% page usage peak
hjacquemin
Hello everoyne,
We problem on one of our server, times to times I have a "memory leak" on my Publisher, the %page usage is more than 90%.
The only way to "release" the memory I found is to reboot the server.
Maybe on of you know another solution ? What can cause such memory leak ?
Hervé Jacquemin
hjacquemin
for info,
System version: 7.1.5.33900-10
most likely a defect that would cause it. Did you check the bug toolkit for the CUCM version ?
GP.
What would you mean by defect, a faulty memory module ?
I found nothing in the bug tool.
So I will open a case.
By saying defect, I meant a bug in the CUCM software. However, an issue with hardware can also be the cause.
GP.
