Pause Dialing in VoIP Dial-Peer
whenusayloveme
Hi All
I have the problem to dial the pattern like this on VoIP dial-peer (both SIP/H323)
4000,,,,9099
It work fine with Pots dial-peer
Any solution that we can achieve it? Please help.
B.R.
Winai
TexasBrandon
This is kind of broad.  What is happening?  What is the configuration like on the Dial-peer voice voip versus the Dial-peer pots?  We need more information.
paolo bevilacqua
VoIP dial-peer do not support pauses.
If you need something to acces IVR in an automatic way, you can use my script "speed-dial with pauses", it can be acquired on the website mentioned in my profile.
