08-23-2011 08:35 AM - edited 03-16-2019 06:38 AM
Dear Support,
I have a weird issue while on SRST. I have a PBX integrated with Q-Sig. The calls from the PBX works fine when the CUCM is available but in SRST the called number on the GW appears only first 5 digits where as the PBX sends 7 digits to the GW.
The scenario:
CUCM ---- GW (Q-Sig Trunk) --- PBX..
Aug 20 03:17:09: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x3F61
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18384
Preferred, Channel 4
Facility i = 0x9FAA068001008201008B0100A1100201010201553008820301B850860101
Facility i = 0x9FAA068001008201008B0100A115020102020100800D5A2053746566616E6F76736B69
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0181, '68152' ------------------------------------------------------àPBX DECT Phone Number
Plan:ISDN, Type:Unknown
Called Party Number i = 0x89, '3012301' -----------------------------------------------------à Cisco IP Phone
Plan:Private, Type:Unknown
User-User i = 0x00FE, 'U', 0x0100, 'Y', 0x0100B00C070981, '12301', 0x0F0F82818B, 'ZStefanovski'
Shift to Codeset 4
During SRST..
Aug 20 03:29:21: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x3F69
Standard = CCITT
Channel ID i = 0xA1838C
Preferred, Channel 12
Facility i = 0x9FAA068001008201008B0100A113020102020100800B5A6F72696E612054657374
Called Party Number i = 0x89, '30123'
User-User i = 0x00FE, 'U', 0x0100, 'Y', 0x0100B00C070981, '68152', 0x0F0D828684, 'ZorinaTest'
Shift to Codeset 4
Codeset 4 IE 0x31 i = 0x80
Aug 20 03:29:21: ISDN Se0/2/0:15 Q931: TX -> SETUP_ACK pd = 8 callref = 0xBF69
Channel ID i = 0xA9838C
Exclusive, Channel 12
Aug 20 03:29:21: ISDN Se0/2/0:15 Q931: RX <- INFORMATION pd = 8 callref = 0x3F69
Called Party Number i = 0x89, '0'
Called Party Number i = 0x89, '1'
Here, the weird part is.. after the 5 digits, the GW receives the balance 2 digits one-by-one.
Called No: 3012301
Calling No: 68152
08-23-2011 08:39 AM
Can we see the router config
Alex
08-23-2011 08:49 AM
Here you goo...
vg3845#sh running-config
Building configuration...
Current configuration : 22638 bytes
! Last configuration change at 11:50:36 UTC Tue Aug 23 2011 by rchand41
! NVRAM config last updated at 11:51:47 UTC Tue Aug 23 2011 by rchand41
version 15.0
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname ahogw001-vg3845
boot-start-marker
boot system flash:c3845-spservicesk9-mz.150-1.M4.bin
boot system flash:c3845-spservicesk9-mz.124-15.T12.bin
boot-end-marker
card type e1 0 1
card type e1 0 2
card type e1 1 0
logging buffered 16384
no logging console
enable secret 5 $1$Eor9$ccFl/Ob0kT54Aos7PReDW.
