02-25-2016 03:37 AM - edited 03-17-2019 06:01 AM
Dear all,
Can any one share a document which will solve below queries:
1. We are running CUCM 10.5 version with Cisco unity (with connection SIP trunk) and IM and presence integrated with CUCM and CUAC running in th setup,Also VCS control and VCS expressway,TMS in the cluster.
2.Since some security issue we are planning to change below passwords.
Application user name and password
Administrator Account user name and password
Security password,OS administration.
3.Can any one share command/Procedure to achieve the same
4.Also what precaution needs to be taken during this activity
Ajith
Solved! Go to Solution.
02-25-2016 05:45 AM
Changing the passwords wont impact this at all but cluster reboot during security password change makes it unavailable for some time during the reboot depending on the CM group configuration.
02-25-2016 05:47 AM
It will not impact the integration with VCS or Expressway series servers.
Manish
02-25-2016 03:56 AM
Hi Ajith,
You can refer below doc:
https://supportforums.cisco.com/document/65041/how-reset-passwords-cucm#Reset_Administrator_and_Security_passwords_on_CUCM_5
Rajan
02-25-2016 04:03 AM
Dear Rajan,
Thanks for your kind reply, However This forum only gives information till version8.X
In CUCM 10.5 the commands are changed
Also I need the Proper steps to change the OS admin password/security password etc
02-25-2016 04:12 AM
These are the new commands for 10.x
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/cli_ref/10_0_1/CUCM_BK_CBEED39F_00_cucm-cli-reference-guide-100/CUCM_BK_CBEED39F_00_cucm-cli-reference-guide-100_chapter_01001.html#CUCM_CL_U39BF1C4_00
02-25-2016 04:16 AM
Dear Rajan,
Is there any dedicated guide from cisco which will help me to do this activity?
Also need t know the precautions to be taken care/impacts/outage etc
02-25-2016 04:18 AM
Only thing you need to take care is that you reset security password in the correct order mentioned in that document and reboot the cluster.
02-25-2016 04:23 AM
Dear Rajan,
I understand this activity needs to be done on pub and followed by all subscribers.
To my knowledge when we change security password and if we have IM and presence in the cluster along with unity connection,as far as i know we need to change the ecurity password in IM and password. But I have bit confusion towards unity connection as we have a sip integration with CUCM do I have to do the changes in unity connection?
Also if we have a Contact center Express in this environment do we have to make any changes in Contact center Express as well?
thx!!
02-25-2016 05:16 AM
Hi Ajith,
Not mandatory to change it on UC and UCCX but IM&P is mandatory since starting from 10.x, IM&P server is added in System --> Server menu in CUCM and this also becomees part of the CUCM cluster. Hence needs to get authenticated using security password with CUCM pub.
Hope this clarifies.
Rajan
02-25-2016 05:31 AM
Ohh great !!
Looks like you have almost solved my confusion,
a last query Assume my video codecs are register on cucm and i have VCS control and expressway along with TMS integrated will it impact this servers?
To my understanding it should not but still I would like to know if it going to impact this servers?
02-25-2016 05:45 AM
02-25-2016 05:53 AM
Thanks Rajan !! I think i got what I was looking for.. !!
02-25-2016 05:54 AM
you are welcome Ajith. Glad it helped :)
Rajan
02-25-2016 06:20 AM
HI Ajith,
you need to change the OS password in all servers in a cluster.
Lastly, after u change the OS password , your PLM would go out of Sync.
You need to change the password in existing product instance of PLM for synchronization.
regds,
aman
02-25-2016 10:35 PM
Thanks for this update Aman ji..!!
02-25-2016 05:47 AM
Manish
