To: <sip:07973xxxxxx@10.0.12.30>;tag=1480316D-1AD7 Date: Mon, 13 Jul 2020 07:10:30 GMT Call-ID: ee147c80-f0c108e6-15b0f-110c000a@10.0.12.17 CSeq: 101 INVITE Require: 100rel RSeq: 8573 Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: kpml, telephone-event Contact: <sip:07973xxxxxx@10.0.12.30:5060;transport=tcp> Supported: sdp-anat Server: Cisco-SIPGateway/IOS-16.6.6 Session-ID: 58d9216120e7570f97bc8825f965a0f7;remote=30bca1117401e23b8117f8034def3ba0 Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 240 v=0 o=CiscoSystemsSIP-GW-UserAgent 3781 3104 IN IP4 10.0.12.30 s=SIP Call c=IN IP4 10.0.12.30 t=0 0 m=audio 8182 RTP/AVP 8 101 c=IN IP4 10.0.12.30 a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=ptime:20 Jul 13 07:10:30.793: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: PRACK sip:07973xxxxxx@10.0.12.30:5060;transport=tcp SIP/2.0 Via: SIP/2.0/TCP 10.0.12.17:5060;branch=z9hG4bK1eeaf1d80c380 From: "VM SIP TEST 2" <sip:45000@10.0.12.17>;tag=404459~9c2c55f8-f6da-4001-942f-f8cb268e11d0-49787915 To: <sip:07973xxxxxx@10.0.12.30>;tag=1480316D-1AD7 Date: Mon, 13 Jul 2020 07:10:30 GMT Call-ID: ee147c80-f0c108e6-15b0f-110c000a@10.0.12.17 User-Agent: Cisco-CUCM11.5 CSeq: 102 PRACK RAck: 8573 101 INVITE Allow-Events: presence Max-Forwards: 70 Content-Type: application/sdp Content-Length: 245 v=0 o=CiscoSystemsCCM-SIP 404459 1 IN IP4 10.0.12.17 s=SIP Call c=IN IP4 172.30.152.11 b=TIAS:64000 b=CT:64 b=AS:64 t=0 0 m=audio 32116 RTP/AVP 8 101 a=ptime:20 a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 Jul 13 07:10:30.796: //96514/EE147C800000/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/TCP 10.0.12.17:5060;branch=z9hG4bK1eeaf1d80c380 From: "VM SIP TEST 2" <sip:45000@10.0.12.17>;tag=404459~9c2c55f8-f6da-4001-942f-f8cb268e11d0-49787915 To: <sip:07973xxxxxx@10.0.12.30>;tag=1480316D-1AD7 Date: Mon, 13 Jul 2020 07:10:30 GMT Call-ID: ee147c80-f0c108e6-15b0f-110c000a@10.0.12.17 Server: Cisco-SIPGateway/IOS-16.6.6 CSeq: 102 PRACK Session-ID: 58d9216120e7570f97bc8825f965a0f7;remote=30bca1117401e23b8117f8034def3ba0 Content-Length: 0 Jul 13 07:10:31.209: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: OPTIONS sip:10.0.12.30:5060 SIP/2.0 Via: SIP/2.0/TCP 10.0.12.16:5060;branch=z9hG4bK6bae22f24ecca From: <sip:10.0.12.16>;tag=2084978717 To: <sip:10.0.12.30> Date: Mon, 13 Jul 2020 07:10:31 GMT Call-ID: eead1300-f0c108e7-4aa6e-100c000a@10.0.12.16 User-Agent: Cisco-CUCM11.5 CSeq: 101 OPTIONS Contact: <sip:10.0.12.16:5060;transport=tcp> Max-Forwards: 0 Content-Length: 0 Jul 13 07:10:31.211: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/TCP 10.0.12.16:5060;branch=z9hG4bK6bae22f24ecca From: <sip:10.0.12.16>;tag=2084978717 To: <sip:10.0.12.30>;tag=14803350-A2F Date: Mon, 13 Jul 2020 07:10:31 GMT Call-ID: eead1300-f0c108e7-4aa6e-100c000a@10.0.12.16 Server: Cisco-SIPGateway/IOS-16.6.6 CSeq: 101 OPTIONS Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: kpml, telephone-event Accept: application/sdp Supported: 100rel,timer,resource-priority,replaces,sdp-anat Content-Type: application/sdp Content-Length: 163 v=0 o=CiscoSystemsSIP-GW-UserAgent 4174 9701 IN IP4 10.0.12.30 s=SIP Call c=IN IP4 10.0.12.30 t=0 0 m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3 c=IN IP4 10.0.12.30 Jul 13 07:10:37.860: //96515/EE147C800000/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 487 Request Terminated Via: SIP/2.0/UDP 10.2.251.57:5060;branch=z9hG4bK12085A0C To: <sip:0797xxxxxx@82.16.19.2>;tag=3803613030-1020988772 From: "VM SIP TEST 2" <sip:45000@10.2.251.57;user=phone>;tag=14803119-1814 Call-ID: C544F9D6-C40E11EA-B9A3B5A2-101A3230@10.2.251.57 