Permanent On a Call
Hi all!
UCM - 11.5.1.11900-26
IMP - 11.5.1.11900-21
Phones - IP Phone 7911, 3905, 6921
Recently I faced with the problem, users go to permanent "On a Call" in Jabber. Phone handset is on-hook and Jabber is not calling. They both do not call anywhere. Then I dial to user there is busy signal, but user can call me.
After restart phones users go "Available" for some time.
Could you please suggest what can be done in this situation.
Manish Gogna
Hi Anton,
Couple of posts with similar issue below that you will find useful
https://supportforums.cisco.com/discussion/12306961/incorrect-presence-status-jabber-windows-105
https://supportforums.cisco.com/discussion/12111006/jabber-96-windows-not-showing-when-users-call#4174339
Manish
Hi Manish,
Many thanks!
It seems I have found the problem. CUCM Presence Viewer shows correct status of users, but Jabber client shows "Offline, On a Call". I downgrade Jabber client from 11 to 10.x and now status is correct.
Hi Anton,
You may also try with latest version of jabber and see if that helps. Downgrading is not a good idea as it exposes the system to more bugs, you may involve TAC if needed.
Manish
Recognize Your Peers