aaa new-model
aaa authentication login default group tacacs+ enable
aaa authentication enable default group tacacs+ enable
aaa authorization config-commands
aaa authorization commands 0 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa accounting update newinfo
aaa accounting commands 15 default
action-type start-stop
group tacacs+
aaa session-id common
network-clock-participate slot 1
network-clock-participate wic 1
network-clock-participate wic 2
network-clock-select 1 E1 0/1/1
network-clock-select 2 E1 0/2/0
dot11 syslog
ip source-route
ip cef
ip domain list nls.XXX.com
ip domain list nlse.XXX.com
ip name-server X.X.X.X
ip multicast-routing
no ipv6 cef
isdn switch-type primary-4ess
voice-card 0
dspfarm
dsp services dspfarm
voice-card 1
dspfarm
voice call send-alert
voice call convert-discpi-to-prog
voice rtp send-recv
voice service voip
h323
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
h225 timeout tcp establish 3
voice translation-rule 1
rule 1 /\(^[23]...$\)/ /301\1/
voice translation-rule 2
rule 1 /^8301\(....$\)/ /301\1/
voice translation-rule 3
rule 1 /301\(....$\)/ /38301\1/
voice translation-profile Internal-to-PhoneDN
translate called 1
voice translation-profile PSTN-to-PhoneDN
translate called 2
voice translation-profile PhoneDN-to-PSTN
translate calling 3
application
global
service alternate DEFAULT
controller E1 0/1/0
pri-group timeslots 1-31 service mgcp
controller E1 0/1/1
framing NO-CRC4
controller E1 0/2/0
framing NO-CRC4
controller E1 0/2/1
framing NO-CRC4
controller E1 1/0/0
controller E1 1/0/1
ip tcp path-mtu-discovery age-timer 30
interface Loopback0
description desc="Management Interface"
ip address X.X.X.X 255.255.255.255
h323-gateway voip interface
h323-gateway voip bind srcaddr X.X.X.X
interface GigabitEthernet0/0
description rhost="abc" rint="Gi1/46" trunk="N" chan="N" speed="1Gb" dept="" phsrp="N" shsrp="N"
ip address X.X.X.X 255.255.255.248
ip ospf authentication message-digest
ip ospf message-digest-key 1 md5 7 045F0E050A2C4E4B1B405357
load-interval 30
duplex full
speed 1000
media-type sfp
negotiation auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface Serial0/1/0:15
description rhost="" rint="" tname="
no ip address
encapsulation hdlc
no logging event link-status
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn bchan-number-order ascending
no cdp enable
interface Serial0/1/1:15
description rhost= E1 Connection to Ericsson MD110 BC12 PABX
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn supp-service name calling profile Network-Extension operation-value-tag local
isdn contiguous-bchan
no cdp enable
interface Serial0/2/0:15
no ip address
encapsulation hdlc
no cdp enable
interface Serial0/2/1:15
description PRI Not in Use
no ip address
encapsulation hdlc
no cdp enable
interface GigabitEthernet0/3/0
description rhost="abc" rint="Gi1/47" trunk="N" chan="N" speed="1Gb" dept="" phsrp="N" shsrp="N"
ip ospf message-digest-key 1 md5 7 050F030C24414C0C0B5C41
load-interval 30
negotiation auto
router ospf 65420
log-adjacency-changes
auto-cost reference-bandwidth 10000
area 301 authentication message-digest
area 301 nssa
passive-interface default
no passive-interface GigabitEthernet0/0
no passive-interface GigabitEthernet0/3/0
network X.X.X.X 0.0.0.0 area 301
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
no ip pim dm-fallback
ip tacacs source-interface Loopback0
ip sla responder
logging trap debugging
logging source-interface Loopback0
logging 19.97.9.50
logging 19.97.9.80
control-plane
voice-port 0/1/0:15
echo-cancel coverage 64
cptone AU
voice-port 0/2/0:15
cptone AU
voice-port 0/2/1:15
cptone AU
voice-port 0/1/1:15
cptone AU
ccm-manager fallback-mgcp
ccm-manager redundant-host X.X.X.X
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server X.X.X.X X.X.X.X
ccm-manager config
mgcp
mgcp call-agent X.X.X.X 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp ip qos dscp cs3 signaling
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax rate 7200
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface Loopback0
mgcp bind media source-interface Loopback0
mgcp profile default
sccp local Loopback0
sccp ccm X.X.X.X identifier 2 version 5.0.1
sccp ccm X.X.X.X identifier 1 version 5.0.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 2 register CFB-ABC
associate profile 1 register XCD-ABC
dspfarm profile 1 transcode
description XCODE dsp farm - G711 <> G729r8 only
codec g711ulaw
codec g711alaw
codec g729r8
maximum sessions 21
associate application SCCP
dspfarm profile 2 conference
description Ad-hoc conference - G711 only
codec g711ulaw
codec g711alaw
maximum sessions 35
dial-peer voice 1001 pots
tone ringback alert-no-PI
description --- Incoming PSTN Trunk form 38301XXXX only ---
translation-profile incoming PSTN-to-PhoneDN
incoming called-number .
