password recovery VG320
monasir
Hi everyone,
I've configured a basic configuration for the VG320 analog gateway, ive copied pasted the running config in the gw.
I'm not able to login anymore because i cannot retrieve the password.
Is there a possibility to do a password recovery?
2 Accepted Solutions
Manish Gogna
Plz check this, it applies to VG3XX as well
http://www.cisco.com/c/en/us/support/docs/routers/2600-series-multiservice-platforms/22188-pswdrec-2600.html
Manish
Nadeem Ahmed
Edit: Connect console cable directly with laptop and VG350 then perform below steps for recovery of password
1) Power off the router
2) Turn it back on
3) Break into rommon
4) Enter "confreg 0x2142"
5) Enter "reset"
6) An empty router will come up
7) Enter "copy startup-config running-config"
8) This will load the usual configuration of the router into  NVRAM
9) Change the passwords as required.
10) Enter "conf t" then in global config enter "config-register 0x2102"
11) Write to memory
11) Reload router and test password.
Br,
Nadeem Ahmed
Br, Nadeem Please rate all useful post.
Manish Gogna
Manish
Nadeem Ahmed
2) Turn it back on
5) Enter "reset"
11) Write to memory
Br,
Nadeem Ahmed
