Highlighted
Participant
PCD Upgrading 8.5.1 to 11.5 Failed
Dear All,
We are performing upgrade and migrate from version 8.5.1.10000-26  to 11.5(SU2) using PCD direct upgrade. During post installation i am getting
error IPM|Internal Error, File:ipm.c:3087, Function: ipmWaitForChild(), Command "/opt/cisco/install/bin/pmNormalizeGeneric /etc/opt/cisco/install/component_install_cmd_list" has exceeded timed threshold of 3600 seconds|
3 REPLIES 3
Hall of Fame Cisco Employee
UPGRADE and MIGRATION are
UPGRADE and MIGRATION are different things, and are not interchangeable terms.
As PCD can only upgrade 8.6 and above, I'll assume this is really a migration.
The same error can be found in a previous thread
https://supportforums.cisco.com/discussion/12386081/installation-fails-cucm-subscriber-105-exceeds-3600-seconds-limit
java
if this helps, please rate
Participant
Thanks Jaime
Thanks Jaime
We are doing a migration from 8.5.1 to 11.5 (box to box migration) (VM to VM).
Participant
I sucessfully migrated to
I sucessfully migrated to newer version, but i did only one change in VM added the NTP setting and synchroized the correct time. due to this issue initially got failed?
Content for Community-Ad
August's Community Spotlight Awards
