04-09-2019 05:40 PM
Hi guys.
Please if you can assist on this on the 4451.
We have an issue where the Outgoing Dial Peer is not being picked. When the Router receives 10332026 as an example it will not pick the Outgoing Dial Peer. The Outgoing Dial Peer is 14 which has the FXO Port 0/3/4 on it.
dial-peer voice 13 voip
destination-pattern 4070.
session target ipv4:XXXX
dtmf-relay h245-signal
dial-peer voice 14 pots
preference 1
destination-pattern 103.....
port 0/3/4
forward-digits 5
Note : We can dial to 40701 and both way voice is possible but the issue is when 40701 dials to this side. We can see that the digits 10332026 is recieved but it will not pick the Dial Peer 14 at the Outgoing.
But when we do show dialplan number 10332026, it picks the correct the Dial peer - 14. The details is as follows:
peer type = voice, system default peer = FALSE, information type = voice,
description = ` Remote Site 1 ',
tag = 14, destination-pattern = `103.....',
voice reg type = 0, corresponding tag = 0,
allow watch = FALSE
answer-address = `', preference=1,
CLID Restriction = None
CLID Network Number = `'
CLID Second Number sent
CLID Override RDNIS = disabled,
rtp-ssrc mux = system
source carrier-id = `', target carrier-id = `',
source trunk-group-label = `', target trunk-group-label = `',
numbering Type = `unknown'
group = 14, Admin state is up, Operation state is up,
Outbound state is up,
incoming called-number = `',
connections/maximum = 0/unlimited,
DTMF Relay = disabled,
URI classes:
Destination =
Destination route-string = None
huntstop = disabled,
in bound application associated: 'DEFAULT'
out bound application associated: ''
dnis-map =
permission :both
incoming COR list:maximum capability
outgoing COR list:minimum requirement
Translation profile (Incoming):
Translation profile (Outgoing):
incoming call blocking:
translation-profile = `'
disconnect-cause = `no-service'
advertise 0x40 capacity_update_timer 25 addrFamily 0 oldAddrFamily 0
mailbox selection policy: none
type = pots, prefix = `',
forward-digits 5
session-target = `', voice-port = `0/3/4,
direct-inward-dial = disabled,
digit_strip = enabled,
register E.164 number with H323 GK and/or SIP Registrar = TRUE
fax rate = system, payload size = 20 bytes
supported-language = ''
preemption level = `routine'
bandwidth:
maximum = 64 KBits/sec, minimum = 64 KBits/sec
voice class called-number:
inbound = `', outbound = `'
dial tone generation after remote onhook = enabled
mobility=0, snr=, snr_noan=, snr_delay=0, snr_timeout=0
snr calling-number local=disabled, snr ring-stop=disabled, snr answer-too-soon timer=0
Time elapsed since last clearing of voice call statistics never
Connect Time = 19106, Charged Units = 0,
Successful Calls = 2, Failed Calls = 0, Incomplete Calls = 0
Accepted Calls = 4, Refused Calls = 0,
Last Disconnect Cause is "10 ",
Last Disconnect Text is "normal call clearing (16)",
Last Setup Time = 6073391.
Last Disconnect Time = 6074437.
Matched: 10332026 Digits: 3 Matched pattern: 103..... Preference: 1
debug voip dialpeer all - This where the Outgoing Dial Peer is not picked.
*Apr 9 22:00:43.511: //-1/A389CA608294/DPM/dpAssociateIncomingPeerCore:
Calling Number=40701, Called Number=10332026, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_INCOMING_DNIS; Called Number=10332026
*Apr 9 22:00:43.511: //-1/A389CA608294/DPM/dpMatchPeertype:
Is Incoming=TRUE, Number Expansion=FALSE
*Apr 9 22:00:43.511: //-1/A389CA608294/DPM/dpMatchCore:
Dial String=10332026, Expanded String=10332026, Calling Number=
Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
Result=-1
*Apr 9 22:00:43.511: //-1/A389CA608294/DPM/dpMatchPeertype:exit@7300
Match Rule=DP_MATCH_ANSWER; Calling Number=40701
Dial String=, Expanded String=, Calling Number=40701T
Result=-1
Match Rule=DP_MATCH_ORIGINATE; Calling Number=40701
*Apr 9 22:00:43.512: //-1/A389CA608294/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=13 Is Matched (4 digits)
*Apr 9 22:00:43.512: //-1/A389CA608294/DPM/dpMatchPeertype:exit@7300