CSeq: 102 INVITE Allow: UPDATE,PRACK,INFO,NOTIFY,OPTIONS,BYE,INVITE,ACK,CANCEL Contact: <sip:07973xxxxxx@82.16.19.2:5060> Content-Length: 0 Jul 13 07:10:37.862: //96515/EE147C800000/SIP/Msg/ccsipDisplayMsg: Sent: ACK sip:07973xxxxxx@82.16.19.2:5060 SIP/2.0 Via: SIP/2.0/UDP 10.2.251.57:5060;branch=z9hG4bK12085A0C From: "VM SIP TEST 2" <sip:45000@10.2.251.57>;tag=14803119-1814 To: <sip:07973xxxxxx@82.16.19.2>;tag=3803613030-1020988772 Date: Mon, 13 Jul 2020 07:10:30 GMT Call-ID: C544F9D6-C40E11EA-B9A3B5A2-101A3230@10.2.251.57 Max-Forwards: 70 CSeq: 102 ACK Allow-Events: telephone-event Content-Length: 0 Jul 13 07:10:37.865: //96514/EE147C800000/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 503 Service Unavailable Via: SIP/2.0/TCP 10.0.12.17:5060;branch=z9hG4bK1eead65cae8f3 From: "VM SIP TEST 2" <sip:45000@10.0.12.17>;tag=404459~9c2c55f8-f6da-4001-942f-f8cb268e11d0-49787915 To: <sip:07973xxxxxx@10.0.12.30>;tag=1480316D-1AD7 Date: Mon, 13 Jul 2020 07:10:30 GMT Call-ID: ee147c80-f0c108e6-15b0f-110c000a@10.0.12.17 CSeq: 101 INVITE Allow-Events: kpml, telephone-event Server: Cisco-SIPGateway/IOS-16.6.6 Reason: Q.850;cause=0 Session-ID: 58d9216120e7570f97bc8825f965a0f7;remote=30bca1117401e23b8117f8034def3ba0 Session-Expires: 1800 Content-Length: 0 Jul 13 07:10:37.867: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: ACK sip:07973xxxxxx@10.0.12.30:5060 SIP/2.0 Via: SIP/2.0/TCP 10.0.12.17:5060;branch=z9hG4bK1eead65cae8f3 From: "VM SIP TEST 2" <sip:45000@10.0.12.17>;tag=404459~9c2c55f8-f6da-4001-942f-f8cb268e11d0-49787915 To: <sip:07973xxxxxx@10.0.12.30>;tag=1480316D-1AD7 Date: Mon, 13 Jul 2020 07:10:30 GMT Call-ID: ee147c80-f0c108e6-15b0f-110c000a@10.0.12.17 User-Agent: Cisco-CUCM11.5 Max-Forwards: 70 CSeq: 101 ACK Allow-Events: presence Content-Length: 0
Debug ccisp error SIP: (96454) Group (a= group line) attribute, level 65535 instance 1 not found. SIP: (96454) Group (a= group line) attribute, level 65535 instance 1 not found. SIP: (96454) Group (a= group line) attribute, level 65535 instance 1 not found. SIP: (96454) Group (a= group line) attribute, level 65535 instance 1 not found. SIP: Attribute mid, level 1 instance 1 not found. SIP: setup attribute, level 1 instance 1 not found. SIP: connection attribute, level 1 instance 1 not found. SIP: Attribute label, level 1 instance 1 not found. SIP: a=framerate attribute, level 1 instance 1 not found. Jul 13 07:07:03.183: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec: Unexpected VoIPCodec Type :No Codec SIP: (96453) Group (a= group line) attribute, level 65535 instance 1 not found. SIP: (96453) Group (a= group line) attribute, level 65535 instance 1 not found. Jul 13 07:07:03.184: //96454/72B2CB000000/SIP/Error/sipSPIGetNewLocalMediaDirection: Unknown media direction (0) from remote end SIP: (96453) Group (a= group line) attribute, level 65535 instance 1 not found. Jul 13 07:07:03.225: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free: Freeing NULL pointer! SIP: Attribute mid, level 1 instance 1 not found. Jul 13 07:07:03.227: //96453/72B2CB000000/SIP/Error/sipSPIGetNewLocalMediaDirection: Unknown media direction (0) from remote end SIP: setup attribute, level 1 instance 1 not found. SIP: connection attribute, level 1 instance 1 not found. SIP: Attribute label, level 1 instance 1 not found. SIP: a=framerate attribute, level 1 instance 1 not found. Jul 13 07:07:10.158: //96453/72B2CB000000/SIP/Error/sipSPIFlushDeferredQueue: Invalid deferredQueue Jul 13 07:07:10.165: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIRemoveBranchName: invalid ccb, bName or branch list for sipSPIRemoveBranchName Jul 13 07:07:10.169: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_iwf_process_event: Dead CCB Jul 13 07:07:10.169: //96454/72B2CB000000/SIP/Error/ccsip_offer_ans_md_invite_ack_answer_sent_hdlr: Unable to send ACK sent peer event
