04-16-2015 12:33 AM - edited 03-17-2019 02:40 AM
Is there an easy way to get an overview of all the scripts that are being used in UCCX 7.X
We see the need to document alot of them
Kind Regards,
Yannick Vranckx
04-16-2015 01:23 AM
Not really - the list of applications will show you which primary scripts are in use, however other scripts may be called from those as Sub Flows and so on.
Basically you will need to go through them all.
Aaron
04-16-2015 06:57 AM
Yannick,
May I ask, how do you plan to document the scripts? What does that process look like for you?
Tanner Ezell
04-20-2015 06:30 AM
Well,
At this very moment making an overview of the script + the settings in an excel with the information from the applications in UCCX7.X.
When this is done, calling each script to determine the flowchart in Visio, so a bit of backtracking
