PCD VM to VM
johnsnave1
I have CUCM ver 7.15 running on VM. I now have a requirement to upgrade to the latest version of 10.5. My question is, can I use PCD for this?
I will be hosting the 10.5 on a new server and keeping the same hostname and ip address.
Many thanks.
Jaime Valencia
You'll need to test it, having 7.x on a VM is not something we support, and therefore, not something PCD was tested to do.
Officially that would be ruled as NOT supported.
java
if this helps, please rate
Jaime Valencia
java
ok - thanks.