And finally my running config
no voice hunt unassigned-number no voice hunt no-response no voice hunt dest-out-of-order no voice hunt invalid-number voice call send-alert voice rtp send-recv ! voice service voip mode border-element license capacity 200 allow-connections sip to sip redirect ip2ip fax protocol pass-through g711alaw sip session refresh header-passing subscription maximum originate 2 asserted-id pai privacy pstn options-ping 60 no update-callerid early-offer forced midcall-signaling passthru privacy-policy passthru ! ! voice class e164-pattern-map 9 description *** PSTN Numbers Outbound *** e164 +800T e164 +44T e164 ^1800[01]$ e164 ^999$ e164 ^11[68]...$ e164 ^1..$ e164 ^[01]T e164 ^[02]T e164 ^[2]T ! ! voice class dpg 90 description *** SBC DPG *** dial-peer 90 preference 1 dial-peer 91 preference 2 ! voice class dpg 1000 description *** CUCM DPG *** dial-peer 1000 preference 1 dial-peer 1001 preference 2 ! voice class sip-options-keepalive 1 description ** global options pings settings ** up-interval 30 retry 3 transport udp ! voice translation-rule 1 rule 1 /^\([127-9]......\)$/ /0115\1/ ! ! voice translation-profile BlockedNumbers translate calling 777 ! voice translation-profile OutboundCalledPartyforShortDIAL translate called 1 ! interface GigabitEthernet0/0/0 ip address 10.2.251.57 255.255.255.252 no ip redirects no ip proxy-arp media-type rj45 negotiation auto ! interface GigabitEthernet0/0/1 ip address 10.0.12.30 255.255.255.0 no ip redirects no ip proxy-arp negotiation auto ! ! mgcp behavior rsip-range tgcp-only mgcp behavior comedia-role none mgcp behavior comedia-check-media-src disable mgcp behavior comedia-sdp-force disable ! mgcp profile default ! ! ! ! dial-peer voice 9 voip description ** INBOUND Dial-Peer from SIP Platform ** translation-profile incoming BlockedNumbers call-block disconnect-cause incoming unassigned-number session protocol sipv2 session transport udp destination dpg 1000 incoming uri via ITSP voice-class codec 1 voice-class sip bind control source-interface GigabitEthernet0/0/0 voice-class sip bind media source-interface GigabitEthernet0/0/0 dtmf-relay rtp-nte ip qos dscp cs3 signaling no vad ! dial-peer voice 10 voip description *** CUCM to CUBE (inbound) *** translation-profile incoming OutboundCalledPartyforShortDIAL session protocol sipv2 session transport tcp destination dpg 90 incoming uri via CUCM voice-class codec 1 voice-class sip bind control source-interface GigabitEthernet0/0/1 voice-class sip bind media source-interface GigabitEthernet0/0/1 dtmf-relay rtp-nte sip-kpml no vad ! dial-peer voice 1000 voip description *** CUBE to CUCM LOX-SUB 1 (outbound) *** preference 1 destination-pattern 69... session protocol sipv2 session target ipv4:10.0.12.17 session transport tcp voice-class sip options-keepalive profile 1 voice-class sip bind control source-interface GigabitEthernet0/0/1 voice-class sip bind media source-interface GigabitEthernet0/0/1 dtmf-relay rtp-nte sip-kpml codec g711alaw ip qos dscp cs3 signaling no vad ! dial-peer voice 90 voip description *** SBC3 Birmingham - Preferred Route *** preference 1 destination-pattern .T session protocol sipv2 session target ipv4:xx.xx.xx.xx session transport udp voice-class sip options-ping 60 voice-class sip options-keepalive retry 3 voice-class sip bind