10-04-2013 09:17 AM - edited 03-16-2019 07:42 PM
Hello! I have a Bogen Classic C-100 working in conjunction with a Wheellock into an FXO Port on my voice gateway that I'd like to use for paging.
I've confirmed with TAC that everything is configured correctly in CUCM. When I call my paging extension, I get a tone (which I assume is coming from the Wheellock as the Bogen does not send a tone), but I hear nothing I speak com out over the speakers. If I break the cable connection and dial the extension, I immediately get a busy signal.
In speaking with Bogen, they said that the port has to be configured for "600 ohms dry audio". Is anyone familiar with how the FXO port needs to be configured in order to do this?
10-04-2013 09:45 AM
James,
On your fxo router/gateway
voice-port 0/1/0
description *** FXO TO BOGEN KIT ***
impedence 600r
Alex.
Please rate useful posts.
10-04-2013 10:08 AM
Thanks, Alex!
The gateway took the command with no errors but I am not seeing it on the port:
voice-port 0/3/1
no battery-reversal
description HQ Paging System
Is this normal? Forgive me as I don't have much experience with FXO.
Thanks for your help!
10-04-2013 10:20 AM
Hello
please ,do
# show voice port 0/3/1 .
Thank you
please rate all useful information
10-04-2013 10:23 AM
please find the below example
Router# show voice port 1/0/0
E&M Slot is 1, Sub-unit is 0, Port is 0
Type of VoicePort is E&M
Operation State is unknown
Administrative State is unknown
The Interface Down Failure Cause is 0
Alias is NULL
Noise Regeneration is disabled
Non Linear Processing is disabled
Music On Hold Threshold is Set to 0 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 0 dB
Echo Cancellation is disabled
Echo Cancel Coverage is set to 16ms
Connection Mode is Normal
Connection Number is not set
Initial Time Out is set to 0 s
Interdigit Time Out is set to 0 s
Analog Info Follows:
Region Tone is set for northamerica
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Voice card specific Info Follows:
Signal Type is wink-start
Operation Type is 2-wire
Impedance is set to 600r Ohm
E&M Type is unknown
Dial Type is dtmf
In Seizure is inactive
Out Seizure is inactive
Digit Duration Timing is set to 0 ms
InterDigit Duration Timing is set to 0 ms
Pulse Rate Timing is set to 0 pulses/second
InterDigit Pulse Duration Timing is set to 0 ms
Clear Wait Duration Timing is set to 0 ms
Wink Wait Duration Timing is set to 0 ms
Wink Duration Timing is set to 0 ms
Delay Start Timing is set to 0 ms
Delay Duration Timing is set to 0 ms
Thank you
