10-09-2012 07:51 AM - edited 03-16-2019 01:35 PM
Hello
I am trying to configure a CCME Router and have two IP Phones as parallel lines.
But I am getting a feedback that only one of them rings when I am trying to call to their common number. Both phones are registered and configured as follows:
Can somebody please advice how to fix this?
ephone-dn 4
number 189
label Phone #4
description 189
ephone-dn 8
number 189
label Phone #8
description 189
ephone 4
device-security-mode none
description Phone4
mac-address ECC8.82B0.3B37
codec g729r8
type 7942
button 1:4
ephone 8
description Phone8
mac-address D057.4C6A.12FD
codec g729r8
type 7942
button 1:8
Many Thanks in advance.
Kaushik
Solved! Go to Solution.
10-09-2012 08:11 AM
Hello configure a Shared Line:
Try this way:
ephone-dn 4
number 189
label Phone #4
description 189
ephone 4
description Phone4
codec g729r8
type 7942
button 1:4
ephone 8
description Phone8
codec g729r8
type 7942
button 1:4
Rate this if helps
Leonardo Santana
10-09-2012 08:11 AM
Try this way:
ephone-dn 4
number 189
label Phone #4
description 189
ephone 4
description Phone4
codec g729r8
type 7942
button 1:4
ephone 8
description Phone8
codec g729r8
type 7942
button 1:4
Rate this if helps
Leonardo Santana
10-10-2012 02:17 AM
Leonardo
Thanks a lot for the reply and it is indeed working now with the changes you suggested.