direct-inward-dial
port 0/1/0:15
dial-peer voice 1002 pots
description --- Incoming PBX Trunk form XXXX only ---
direct-inward-dial
port 0/1/1:15
dial-peer voice 1003 pots
direct-inward-dial
port 0/2/0:15
dial-peer voice 1004 pots
direct-inward-dial
port 0/2/1:15
dial-peer voice 3001 voip
description --- FOR SRST only / generic incoming VoIP peer ---
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
fax-relay ecm disable
fax rate 7200
no vad
dial-peer voice 2001 pots
description --- FOR SRST only / PRI Voice Trunk: 0+001 --- IDD Calls
translation-profile outgoing PhoneDN-to-PSTN
destination-pattern 0001T
progress_ind setup enable 3
progress_ind alert enable 8
direct-inward-dial
port 0/1/0:15
prefix 001
dial-peer voice 2002 pots
description --- FOR SRST only / PRI Voice Trunk: 0+[29] --- Local Calls
destination-pattern 0[2-9].......$
direct-inward-dial
port 0/1/0:15
forward-digits 8
dial-peer voice 2003 pots
description --- FOR SRST only / PRI Voice Trunk: 0+04 --- Mobile calls
destination-pattern 004........$
direct-inward-dial
port 0/1/0:15
prefix 04
dial-peer voice 2004 pots
description --- FOR SRST only / PRI Voice Trunk: 0+0[2356789] --- National C
destination-pattern 00[2356789]........
direct-inward-dial
port 0/1/0:15
prefix 0
dial-peer voice 2005 pots
description --- FOR SRST only / PRI Voice Trunk: 0+000 --- Emergency Calls
destination-pattern 0000$
direct-inward-dial
port 0/1/0:15
prefix 000
dial-peer voice 2006 pots
description --- FOR SRST only / PRI Voice Trunk: 0+1800 --- Toll free Number
destination-pattern 01800......
direct-inward-dial
port 0/1/0:15
prefix 1800
dial-peer voice 2007 pots
description --- FOR SRST only / PRI Voice Trunk: 0+13 --- TollFree Numbers
destination-pattern 013........$
direct-inward-dial
port 0/1/0:15
prefix 13
dial-peer voice 2008 pots
description --- FOR SRST only / PRI Voice Trunk: --- Specail Numbers(1100)
destination-pattern 01100$
direct-inward-dial
port 0/1/0:15
prefix 1100
dial-peer voice 2009 pots
description --- FOR SRST only / PRI Voice Trunk: --- Specail Numbers(1194 &
destination-pattern 0119[46]$
direct-inward-dial
port 0/1/0:15
prefix 119
dial-peer voice 2010 pots
description --- FOR SRST only / PRI Voice Trunk: --- Specail Numbers(1223)
destination-pattern 01223$
direct-inward-dial
port 0/1/0:15
prefix 1223
dial-peer voice 2011 pots
description --- FOR SRST only / PRI Voice Trunk: --- Specail Numbers(12455)
destination-pattern 012455$
direct-inward-dial
port 0/1/0:15
prefix 12455
dial-peer voice 2012 pots
description --- FOR SRST only / PRI Voice Trunk: --- Specail Numbers (12511
destination-pattern 012511[18]$
direct-inward-dial
port 0/1/0:15
prefix 12511
dial-peer voice 2013 pots
description --- FOR SRST only / PRI Voice Trunk: --- Specail Numbers(1920)
destination-pattern 01902$
direct-inward-dial
port 0/1/0:15
prefix 1902
dial-peer voice 2014 pots
description --- FOR SRST only / PRI Voice Trunk: --- Specail Numbers(19818
destination-pattern 01981[89]$
direct-inward-dial
port 0/1/0:15
prefix 1981
dial-peer voice 2015 pots
description --- FOR SRST only / Q-sig Voice Trunk: --- Internal 4 Digit
destination-pattern [456789]...$
direct-inward-dial
port 0/1/1:15
forward-digits 4
dial-peer voice 2016 pots
description --- FOR SRST only / Q-sig Voice Trunk: --- Reception/Operators
destination-pattern 99$
direct-inward-dial
port 0/1/1:15
forward-digits 2
prefix 99
dial-peer voice 2017 pots
direct-inward-dial
port 0/2/0:15
forward-digits 4
dial-peer voice 2018 pots
direct-inward-dial
port 0/2/0:15
forward-digits 2
prefix 99
dial-peer voice 2019 pots
direct-inward-dial
port 0/2/1:15
forward-digits 4
dial-peer voice 2020 pots
direct-inward-dial
port 0/2/1:15
forward-digits 2
prefix 99
dial-peer voice 4001 voip
dial-peer voice 4101 voip
description --- FOR SRST only / To first VG224 ---
destination-pattern 30125[789].
