password for uc500
hi folks,
i am not able to log into UC500 box.
the manual says i should get the DHCP when connected to box .but i am not getting
can somebody tell me what is the default password for UC500 box.
or how to set it to default value.
or password recovery.
thx for ur consideration.
5 Replies 5
paolo bevilacqua
Connect via serial cable to console port. As the banner indicates, the default is cisco/cisco.
thx but its not working.
cisco/cisco is not working somebody might have changed it. i am working in my lab on this box.
any password recovery.
Apply the standard router password recovery:
http://cisco.com/en/US/products/hw/routers/ps259/products_password_recovery09186a0080094675.shtml
hope this helps, please rate post if it does!
As I recall, I think the default username / password for my UC520 was:
username: Cisco
password: Cisco
(Note the C is upper case)
How do I find the IP address for CCA