control source-interface GigabitEthernet0/0/0 voice-class sip bind media source-interface GigabitEthernet0/0/0 dtmf-relay rtp-nte dtmf-interworking rtp-nte codec g711alaw ip qos dscp cs3 signaling no vad ! dial-peer voice 1001 voip description *** CUBE to CUCM WTG-SUB 1(outbound) *** preference 2 destination-pattern 69... session protocol sipv2 session target ipv4:SUBSCRIBER session transport tcp voice-class sip options-keepalive profile 1 voice-class sip bind control source-interface GigabitEthernet0/0/1 voice-class sip bind media source-interface GigabitEthernet0/0/1 dtmf-relay rtp-nte sip-kpml codec g711alaw ip qos dscp cs3 signaling no vad ! dial-peer voice 1002 voip description *** CUBE to CUCM PUB (outbound) *** preference 3 destination-pattern 69... session protocol sipv2 session target ipv4:PUBLISHER session transport tcp voice-class sip options-keepalive profile 1 voice-class sip bind control source-interface GigabitEthernet0/0/1 voice-class sip bind media source-interface GigabitEthernet0/0/1 dtmf-relay rtp-nte sip-kpml codec g711alaw ip qos dscp cs3 signaling no vad ! ! dial-peer hunt 1 sip-ua authentication username XXXXX password 7 XXXXX no remote-party-id aaa username proxy-auth retry invite 4 timers options 600 reason-header override connection-reuse
Thanks in advance
Martyn
07-13-2020 04:24 AM
07-13-2020 05:05 AM
Hi and thanks for the response, its an excising CUCM moving services from ISDN to SiP, I'm currently testing with the telco for sign off but they are saying that its a miss-configuration from my-side. I will ask them to double check the configuration their side because as you mention it all looks fine cube side.
Again thanks for your response and I will let you know the outcome.
Martyn
07-14-2020 01:44 AM
So the sequence is a normal outbound call setup, gets as far as 183 proceeding at which point I assume you hear the announcement. Then the carrier send you a 487 termination, and your gateway sends 503 Service Unavailable to CUCM.
I think it's possible that the carrier doesn't like your calling number. Many want to see a valid number, ie one of the numbers that route into the trunk. Especially on an authenticated trunk.
By the way is that only a partial configuration? I see you're matching inbound by URI but I can't see the actual definitions for "ITSP" or "CUCM" (coincidentally the exact names that I use in that context). Routing by DPG you need bombproof inbound dial peer matching.
07-14-2020 05:02 AM
Thanks, let me get back to the carrier with that question, what definitions are missing for my "ITSP" or "CUCM" as this is the majority of my configuration.
07-14-2020 05:52 AM
In your inbound dial peers you have configured them to match based on the VIA header. For example ...
That's saying it will match if the VIA header matches one of the parameters defined in a class named "CUCM". For example if you were just matching by IP address ..
voice class uri CUCM sip host ipv4:192.168.21.10 host ipv4:192.168.21.11
07-14-2020 09:29 AM
Apologies, yes I have our cluster
host ipv4:10.0.12.16
host ipv4:10.0.12.17
host ipv4:10.20.12.16
Ive been going trough my debugs which may be showing something strange, this is me calling my mobile number from 45000
