05-14-2013 02:15 PM - edited 03-16-2019 05:18 PM
I am going to install CM 9.1 BE , I am not sure which OVA template i shld use as per the below, Can anybody route me to proper docs for understanding which is appropriate for my situation and what is the difference between both.
cucm_9.1_vmv8_v1.6.ova
OR
cucm_9.1_vmv7_v1.6.ova
Solved! Go to Solution.
05-14-2013 02:41 PM
05-14-2013 03:20 PM
If you want to further read about differences between Virtual Machine v7 vs v8, you'll need to review such info in the VMWare site as we do not have anything within Cisco explaining that.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
05-14-2013 02:41 PM
vmv8 is for ESXI 5.x
vmv7 is for ESXI 4.1
05-14-2013 03:20 PM
java