*Apr 9 22:00:43.512: //-1/A389CA608294/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=13
*Apr 9 22:00:43.512: //-1/A389CA608294/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
*Apr 9 22:00:43.512: //-1/A389CA608294/DPM/dpAssociateIncomingPeerSPI:exit@7882
*Apr 9 22:00:43.512: //-1/A389CA608294/DPM/dpMatchCore:
Result=-1
Result=-1
*Apr 9 22:00:43.513: //-1/A389CA608294/DPM/MatchNextPeer:
*Apr 9 22:00:43.513: //-1/A389CA608294/DPM/dpMatchPeertype:exit@7300
*Apr 9 22:00:43.513: //-1/A389CA608294/DPM/dpAssociateIncomingPeerCore:
*Apr 9 22:00:43.513: //-1/A389CA608294/DPM/dpMatchSafModulePlugin:
*Apr 9 22:00:43.513: //-1/A389CA608294/DPM/dpAssociateIncomingPeerSPI:exit@7882
*Apr 9 22:00:53.724: //-1/A9C6779D8299/DPM/dpAssociateIncomingPeerCore:
*Apr 9 22:00:53.724: //-1/A9C6779D8299/DPM/dpMatchPeertype:
*Apr 9 22:00:53.724: //-1/A9C6779D8299/DPM/dpMatchCore:
Result=-1
*Apr 9 22:00:53.724: //-1/A9C6779D8299/DPM/dpMatchPeertype:exit@7300
Result=-1
*Apr 9 22:00:53.725: //-1/A9C6779D8299/DPM/MatchNextPeer:
*Apr 9 22:00:53.725: //-1/A9C6779D8299/DPM/dpMatchPeertype:exit@7300
*Apr 9 22:00:53.725: //-1/A9C6779D8299/DPM/dpAssociateIncomingPeerCore:
*Apr 9 22:00:53.725: //-1/A9C6779D8299/DPM/dpMatchSafModulePlugin:
*Apr 9 22:00:53.725: //-1/A9C6779D8299/DPM/dpAssociateIncomingPeerSPI:exit@7882
*Apr 9 22:00:53.725: //-1/A9C6779D8299/DPM/dpMatchCore:
Result=-1
Result=-1
*Apr 9 22:00:53.726: //-1/A9C6779D8299/DPM/dpMatchPeertype:exit@7300
04-09-2019 09:50 PM
Hi guys
Got this error as well when using csim start 10332026
#csim start 10332026
csim: Test started.This command can only be run one at a time.
csim: called number = 10332026, loop count = 1 ping count = 0
csim err:csim_do_test invalid major major(1024) minor(0x0)
csim err csimDisconnected recvd DISC cid(310)
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
04-09-2019 09:57 PM
Hi all.
Please find below the details of the tests. Please requesting for someone to assist. The csim start 10332026 states that the call is presented to the local router but correct dial peer is not being picked up in the local which would make the voice-port 0/3/4 ring.
Remote Router.
Local Router. debug voip dialpeer all
*Apr 10 04:53:34.121: //-1/513B576782E0/DPM/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=10332026, Voice-Interface=0x0,
*Apr 10 04:53:34.121: //-1/513B576782E0/DPM/dpMatchPeertype:
*Apr 10 04:53:34.122: //-1/513B576782E0/DPM/dpMatchCore:
Result=-1
*Apr 10 04:53:34.122: //-1/513B576782E0/DPM/dpMatchPeertype:exit@7300
*Apr 10 04:53:34.122: //-1/513B576782E0/DPM/dpAssociateIncomingPeerCore:
Result=NO_MATCH(-1) After All Match Rules Attempt
*Apr 10 04:53:34.122: //-1/513B576782E0/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
*Apr 10 04:53:34.122: //-1/513B576782E0/DPM/dpAssociateIncomingPeerSPI:exit@7882
Result=-1
04-10-2019 01:42 AM
Do you have any number-expansions configured or any voice translation configured?
Once you make test call search
show call history voice compact
<callID> A/O FAX T<sec> Codec type Peer Address IP R<ip>:<udp> disc-cause
142353 ANS T51 g711ulaw VOIP P1480 172.22.21.36:24818 D10
142354 ORG T51 g711ulaw TELE P996481732 D10
Then paste the output of all the relevant callid here to analyze.
VG#show call history voice callid 142353
Telephony call-legs: 0
SIP call-legs: 1
H323 call-legs: 0
Call agent controlled call-legs: 0
Total call-legs: 1
04-10-2019 02:32 AM
Hi Harris
There isn't any calls shown when I ran the command on the local router.
But when I configure FXS Port 0/3/0 and dial 10332038 on the local router the calls are successful. But this is confined to the local Router.
The problem is when the calls originate from the remote router.
The remote router has the following translation.
voice translation-rule 1
rule 1 // /103/
voice translation-profile prefix
translate called 1
voice-port 0/1/0
timing hookflash-in 500 150
voice-port 0/1/1
dial-peer voice 1 voip
dial-peer voice 2 pots
translation-profile incoming prefix
destination-pattern 40701
port 0/1/0
Please if you can assist.