Jul 14 15:51:05.981: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: INVITE sip:07973xxxxxx@10.0.12.30:5060 SIP/2.0 Via: SIP/2.0/TCP 10.0.12.17:5060;branch=z9hG4bK60b01ac8f481 From: "SiP Test 45000" <sip:45000@10.0.12.17>;tag=67135~9c2c55f8-f6da-4001-942f-f8cb268e11d0-36791270 To: <sip:07973xxxxxx@10.0.12.30> Date: Tue, 14 Jul 2020 15:51:05 GMT Call-ID: d2010000-f0d1d469-3f0d-110c000a@10.0.12.17 Supported: 100rel,timer,resource-priority,replaces Min-SE: 1800 User-Agent: Cisco-CUCM11.5 Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY CSeq: 101 INVITE Expires: 180 Allow-Events: presence Supported: X-cisco-srtp-fallback,X-cisco-original-called Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=DESKTOP Session-ID: 4fe824fef3d83993017e11e24aa67130;remote=00000000000000000000000000000000 Cisco-Guid: 3523280896-0000065536-0000000923-0285999114 Session-Expires: 1800 P-Asserted-Identity: "SiP Test 45000" <sip:45000@10.0.12.17> Contact: <sip:45000@10.0.12.17:5060;transport=tcp> Max-Forwards: 69 Content-Length: 0
As you can see I start with
CSeq: 101 INVITE
Then we sip 100 trying followed by Sip 407 Proxy auth and Ack
Jul 14 15:51:05.986: //3692/D20100000000/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:07973xxxxxx@82.16.19.2:5060 SIP/2.0 Via: SIP/2.0/UDP 10.2.251.57:5060;branch=z9hG4bK91B145F From: "SiP Test 45000" <sip:45000@10.2.251.57>;tag=13D3EBA-26AE To: <sip:07973xxxxxx@82.16.19.2> Date: Tue, 14 Jul 2020 15:51:05 GMT Call-ID: A9658480-C52011EA-8EF3AD4F-A1EA3405@10.2.251.57 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 3523280896-0000065536-0000000923-0285999114 User-Agent: Cisco-SIPGateway/IOS-16.6.6 Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 101 INVITE Timestamp: 1594741865 Contact: <sip:45000@10.2.251.57:5060> Expires: 180 Allow-Events: telephone-event Max-Forwards: 68 P-Asserted-Identity: "SiP Test 45000" <sip:45000@10.2.251.57> Session-ID: 4fe824fef3d83993017e11e24aa67130;remote=00000000000000000000000000000000 Session-Expires: 1800 Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 243 v=0 o=CiscoSystemsSIP-GW-UserAgent 2503 7226 IN IP4 10.2.251.57 s=SIP Call c=IN IP4 10.2.251.57 t=0 0 m=audio 8122 RTP/AVP 8 101 c=IN IP4 10.2.251.57 a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 Jul 14 15:51:05.987: //3691/D20100000000/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 100 Trying Via: SIP/2.0/TCP 10.0.12.17:5060;branch=z9hG4bK60b01ac8f481 From: "SiP Test 45000" <sip:45000@10.0.12.17>;tag=67135~9c2c55f8-f6da-4001-942f-f8cb268e11d0-36791270 To: <sip:07973xxxxxx@10.0.12.30> Date: Tue, 14 Jul 2020 15:51:05 GMT Call-ID: d2010000-f0d1d469-3f0d-110c000a@10.0.12.17 CSeq: 101 INVITE Allow-Events: kpml, telephone-event Server: Cisco-SIPGateway/IOS-16.6.6 Session-ID: 00000000000000000000000000000000;remote=4fe824fef3d83993017e11e24aa67130 Content-Length: 0 Jul 14 15:51:05.996: //3692/D20100000000/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 100 Trying Via: SIP/2.0/UDP 10.2.251.57:5060;branch=z9hG4bK91B145F From: "SiP Test 45000" <sip:45000@10.2.251.57>;tag=13D3EBA-26AE To: <sip:07973xxxxxx@82.16.19.2> Call-ID: A9658480-C52011EA-8EF3AD4F-A1EA3405@10.2.251.57 CSeq: 101 INVITE Timestamp: 1594741865 Content-Length: 0 Jul 14 15:51:06.004: //3692/D20100000000/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 407 Proxy Authentication Required Via: SIP/2.0/UDP 10.2.251.57:5060;branch=z9hG4bK91B145F Proxy-Authenticate: Digest realm="Realm",nonce="MTU5NDczMjQzMzQ1NTkwMWE1ZGY0ZTMyOGUzNmYzNzE4ZjYzN2ViNzc1NzZl",stale=false,algorithm=MD5,qop="auth" To: <sip:07973xxxxxx@82.16.19.2>;tag=3803730665-1501893535 From: "SiP Test 45000" <sip:45000@10.2.251.57;user=phone>;tag=13D3EBA-26AE Call-ID: A9658480-C52011EA-8EF3AD4F-A1EA3405@10.2.251.57 CSeq: 101 INVITE Allow: UPDATE,PRACK,INFO,NOTIFY,OPTIONS,BYE,INVITE,ACK,CANCEL Contact: <sip:07973xxxxxx@82.16.19.2:5060> Content-Length: 0 Jul 14 15:51:06.005: //3692/D20100000000/SIP/Msg/ccsipDisplayMsg: Sent: ACK sip:07973xxxxxx@82.16.19.2:5060 SIP/2.0 Via: SIP/2.0/UDP 10.2.251.57:5060;branch=z9hG4bK91B145F From: "SiP Test 45000" <sip:45000@10.2.251.57>;tag=13D3EBA-26AE To: <sip:07973xxxxxx@82.16.19.2>;tag=3803730665-1501893535 Date: Tue, 14 Jul 2020 15:51:05 GMT Call-ID: A9658480-C52011EA-8EF3AD4F-A1EA3405@10.2.251.57 Max-Forwards: 70 CSeq: 101 ACK Allow-Events: telephone-event Session-ID: ;remote= Content-Length: 0