session target ipv4:19.242.170.4
voice-class codec 1
voice-class h323 1
fax rate 7200
no vad
dial-peer voice 4102 voip
description --- FOR SRST only / 7D internal to abc-vg3845 ---
destination-pattern 301[23]...$
session target ipv4:19.242.255.129
voice-class codec 1
voice-class h323 1
fax rate 7200
no vad
dial-peer voice 2023 pots
description --- FOR SRST only / Q-sig Voice Trunk: --- to DECT Phones
destination-pattern 1....
direct-inward-dial
port 0/1/1:15
dial-peer voice 2024 pots
direct-inward-dial
port 0/2/0:15
dial-peer voice 2025 pots
direct-inward-dial
port 0/2/1:15
sip-ua
no transport udp
no transport tcp
call-manager-fallback
max-conferences 16 gain -6
transfer-system full-consult
timeouts interdigit 6
ip source-address X.X.X.X port 2000
max-ephones 730
max-dn 803 dual-line no-reg
system message primary SRST Mode - Limited Access
system message secondary SRST Mode
transfer-pattern .T
keepalive 10
banner motd ^CC
WARNING! THIS IS A PRIVATE COMPUTER SYSTEM. USAGE MAY BE
MONITORED AND UNAUTHORIZED ACCESS OR USE MAY RESULT IN
CRIMINAL OR CIVIL PROSECUTION.
Except for some privacy rights granted by applicable law,
by signing on to the system you acknowledge:
You do not have any expectation of privacy in your use of the system.
You are familiar with, understand, accept, and will comply with the
provisions of Company Directive B-109.
^C
scheduler allocate 20000 1000
ntp server X.X.X.X
ntp server X.X.X.X
end
08-23-2011 09:03 AM
Something is going on with your voice translations with a combination of the dial peers. Id run a debug on the dial peers and see exactly which one its using. When you are in MGCP mode, the call is going to ignore any of this stuff until it goes through CUCM (which you must have some kind of digit manupulation going on at that point). After CUCM, it hands the call back to the router and should hit your dial peer to the PBX trunk.
08-23-2011 09:25 AM
I think the issue is being caused by this part of the config
This will be ignored under MGCP working.
I can not see what it point to.
Try removing it temporarilyand retest
Alex
08-23-2011 09:35 AM
Alex,
The command "
isdn supp-service name calling profile Network-Extension operation-value-tag local" is responsible for th calling name presentation with respect to the Q-sig interoperability with the PBX. I dont think it could cause the called number presentation on the GW from the PBX.
My Q is. why the called number is being received on the GW in the below manner
First 5 digits (30123) ENBLOC
next 2 digits (01) one-by-one.
Similarly, in the SRST itself.. The calls from the PBX DECT phone appears to be a normal 7 digits on the GW but the PBX Desk phone has the 5 digits issue.
08-24-2011 04:42 AM
Thank you for this information.
May be we could try adding the following to int s0/2/0:15
int s0/2/0:15
isdn overlap-receiving
isdn overlap-receiving T302 2000
Then re-test
Alex
