Highlighted
Beginner
Outgoing voice calls suddenly not working - incoming fine
We have 2 IAD2431-16FXS unit that have been in service for a couple of years working fine. Calling into an analogue line works fine but just recently calling out from the phone causes the line to go silent indefinitely.
What command can I use to diagnose the problem?
Below is the results of the voice trace and further below is the summary configuration.
SPC-TEL-T3B2-IAD3#sh voice trace 2/9
2/9 State Transitions: timestamp (state, event) -> (state, event) ...
95.584 (FXSLS_ONHOOK, E_DSP_SIG_1100) ->
95.604 (FXSLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK) ->
104.576 (FXSLS_OFFHOOK, E_HTSP_PROCEEDING) ->
114.908 (FXSLS_OFFHOOK, E_DSP_SIG_0100) ->
115.908 (FXSLS_OFFHOOK, E_HTSP_EVENT_TIMER) ->
115.912 (FXSLS_WAIT_RELEASE_REQ, E_HTSP_RELEASE_REQ) ->
115.916 (FXSLS_ONHOOK, E_DSP_SIG_0100) ->
no aaa new-model
clock timezone AEST 10
no ip source-route
voice service voip
fax protocol cisco
sip
bind control source-interface FastEthernet0/1
bind media source-interface FastEthernet0/1
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice translation-rule 1
rule 1 /.*\(..\)$/ /2\1/
voice translation-rule 2
rule 1 /.*\(..\)$/ /07555502\1/
voice translation-profile IN
translate called 1
voice translation-profile OUT
translate calling 2
voice-card 0
interface FastEthernet0/0
description SPC link
ip address 192.168.2.21 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex full
speed auto
description Spirit Link
ip address 103.233.227.2 255.255.255.252
ip nat outside
duplex auto
speed auto
ip http server
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 103.233.227.1
no ip nat service sip udp port 5060
ip nat inside source list 1 interface FastEthernet0/1 overload
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.2.0 0.0.0.255
control-plane
voice-port 2/0
cptone AU
station-id number 201
caller-id enable
etc
dial-peer voice 201 pots
description Lift 1
destination-pattern 0755550201
port 2/0
no sip-register
etc
dial-peer voice 1 voip
translation-profile outgoing OUT
destination-pattern [01].........
voice-class codec 1
session protocol sipv2
session target sip-server
incoming called-number .
dtmf-relay sip-kpml rtp-nte sip-notify
no vad
sip-ua
credentials username 0755550201 password 7 x realm trunk.voxcom.net.au
authentication username 0755550201 password 7 x
no remote-party-id
registrar dns:trunk.voxcom.net.au expires 3600
sip-server dns:trunk.voxcom.net.au
Everyone's tags (1)
1 ACCEPTED SOLUTION
Beginner
Re: Outgoing voice calls suddenly not working - incoming fine
debug ccsip
debug ccsip messages
then found the problem: SIP/2.0 401 Unauthorized
1 REPLY 1
Beginner
debug ccsip
Content for Community-Ad
August's Community Spotlight Awards