Which gives us our CSeq: 101 Ack
Our CSeq is incremented once we have been authorised to CSeq: 102 INVITE
Jul 14 15:51:06.006: //3692/D20100000000/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:07973xxxxxx@82.16.19.2:5060 SIP/2.0 Via: SIP/2.0/UDP 10.2.251.57:5060;branch=z9hG4bK91C18C From: "SiP Test 45000" <sip:45000@10.2.251.57>;tag=13D3EBA-26AE To: <sip:07973xxxxxx@82.16.19.2> Date: Tue, 14 Jul 2020 15:51:06 GMT Call-ID: A9658480-C52011EA-8EF3AD4F-A1EA3405@10.2.251.57 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 3523280896-0000065536-0000000923-0285999114 User-Agent: Cisco-SIPGateway/IOS-16.6.6 Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 102 INVITE Timestamp: 1594741866 Contact: <sip:45000@10.2.251.57:5060> Expires: 180 Allow-Events: telephone-event Proxy-Authorization: Digest username="onboard08",realm="Realm",uri="sip:07973xxxxxx@82.16.19.2:5060",response="1cea26f27f5360fd654f3f0ca1b19e8f",nonce="MTU5NDczMjQzMzQ1NTkwMWE1ZGY0ZTMyOGUzNmYzNzE4ZjYzN2ViNzc1NzZl",cnonce="FF513110",qop=auth,algorithm=MD5,nc=00000001 Max-Forwards: 68 P-Asserted-Identity: "SiP Test 45000" <sip:45000@10.2.251.57> Session-ID: 4fe824fef3d83993017e11e24aa67130;remote=00000000000000000000000000000000 Session-Expires: 1800 Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 243
We then moving onto 183 session progress
v=0 o=CiscoSystemsSIP-GW-UserAgent 2503 7226 IN IP4 10.2.251.57 s=SIP Call c=IN IP4 10.2.251.57 t=0 0 m=audio 8122 RTP/AVP 8 101 c=IN IP4 10.2.251.57 a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 Jul 14 15:51:06.015: //3692/D20100000000/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 100 Trying Via: SIP/2.0/UDP 10.2.251.57:5060;branch=z9hG4bK91C18C From: "SiP Test 45000" <sip:45000@10.2.251.57>;tag=13D3EBA-26AE To: <sip:07973xxxxxx@82.16.19.2> Call-ID: A9658480-C52011EA-8EF3AD4F-A1EA3405@10.2.251.57 CSeq: 102 INVITE Timestamp: 1594741866 Content-Length: 0 Jul 14 15:51:06.074: //3692/D20100000000/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 183 Session Progress Via: SIP/2.0/UDP 10.2.251.57:5060;branch=z9hG4bK91C18C To: <sip:07973xxxxxx@82.16.19.2>;tag=3803730666-1791299518 From: "SiP Test 45000" <sip:45000@10.2.251.57;user=phone>;tag=13D3EBA-26AE Call-ID: A9658480-C52011EA-8EF3AD4F-A1EA3405@10.2.251.57 CSeq: 102 INVITE Allow: UPDATE,PRACK,INFO,NOTIFY,OPTIONS,BYE,INVITE,ACK,CANCEL Contact: <sip:07973xxxxxx@82.16.19.2:5060> Content-Type: application/sdp Content-Length: 252
I then see this
v=0 o=CiscoSystemsSIP-GW-UserAgent 3057 3584 IN IP4 10.0.12.30 s=SIP Call c=IN IP4 10.0.12.30 t=0 0 m=audio 8120 RTP/AVP 8 101 c=IN IP4 10.0.12.30 a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=ptime:20 Jul 14 15:51:06.086: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: PRACK sip:07973xxxxxx@10.0.12.30:5060;transport=tcp SIP/2.0 Via: SIP/2.0/TCP 10.0.12.17:5060;branch=z9hG4bK60b1101193f8 From: "SiP Test 45000" <sip:45000@10.0.12.17>;tag=67135~9c2c55f8-f6da-4001-942f-f8cb268e11d0-36791270 To: <sip:07973xxxxxx@10.0.12.30>;tag=13D3F15-1794 Date: Tue, 14 Jul 2020 15:51:05 GMT Call-ID: d2010000-f0d1d469-3f0d-110c000a@10.0.12.17 User-Agent: Cisco-CUCM11.5 CSeq: 102 PRACK RAck: 5309 101 INVITE Allow-Events: presence Max-Forwards: 70 Content-Type: application/sdp Content-Length: 223
