password recovery, linux based unity connection
ReadersUK
Explorer
Explorer
Can anyone help me recovery procedure for the admin password on a linux based unity connection box. I have a remote system i cant get in to and have to talk a local IT guy though the process.
Colin
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
Resetting Administrator and Security Passwords
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/connection/8x/os_administration/guide/8xcucosag020.html#wp1053218
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Thanks for your fast response but i cant access that link it says i don't have the right privilege on my logon.
colin
Jaime Valencia
Whenever that happens just copy the link and remove partner/ from the URL and try again.
java
java
Java
This is link is highly useful ! Thanks.
Recognize Your Peers
