10-11-2021 09:24 AM
Greetings,
I have cisco VG configured as H323 With 1 PSTN LINE on FXO port.
I have Call Manager 11.5.
On call Manager i configured gateway as H323. Created Route patterns with Gateway.
9.05[0-4]XXXXXXX for 10 digit mobile
9.[2-4]XXXXXX for 7 digit local call
9.0[23679]XXXXXXX for 9 digit national call
9.8XXXXXX for 7 digit services number
9.9XX for emergency number
On gateway I have following pots dial-peer for outgoing calls.
dial-peer voice 101 pots
destination-pattern 9T
port 0/1/0
and VOIP dial-peer for incoming calls pointing to CUCM.
Now local, emergency, services calls are working fine. But when making a mobile or national call, it rings on the mobile once and gives message " Your call cannot be completed as dial, please confirm your directory and call again..... "
I have attached the debug for outgoing calls.
Kindly advice.
Solved! Go to Solution.
10-11-2021 03:02 PM
You may want to start with verifying that the CSS on the phone has the access to the partition of route pattern mobile or national call.
suppose your Phone CSS is CSS-phone.
Route pattern 9.05[0-4]XXXXXXX is in partition pt-Mobile
Route pattern 9.0[23679]XXXXXXX is in partition pt-National
Make sure CSS-Phone has access to the above pt-Mobile and pt-National patterns.
Also make sure you are sending the correct calling number to your provider. You can also use "Calling Party Transform Mask" setting on these route pattern and put main DID number provided by PSTN provider.
Hope this helps.
If this was useful, please mark it "helpful" or "accept as solution".
10-13-2021 02:52 AM
Thank you for your reply,
Finally I managed to solve the issue it was with FXO port.
Earlier I was using few parameters, i removed all and all In out calls are working fine.
10-11-2021 03:02 PM
Hope this helps.
10-13-2021 02:52 AM
10-11-2021 07:05 PM - edited 10-11-2021 07:06 PM
When dialling 10 digit mobile number, VG is using dial-peer "Outgoing Dial-peer=102". And when dialling 7 digit number its using 101 dial-peer.
Whats your 102 dial-peer?
Since its an analogue line , Calling number has no role and external phone number mask doesn't make any impact on the call.
10-13-2021 02:53 AM
Appreciate your reply.