Is this sequence correct:
CSeq: 102 PRACK
After I see my CSeq 102 PRACK and ACK
v=0 o=CiscoSystemsCCM-SIP 67135 1 IN IP4 10.0.12.17 s=SIP Call c=IN IP4 172.19.105.56 b=TIAS:64000 b=AS:64 t=0 0 m=audio 27026 RTP/AVP 8 101 a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 Jul 14 15:51:06.088: //3691/D20100000000/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/TCP 10.0.12.17:5060;branch=z9hG4bK60b1101193f8 From: "SiP Test 45000" <sip:45000@10.0.12.17>;tag=67135~9c2c55f8-f6da-4001-942f-f8cb268e11d0-36791270 To: <sip:07973xxxxxx@10.0.12.30>;tag=13D3F15-1794 Date: Tue, 14 Jul 2020 15:51:06 GMT Call-ID: d2010000-f0d1d469-3f0d-110c000a@10.0.12.17 Server: Cisco-SIPGateway/IOS-16.6.6 CSeq: 102 PRACK Session-ID: f8a7a6d78edc579ab2ba35900b096ba7;remote=4fe824fef3d83993017e11e24aa67130 Content-Length: 0 Jul 14 15:51:13.210: //3692/D20100000000/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 487 Request Terminated Via: SIP/2.0/UDP 10.2.251.57:5060;branch=z9hG4bK91C18C To: <sip:07973xxxxxx@82.16.19.2>;tag=3803730666-1791299518 From: "SiP Test 45000" <sip:45000@10.2.251.57;user=phone>;tag=13D3EBA-26AE Call-ID: A9658480-C52011EA-8EF3AD4F-A1EA3405@10.2.251.57 CSeq: 102 INVITE Allow: UPDATE,PRACK,INFO,NOTIFY,OPTIONS,BYE,INVITE,ACK,CANCEL Contact: <sip:07973xxxxxx@82.16.19.2:5060> Content-Length: 0 Jul 14 15:51:13.211: //3692/D20100000000/SIP/Msg/ccsipDisplayMsg: Sent: ACK sip:07973xxxxxx@82.16.19.2:5060 SIP/2.0 Via: SIP/2.0/UDP 10.2.251.57:5060;branch=z9hG4bK91C18C From: "SiP Test 45000" <sip:45000@10.2.251.57>;tag=13D3EBA-26AE To: <sip:07973xxxxxx@82.16.19.2>;tag=3803730666-1791299518 Date: Tue, 14 Jul 2020 15:51:06 GMT Call-ID: A9658480-C52011EA-8EF3AD4F-A1EA3405@10.2.251.57 Max-Forwards: 70 CSeq: 102 ACK Allow-Events: telephone-event Content-Length: 0
Followed by
Jul 14 15:51:13.214: //3691/D20100000000/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 500 Internal Server Error Via: SIP/2.0/TCP 10.0.12.17:5060;branch=z9hG4bK60b01ac8f481 From: "SiP Test 45000" <sip:45000@10.0.12.17>;tag=67135~9c2c55f8-f6da-4001-942f-f8cb268e11d0-36791270 To: <sip:07973xxxxxx@10.0.12.30>;tag=13D3F15-1794 Date: Tue, 14 Jul 2020 15:51:06 GMT Call-ID: d2010000-f0d1d469-3f0d-110c000a@10.0.12.17 CSeq: 101 INVITE Allow-Events: kpml, telephone-event Server: Cisco-SIPGateway/IOS-16.6.6 Reason: Q.850;cause=16 Session-ID: f8a7a6d78edc579ab2ba35900b096ba7;remote=4fe824fef3d83993017e11e24aa67130 Session-Expires: 1800 Content-Length: 0 Jul 14 15:51:13.216: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: ACK sip:07973xxxxxx@10.0.12.30:5060 SIP/2.0 Via: SIP/2.0/TCP 10.0.12.17:5060;branch=z9hG4bK60b01ac8f481 From: "SiP Test 45000" <sip:45000@10.0.12.17>;tag=67135~9c2c55f8-f6da-4001-942f-f8cb268e11d0-36791270 To: <sip:07973xxxxxx@10.0.12.30>;tag=13D3F15-1794 Date: Tue, 14 Jul 2020 15:51:05 GMT Call-ID: d2010000-f0d1d469-3f0d-110c000a@10.0.12.17 User-Agent: Cisco-CUCM11.5 Max-Forwards: 70 CSeq: 101 ACK Allow-Events: presence Content-Length: 0
Which as you can see is CSeq: 101 again
Hope you can help me out further
07-14-2020 11:54 PM - edited 07-14-2020 11:54 PM
Noticed in your PAI header (in INVITE) for outgoing call leg to ITSP, you just have your extension 'SiP Test 45000" in there. ITSP would want some sort of authentication before they can route the call for customer. I think you're going to need some NR /trunk number in PAI in OUTGOING SIP invite (CallID:C544F9D6-C40E11EA-B9A3B5A2-101A3230) ... Secondly your ITSP is sending you 183 ringing whereas they should ideally be sending 200 OK.
You'd have to create a SIP profile on your CUBE to modify the PAI header if it's that.
Don't want to hijack your troubleshooting as it could be so many things but PAI being sent in INVITE could be one.
07-15-2020 12:06 AM
I've mentioned the 183 ringing and they say that is OK, as this is a new cube and we are just testing the service at the minute, what would need to be in the profile to modify the modify the PAI header
07-15-2020 03:42 AM
voice class sip-profiles 1
request INVITE sip-header P-Asserted-Identity modify "(.*)" "P-Asserted-Identity: <sip:XXXXX@yourSIPRealm>"
XXXXX being your authentication user ID.
Apply the SIP profile on ITSP facing dialpeer (outgoing)
voice-class sip profiles 1
That could be just one of the reasons ITSP could be not letting the call thru. Another test could be to update the matching route pattern in CUCM 'Calling Party Transform Mask' field with valid DDI on your SIP range.
07-20-2020 10:52 AM - edited 07-20-2020 10:55 AM
@mrvoipstuff If Authentication / Authorization mismatch case, the Telco would not allow to place the call. The 183 session progress would also not seen in the logs that is shared by @martynch1
i think @martynch1 you need to share the configuration and the expected call flow with expected matching dial-peers.
peers here can have a look. I will try best if available tomorrow to check and suggest.
07-21-2020 01:22 AM
I think that the 183 early media is sending the announcement, the "your call can't be completed" message. That would be consistent with the carrier following that with a termination. A Wireshark capture would confirm, you can listen to the captured RTP.
I still think the calling number could be an issue. Many SIP providers have their own requirement for the presented calling number, and these vary from provider to provider. The OP earlier showed a debug of a successful outbound call, in that call the calling number was presented in full E164 format.
07-20-2020 10:43 AM
@mrvoipstuff When telecom is sending 183 Ringing which means telecom provider is configured with EARLY MEDIA so that ringback is played. These is normal and should not be issue in my opinion.
07-15-2020 12:52 AM
The sequence number (CSeq) in a Request is it's own label, so other devices can distinguish a repeat or retry of the same request vs a new request. In a Response the CSeq indicates which request the Response is responding to. So for example you send one Invite CSeq 101, then the authenticated Invite is CSeq 102. Further down you can see that the 183 Response includes "CSeq: 102 INVITE" to show which Invite it's related to.
The 183 with early media is perfectly normal. All it means is "the call's not yet connected but there's some audio". In this case presumably the audio is the announcement rejecting the call.
Before we go into detail about how to change headers, has the ITSP actually said how they want the header formatted and what they want it to contain? It's impossible to guess, there is no common convention. Some want the "Contact" header modifier, some want some extra parameter added, etc etc.
Unless someone is using the same carrier as you.
If you want to try things a random an easy test would be to set external number mask of something so you put out a valid DDI in place of the internal number of "45000"
07-15-2020 01:35 AM - edited 07-15-2020 01:59 AM
First of all let me say well done for attempting to break down the logs. I am always a big fan of people who make efforts and show diligence in what they do.
I would like to correct a few things on your analysis, but before I do, let me get to the issue you are facing first.
Here is a sip ladder of your trace (next time please attach the logs rather)
From the ladder, you can see where the issue is.
1. at 7:10:30 your ITSP sends a 183 Session progress with SDP ( indicating that they want to do early media)
2. At 7:10:37 ( 7s after), your get a request terminated from them.
Normally you should get a 200 OK with the same SDP parameter as the 183 Session progress.
Question then is why...did we not get a 200 OK.
My guess is that they want an ACK of the 183 session progress even though they have not requested a PRACK. This is where you need to go back to them and ask Why they are not sending a 200 OK. Do they want PRACK for 183 if they do they need to include "Require: 100rel" in their SDP
++ Back to your PRACK analysis ++
PRACK uses a combination of Rseq and Rack numbers to identify the exact PRACK messages.
In this log,
CUBE sends PRACK to CUCM
Sent:
CSeq: 101 INVITE
Require: 100rel
RSeq: 8573
++ CUCM sends PRACK with Rack of the Rseq number ++
Received:
CSeq: 102 PRACK
++ CUBE sends a 200 OK to complete PRACK ++
Sent:
SIP/2.0 200 OK
CSeq: 102 PRACK
++ In your log example, you are confusing the dialog between CUCM and CUBE and that between CUBE and ITSP ++
This PRACK is from CUCM and The INVITE to CUCM is Cseq 101 and the 183 Session progress has Rseq 5309 for PRACK
